10-16-2015, 08:28 AM | #1167 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
If that's the case, you should be able to just connect the green HSD cable from the TCB straight to the NBT and you will be able to retain the SOS functionality as long as write your VIN to the new NBT. It's very unlikely that the NBT has no FSCs if it is a used unit. If it is a virgin NBT, you can always inject a set of repair codes from another car or you can use E-sys to download the codes from someone else's car.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
10-16-2015, 09:06 AM | #1168 |
Rep 263
Thanks Aritaurus. It's 9/15, so definately the new version you mean.
I'll check the green cable. But where can I find this TCB and how does it look like? This means the TCB substitutes the formerly built-in combox as an external device and also contains the SIM card? If so, I'd get rid off the problems I feared as I'd not touch this part and just change the HU...? If I'm not wrong with that, this way I shouldn't get any problems with SOS call and even Teleservices? Last edited by TePee; 10-16-2015 at 09:12 AM.. |
10-16-2015, 12:35 PM | #1169 | |
Rep 1,976
Correct - if you plug that in and code it correctly, you will be able to retain your SOS calling functionality. I cannot guarantee that it will work 100%. I have swapped HU_ENTRY on a 2014 model with the ECall combox and even with that, the SOS button still works. I believe the combox has a direct connection to the emergency speaker underneath the steering wheel so it can technically still work without the head unit.
10-16-2015, 02:17 PM | #1170 |
Rep 263
I was excited and took out my original HU Entrynav to check the connecting cables. As you can see there is the mentioned green cable (TCB?).
I try to identify. Please correct if I´m wrong. Beginning from left: black: FM 1 antenna cable white: FM 2 antenna cable blue: not used (probably USB2 for ground plate, which I don´t have) green: TCB white: USB1 purple: CID brown: Bluetooth antenna As you can see there is no GPS connector! Although the HU is called Entrynav, it is not possible to enable navigation. |
10-16-2015, 02:26 PM | #1171 |
Rep 263
Now I checked the connectors at NBT Evo. There is no green one for TCB! Only USB1 and USB2.
This means I can´t just swap my Entrynav with NBT Evo because I can´t connect my TCB!? When I check normal NBT (no Evo), it has the green connector (TCB?). Does it mean I´d be better off to install NBT instead of NBT Evo? Please have a look at NBT Evo connectors to see what I´m talking about: |
10-17-2015, 03:11 PM | #1172 |
Rep 263
Me again
I've found out that Entrynav has TCB Basic connected via USB (as NBT too). But NBT Evo has a newer generation of TCB and this is not connected via USB but via Ethernet. This why the third green USB connector is missing at NBT EVO. The Ethernet connector is the flat black square one (OABR) above the big main connector. And this is my problem... But I guess if don't connect the green TCB cable SOS call still would work. Telematics I plan anyway to try to deactivate officially But of course it is not the best solution to leave a cable just not connected. Last edited by TePee; 10-17-2015 at 03:19 PM.. |
10-18-2015, 09:25 AM | #1173 | |
Rep 1,976
NBT EVO uses ATM for telematics so the TCB won't be compatible. ATM uses Ethernet which is what the rectangular connection is for. Also, NBT EVO doesn't use the GPS Arial port on the head unit ATM now has the GPS antenna. I believe you can get it to work while plugged into the head unit but it will require some coding. If you had the older NBT, it would pretty much be plug and play with a little coding.
10-18-2015, 09:28 AM | #1174 | |
Rep 1,976
At least with NBT, you'll be able to maintain most if not all of your functionality and it will look completely OEM.
10-19-2015, 05:44 AM | #1175 |
Rep 263
Many thanks Aritaurus once again!
I don´t want to swap the TCB, thus I have 2 possibilities: 1. As you wrote the best would be to buy normal NBT, which should be plug&play. I´ve found out that the parts-number of the TCB my car has, is also used at earlier cars with normal NBT – according to parts catalog. 2. I could keep NBT Evo and just not connect TCB. The question is what will cause this? SOS will probably still work without HU in a limited way as it is connected to extra loudspeaker and micro too? I also could deactivate TCB officially – just Teleservices or even SOS. Teleservices I don´t prefer anyway and all the Connected Drive stuff I don´t really need. The best would be to swap TCB too and then enjoy full improvements of EVO. Due to some reasons it´s not allowed to me to swap TCB Maybe someone with normal NBT is looking for EVO...? |
10-19-2015, 09:11 AM | #1176 | |
Rep 1,976
2. If you go with this option, you should at the very least be able to still press the SOS button in the case of an emergency but you will not be able to access the Teleservices Call function on the iDrive itself. Regardless, you will need to code the NBT2 to use the GPS Arial located on the head unit as opposed to the one from ATM. I don't think you can swap TCB with an ATM. Even if you had access to one, it would have to come from a donor vehicle that has a valid BMW Assist subscription.
10-21-2015, 07:05 AM | #1177 |
Rep 15
Hey All,
I have followed this thread and decided to fit the NBT in my F20 builddate 06/2012 currently equipped with Radio Prof (HU_ENTRY with Combox) and expanded KOMBI. Although there is a lot of useful information in this thread, I still remain with a few questions because it's a F20. 1. As read the Combox must be disconnected after the retrofit and the USB, GPS and Bluetooth rewired to the NBT. The colors of the plugs however are different for the USB and GPS in the Combox then in the NBT. GPS Combox = Pink, USB Combox = black, GPS NBT = Blue, USB NBT = Beige. Do the different colors matter or will the plugs just fit into the different colored NBT entries? And will this installed GPS antenna work for the NBT or do I need an eBay one? 2. The MOST wires are now coming from the Combox to the unit. Is it correct they need to be disconnected completely because this is already a build-in feature from the NBT unit? 3. The GSM antenna is also connected to the Combox, does it has any function after installation of the NBT or does it has to be disconnected? 4. Currently I have the Emergency call option, will this, including connected drive (remote services etc.) from BMW, work on the NBT as before? 5. Do you advise to use FSC codes or the can filter with emulator to get the navigation, apps etc. working? And will it still be possible to update the car's/NBT software if I use an emulator. I hope you guys can provide me with soms answers, that would be highly appreciated! |
10-21-2015, 05:29 PM | #1178 | |
Rep 1,894
1. As read the Combox must be disconnected after the retrofit and the USB, GPS and Bluetooth rewired to the NBT. The colors of the plugs however are different for the USB and GPS in the Combox then in the NBT. GPS Combox = Pink, USB Combox = black, GPS NBT = Blue, USB NBT = Beige. Do the different colors matter or will the plugs just fit into the different colored NBT entries? And will this installed GPS antenna work for the NBT or do I need an eBay one? You can pull the wires from the combox over to the NBT but it's easier to buy the spare cables off eBay, makes returning to original config a lot easier. 2. The MOST wires are now coming from the Combox to the unit. Is it correct they need to be disconnected completely because this is already a build-in feature from the NBT unit? Disconnect all the wires from the combox and terminate the MOST loop using something like this: http://www.ebay.co.uk/itm/BMW-AUDI-M...8AAOSwl8NVWD26 If you don't then the audio won't work as it's carried along the MOST. Also you'll need to move the MOST connectors from your original quadlok connector to the emulator. 3. The GSM antenna is also connected to the Combox, does it has any function after installation of the NBT or does it has to be disconnected? Not sure, but I've had no issues with using my mobile inside the car. 4. Currently I have the Emergency call option, will this, including connected drive (remote services etc.) from BMW, work on the NBT as before? Don't know. 5. Do you advise to use FSC codes or the can filter with emulator to get the navigation, apps etc. working? And will it still be possible to update the car's/NBT software if I use an emulator. When you get the NBT, most units I've seen have the donor FSC codes still on the unit. It's way cheaper and easier to use those codes with an emulator than buying them. It doesn't matter where you get the NBT from as the FSC codes will work with any map. Also ask your seller if the NBT has the 6NR (Apps) or if they know what the donor vin is, that way you can check on bmwvin.com. I hope you guys can provide me with soms answers, that would be highly appreciated! |
10-22-2015, 01:01 PM | #1179 |
Rep 15
Thank you for the answers kitster! Really appreciate it.
Anyone who can still provide me with an answer on the questions below? 1. Currently I have the Emergency call option, will this, including connected drive (remote services etc.) from BMW, work on the NBT as before? 2. The GSM antenna is also connected to the Combox, does it has any function after installation of the NBT or does it has to be disconnected? Thank you! |
10-22-2015, 08:35 PM | #1180 | |
Rep 286
First of all you don't need to remove the combox. You can FDL code the entries with Bluetooth and USB functions on combox. I have done this on two of the retrofits with CIC and Entry. If you scroll back on this thread there are instruction on how to FDL code out the Bluetooth and USB. Once you do so, your NBT Bluetooth will take over and wont conflict with combox.
On the entry with combox (ecall) we were able to trigger the Emergency call function using the menu or the SOS button, however if you re route the mic from combox to nbt, the other party won't be able to hear you, as the signal will need to go to combox. My advice is to get an aftermarket mic for NBT (for bluetooth calls/phone) and leave the OEM microphone connected to combox. This way you can retain ecall function using your combox. I can maybe later lookup the fdl codes you need to remove on combox. Quote:
10-24-2015, 09:08 AM | #1181 |
Rep 15
vithy thank you for your answer. I will probably leave the Combox connected, so it will be more easy to return to the original configuration if needed.
I have ordered most of the parts now and expect them next week, but some additional may be needed. So if I understand it all right, I will need to do the following: - Replace the unit, screen and iDrive controller. - Place the can filter between the quadlock coming from the car and the unit connector. - Disconnect the MOST connector from the Combox and terminate it with the terminator adapter. Remove the MOST connector from the original quadlock and replace it to the emulator quadlock entering the NBT. - Connect the GPS antenna to the NBT (I've one connected to the Combox, but following this topic, do you guys advise to use the FAKRA GPS deliverd with the NBT?) - Connect the Bluetooth. It's currently connected to the Combox, but as I understand I should leave that one installed and get for example this? http://www.ebay.co.uk/itm/BMW-CIC-NB...-/251525655643 - Connect the USB (rewire or new cable) and shave it + turn 180 degrees to get it working. - I will probably leave the AUX function alone. Did you guys rewire it or buy a new cable? About the MIC's. I have two installed (left and right) and would like to keep using them and refrain from installing new ones. Is it possible to reassemble the MIC connectors in the roof with some extra wires and lead them direct to the quadlock? If this is possible I could still use them for the emergency call option in the Combox. Finally, code. Can this be easily picked up by a newbie (found some tuts and stuff)? I am just starting with it and did order an ENET cable. I have an 06/2012 F20. Which version of E-SYS do you advise? Currently got 3.26.1 installed with PSdZ 56.4 (lite). Thank you all for contributing to this great DIY! |
10-25-2015, 01:29 PM | #1183 | |
Rep 1,894
10-26-2015, 11:41 AM | #1184 | |
Rep 286
If you have two Mic's, just disconnect the left (driver side) one and connect to NBT. If i'm not mistaken, the right side/passenger side, should be going to combox, which should allow you to use the ecall function. I'm not really sure, how it's wired in Entry_HU. But you can play with this as you install.
Disconnect you current quadlock and check to see if you have wires on 17/22 (Mic1) and 18/19 (Mic2) connected. If you have Mic1 going into your Entry_HU, then you don't need to rewire anything, If not you might need to tap into quadlock to mic1. Quote:
10-26-2015, 03:12 PM | #1185 |
Rep 15
Thank you vithy and kitster! Will check it out tomorrow how those are routed. New cable ordered.
Another question about BMW apps (6NR). Currently I have 6NL connectivity (Extended bluetooth connectivity, usb etc. + telephone base plate in armrest) and no glovebox USB. If I shave and turn my current USB cable and connect it to the beige NBT port, will this also support Apps (6NR)? Besides VO coding 6NR, do I need to change anything with regard to 6NL? |
10-27-2015, 03:12 PM | #1186 | |
Rep 286
6NR requires you to have FSC codes on your NBT. Coding alone wont activate this. You have to make sure it's actually in yours.
10-27-2015, 04:51 PM | #1187 |
Rep 15
I currently have the can filter and will wait until the NBT arrives to see if the donor VIN supports apps.
But for coding purposes, what do I need to change besides adding 6NR? I currently have 6NL. Will this need to be changed or...? |
10-28-2015, 12:20 PM | #1188 |
Rep 286
6NL to 6NS should be fine. Only add 6NR if you have APPS fsc, if not it will error out during coding.
