08-09-2020, 05:02 PM | #1 |
Rep 34
F32 N55 Dyno - MHD Stage 2+
Not much to show since I don't have a baseline but figured I'd post for those interested in just numbers.
N55 EWG 8AT Mods: ER Catless DP ER Chargepipe VRSF 5" HD FMIC NGK 97506 Plugs gapped to .022" K&N Drop-In Filter MHD Stage 2+ 93 Oct JB4 (currently only using for logging) Shop was around 100°F and 50% humidity 5th run made 374 HP/372 TQ in 6th gear Car was pretty hot at that point, had a couple scrub runs due to hitting the kickdown. Torque numbers seemed low compared to other dyno results I've seen.. I plan on running E30 soon and will dyno again. |
08-09-2020, 05:32 PM | #2 | |
Rep 7,611
Also i would recommend just getting MHD monitoring moudle. If your JB4 logging speed is like the others i have seen its 10-20x slower (lower time resolution) than MHD. |
08-09-2020, 07:14 PM | #3 | |
Rep 4,160
I LOVE MHD’s torque curve, but the tunes are down on absolute power (but more reliable) For the record, that’s about 365whp SAE. Last edited by AmuroRay; 08-10-2020 at 04:01 PM.. |
08-09-2020, 08:13 PM | #4 |
Rep 1,288
Time to order some boostane from Amazon Prime and use the 95map... there is noticeable difference between the 93 & 95 map...
08-09-2020, 10:42 PM | #5 | |
Rep 7,611
E20 map will make more power than 95 map per MHD. |
08-09-2020, 11:46 PM | #6 |
Rep 1,288
08-10-2020, 11:00 AM | #7 |
Rep 7,611
E30 is probably the most common custom tune with upgraded HPFP; you can just run more boost with the upgraded HPFP. With stock turbo you can probably go to E50 (on stage 1 HPFP), which should allow you to make some more power with timing in addition to the extra boost.
08-10-2020, 04:02 PM | #9 |
Rep 4,160
08-10-2020, 04:42 PM | #10 |
Rep 1,105
365whp for a PWG sounds pretty accurate for FBO.
Jordan1scool32.50 |
08-10-2020, 04:55 PM | #11 |
Rep 7,611
08-10-2020, 06:26 PM | #12 |
Rep 1,105
08-11-2020, 08:36 AM | #13 | |
Rep 9
08-12-2020, 03:33 PM | #14 |
Rep 94
Tpriest7893219.50 |
08-12-2020, 04:35 PM | #15 |
Rep 7,611
Tpriest7893219.50 |
08-14-2020, 01:20 PM | #16 |
Rep 5,374
The numbers look solid. The ambient heat and humidity were likely sucking out some power because your peak HP power only hit at 5500rpms and then dropped from there. The EWG N55s hit peak power at around 6000-6200rpms and then tail off. When they're heat soaked, timing gets pulled and they almost always peak at 5500rpms. This happens a lot on heat soaked N55 M2s.
If you were to have run on a 50 degree day, I'd bet those numbers would be more like 385whp/wtq.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
08-14-2020, 01:35 PM | #17 | |
Rep 4,160
08-14-2020, 01:49 PM | #18 | |
Rep 7,611
2nd post here: https://f30.bimmerpost.com/forums/sh....php?t=1710794 Image: |
08-18-2020, 01:48 PM | #19 | |
Rep 4,160
Mods: Yes.
08-18-2020, 04:34 PM | #20 |
Rep 1,288
Alright thejeremyman9... got the fabspeed put on... definitely spins up faster... I just did a run and IAT's are too high to compare to my other log but yea it pulled a lot of timing like you said it would... I only drove it like 20 miles on the freeway so far... there is a spike @ 5336rpm... maybe I hit a bump in the road???.... well here is the log... Click here
08-18-2020, 05:57 PM | #21 | |
Rep 7,611
Timing is decent, not too bad honestly considering IATs are very high and its the 95 map. That does look like a bump, yeah. Unless you are 6MT it could be clutch slip, but it's kindof far into the pull for that even if you were. Even hitting a small bump can look like that (you dont have to like catch air for example, just reduce load on rear tires). |
08-18-2020, 06:24 PM | #22 | |
Rep 1,288
Yea running Boostane 8oz per tank of 93.... think'in dropping another 8oz in it to compensate for IAT Yea... I think it was a slight bump... I have the 8AT So in the end... I think it's gonna run real nice this November... Last edited by FastF30; 08-18-2020 at 06:45 PM.. |
