08-18-2020, 02:34 PM | #331 |
Rep 192
Ask kretzu for links here https://f30.bimmerpost.com/forums/sh....php?t=1329605
08-19-2020, 09:31 PM | #332 |
Rep 912
Drives: G12 750Li
Im unsure as to how this works, can someone give me a run down?
08-23-2020, 04:01 AM | #333 |
Rep 2
Hi,
can someone send me FSC code to update map? Curently on my nav I have installed Road Map EUROPE EVO 2018-2. I have donwloaded 2020-2 version and have it on USB stick. VIN: G617383 Production date: 03.03.2016. These 2 FSC codes are not working: EDN543WQE4XAYAJAAD7Q NSQNTTDFDSE5AAJAABEQ All the best |
08-26-2020, 07:49 AM | #334 | |
Rep 30
You will have to extract the file from your car to be able to create a working key. therefore you need a cable and software. If you are from vienna there are a lot of F3x drivers (community) that should be able to help you.
09-03-2020, 01:49 AM | #335 |
Rep 2
Can someone help me, I have BMW F30 VIN: J621410, production 12/2012 and I am having troubles with navigation. I tried to upgrade it, and now even the original version Road map wants FSC code (ROAD MAP EUROPE MOVE 2013, 101114013), I tried the generator form Jagaer by date and it does not work... Thanks...
09-07-2020, 11:45 AM | #337 | |
Rep 102
Can the links be updated as they have expired. Cheers |
09-07-2020, 11:14 PM | #339 |
Rep 170
@x-m4n : Done
Lookup.xml updated with 2021 North America NEXT Last edited by Jagaer; 09-07-2020 at 11:43 PM.. |
contracts3444.50 x-m4n148.00 |
09-09-2020, 03:48 AM | #340 |
Rep 83
Awesome work here Jagaer just wanted to confirm there is no way of downloading the DE file for NBT units using Bluetooth OBD readers and a mobile app?
Don't have a windows laptop, just an iMac so ENET cable is not that convenient with a 27inch iMac |
x-m4n148.00 |
09-11-2020, 05:37 PM | #341 |
Rep 3
Hi Everybody.
This might be a daft question, but for Jagaer's tool when selecting maps, do I select map version i currently have in the car or the new ones I would like to update unit with? Just trying to make sure everything goes smoothly. |
09-12-2020, 07:57 AM | #342 |
Rep 766
09-17-2020, 08:44 AM | #344 |
Rep 8
Would it be possible to get the FSC code for my 2013 F30 20d, please?
VIN: F295980 ECE BMW Group 101104.2.17 Current map: Road Map Europe PREMIUM 2012 Going to: Road Map Europe EAST PREMIUM 2020-2 Would greatly appreciate it, thank you. |
09-19-2020, 10:07 PM | #345 |
Rep 103
I have a '16 F80 with NBT EVO ID4 that uses EVO maps.
I was able to get this software to generate a key with my F0.fsc file, but it didn't work. Reading more closely, I think that is expected now because of the EVO maps part. Can you knowledgeable folks confirm? If so, is my best way to upgrade at this point Ebay roulette? |
09-20-2020, 03:07 AM | #346 | |
Rep 2,302
The generator doesn’t work for Evo-Maps. And yes, it‘s the best idea to buy a code on EBay. |
09-20-2020, 10:09 PM | #348 | |
Rep 2
Help
I would like to know if you can help me, i have '17 mini cooper pepper and i would like to update the Nav system, i already have the maps but i need the code! can you help me ? i dont have an obd-ethernet cable Thank you! |
09-29-2020, 04:11 AM | #349 |
Rep 30
what NAV du you have in your car? if you do have facelift it may be possible that you do not have NEXT map's so if you do have EVO it is not possible to use this tool.
10-08-2020, 04:27 AM | #350 |
Rep 7
Can anyone help, I have tried everything to get the 1b.hex file off my car but nothing works.
I have also tried to manually input my long vin number into the FSC Generator but all the codes which get generated do not work. My vehicle is a 2013 F25 with the following navigation system: Europe BMW Group 101114014 Road Map Eurpoe MOVE 2013 I have got the Europe MOVE 2019 Map update file ready to go into my car but need the FSC code. The last 7 digits of my VIN: 0C69515 Please, please, please can someone help as im pulling my hair out with it! Thanks in advance |
10-11-2020, 01:07 AM | #351 |
Rep 4
Thanks for the great work on the generator.
However I am having some issues. I can properly extract the 1b hex, done so twice for good measure, however the generator can't read the file, saying it could be corrupt. Now my dealer had my CIC and all modules updated just this week, (E91 2008) so is it possible that I'm running a version unsupported by the tool? I simply get "Incorrect RSA Key Header/Footer File Likely Corrupted" Edit- The new version of the CIC tool repaired the Hex properly it seems! Last edited by Zews; 10-11-2020 at 01:39 AM.. Reason: Spelling |
10-12-2020, 02:05 PM | #352 |
Rep 14
You can use esys to fetch your car it's FSC code.
Then once you got that code, feed it into this application (from Jagaer) and it will then generate the code you need. |
