12-30-2015, 05:03 PM | #1 |
it can never be too clean...
163
Rep 1,100
Fix: annoying door creaking - bmw 3M tape solution
~ I know many have discussed the annoying creaking noises that come from the door areas as a result of the upper door felt/rubber rubbing against the black shadow line trim (typically sounds more like the noises are around the door pin/striker area). Cleaning and waxing the area always seemed to help for a short while but not long term.
I brought the bulletin to the attention of the dealer and they ordered a roll of the 3M Teflon tape. My local dealer and preferred technician graciously allowed me to take the $250 roll of 3M tape and apply the tape myself because I'm a bit particular...with the understanding I would return the unused portion of the roll (more than 50% remains after installing the tape on both sides of the car). Please see the detailed photos below of my install... I began by cleaning the black trim thoroughly with rubbing alcohol to remove any wax or silicones to prep the surface for the proper adhesion. I then closed the doors and ran blue painters tape about 1/8" above the rubber door felt for an alignment tool once the doors were opened for the installation of the tape. Thus allowing a clean straight line once completed. The install was easy and I applied the tape dry with the ability to adjust as needed before firmly securing the tape in place. I also used a dry microfiber towel and pressed aggressively to assure full adhesion once finished. End result... All and all - fairly easy to do with the attention to detail and prep. Total install time 45 minutes. Finally no more door creaking on uneven pavement. Problem solved. (Bulletin: SIB 51 28 10)
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra Last edited by andrew 330i; 12-30-2015 at 08:05 PM.. |
12-30-2015, 05:13 PM | #2 |
Rep 2,407
Drives: E30 M3 Cecotto, F85, G05, G07,
Well done!
12-30-2015, 06:56 PM | #4 | |
Rep 376
I was pretty disappointed so hoping that if I can show them an actual service bulletin with a more useful resolution than simply "keeping it clean," then it might help.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
12-30-2015, 08:01 PM | #5 |
163
Rep 1,100
~ I believe this is it: SIB 51 28 10
I will double check with the dealer tomorrow.
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra |
12-30-2015, 08:14 PM | #6 |
Rep 3,622
That's cool! I just wipe mine with rubber cleaner/treatment and no squeaks
BMW CCA Member #516012
upsidedownfunnel1996.00 |
12-30-2015, 08:27 PM | #7 |
Rep 4,981
Had the Teflon tape applied per the below thread back in June/July and I haven't heard a single squeak or rattle since. I mentioned it to my dealer and they said the first thing they did was apply the Teflon since a number of people had the same issue. Worked like a charm.
http://f30.bimmerpost.com/forums/sho....php?t=1029827
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-04-2016, 09:14 PM | #10 |
Rep 2,744
Thank you for this post!
Your solution is probably the best permanent fix, but this gave me the key for a similar (if cheaper/simpler) solution. My doors have been squeaking for a couple of months now over speed bumps and other road irregularities, and I've tried a variety of lubricants liberally applied around the rubber seals on the doors and frames, with little luck. In fact, sometimes it seemed to get worse. But based on this thread, I cleaned off the rubber seals themselves (using water + soap), and then simply applied some DuPont dry Teflon spray along the bottom half of the shadowline trim. Voila, noise is GONE! Thanks again. I wonder how long this'll last... |
01-04-2016, 10:50 PM | #11 |
I want to drive a Zamboni
1128
Rep 5,554
Drives: 13 E93 M3 18 F80 M3 16 K71
Had mine done by dealer a few months back the problem just show up in December, dropped the car off this evening and hopefully they can fix the rattle. Not to mention the steering column had a buzzing noise as well.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
01-06-2016, 12:02 PM | #13 | |
Rep 3,468
01-06-2016, 12:14 PM | #14 | |
1128
Rep 5,554
01-06-2016, 12:16 PM | #15 |
Rep 3,089
Can you please post a link? I just tried searching for it but didnt find anything that looked similar.
01-06-2016, 12:40 PM | #16 | |
Rep 3,468
http://www.amazon.com/gp/product/B00...3&sr=8-3-fkmr1 Given, it's only 5yd rolls, but still, 33m would be 36 yards, 36/5*4.88=$35 Wildly overpriced at $250, but hey, it's BMW, what does one expect? |
01-06-2016, 12:43 PM | #17 | |
Rep 3,089
Perhaps this is better? http://www.amazon.com/CS-Hyde-Polyet...W6M6SEMCT9YG4E
01-06-2016, 01:11 PM | #18 | |
Rep 3,468
01-06-2016, 01:17 PM | #19 |
Rep 3,468
Here's another one, the exact tape, again for cheaper, although not quite as cheap. (only like 5yd, but you don't need that much anyway).
http://www.pemro.com/productDetails....src=googleBase Same exact 3M part number/spec as the BMW tape. |
01-07-2016, 03:40 PM | #20 |
Rep 1,738
Dammit, I just started hearing this last night. Just slight little creaks around the window area while going over small bumps and uneven road surfaces. Must be the cold weather. I never heard this last winter.
So basically you apply this tape to the shadow trim so that the rubber seal of the door rests on the tape instead of the trim. KGB, you said you use silicone lube....you mean like silicone divers grease? Like wipe it on the rubber every time it gets squeaky? I have a jar of this stuff for O-rings in air lines. |
01-07-2016, 04:49 PM | #21 |
Rep 3,089
As much as I like the idea of getting rid of this annoying creaking, I am worried about how this tape will look after a while. Will it yellow? In case another application needs to be in a year a two can it be removed without damaging the rubber? etc...
01-10-2016, 11:47 PM | #22 |
1128
Rep 5,554
Need to drop the car off to dealer tomorrow and they need to replace the tape and realign the door, hope that would fix squeaking noise.
