04-18-2022, 09:40 AM | #419 |
Rep 40,789
Do you still have banner on your profile? If not, make sure you have PM enabled under your account settings.
Control Panel => Edit Options => Messaging & Notification and Check these boxes: Enable Private Messaging Receive Email Notification of New Private Messages Show New Private Message Notification Pop-up
04-18-2022, 10:36 AM | #420 | |
Rep 21
But nothing seems to happen |
04-18-2022, 10:37 AM | #421 |
Rep 40,789
No idea. Try an contact a Forum support or Moderator.
SRB-F31M30.00 |
04-18-2022, 08:59 PM | #423 |
Rep 97
04-19-2022, 09:00 AM | #424 |
Rep 13
04-24-2022, 07:47 PM | #426 |
Rep 40,789
04-25-2022, 06:58 PM | #427 |
Rep 13
ok, shaw muchas gracias por su respuesta, que le podría añadir a mi entrynav por FSC para modernizarla un poco, bmw live por ejemplo se podría o seria para hu mas modernas, por que lo del trafico en directo seria por suscripción no??
04-25-2022, 08:46 PM | #428 | |
BimmerGestalt dev
Rep 14
I would like to point out that your BMW Apps FSC codes are still valuable, especially now that the subscription services for older 3G cars have shut off. Even though the official BMW Connected app has shut down and MyBMW does not provide the previous BMW Apps features, MyBMW still establishes the Apps connection to the car to update car information in the app without using the ConnectedDrive cloud connection. Additionally, the old BMW Connected app (available from various Android APK sites) still connects to the car even without the user being able to log in, and AAIdrive can use either of these app connections to add its features to the car. Please continue your generous work of sharing BMW Apps FSC codes for these users |
04-25-2022, 09:01 PM | #429 | |
Rep 40,789
Just so I am clear though, AAIdrive will also work without 6AK ConnectedDrive Services so long as : 1. Car has 9C FSC Enabling Code 2. Car has 6NR BMW Apps Coding 3. Car has either old ConnectedDrive .apk App or new MyBMW App And for iPhone users, they are out in the cold?
04-26-2022, 08:50 AM | #430 | |
Rep 17
Which guide did you follow to enable the BMW Apps? |
04-26-2022, 08:51 AM | #431 |
Rep 40,789
You need 9C SFC Code and 6NR Coding.
04-26-2022, 09:21 AM | #433 |
Rep 40,789
C1984H0.00 |
04-27-2022, 10:46 PM | #434 | |
BimmerGestalt dev
Rep 14
And so, I appreciate your experience and knowledge in this! If there is some more confident wording to including in the app or description for users to know ahead-of-time that their car is compatible, please let me know! My understanding of the app connection is: 1. Something about the car triggers the MyBMW/BMWConnected app to start the BCL connection to the car, either over USB or Bluetooth SPP. I believe MyBMW includes a Bluetooth address check to only start connecting to cars that are in your "Garage", but BMWConnected doesn't seem to care. 2. AAIdrive detects the case where the connection doesn't succeed because the car is expecting the Apps connection from, say, the USB connection and the phone is trying to connect over Bluetooth. I don't know how the connection reacts if the subscription/coding is not enabled, but might be similar. 3. Once MyBMW/BMWConnected is connected, it starts up a local TCP port on the phone for other apps to talk to. 4. AAIdrive connects through this port and generally reliably works great after this point. I believe the iPhone connection is the same. I've sniffed the iPhone USB connection and I can see the same traffic, but I don't know how the specifics on how the other apps talk through the connection. It seems harder to downgrade the apps on iPhone too, which removes the option of installing the older BMWConnected app. :\ |
04-27-2022, 10:57 PM | #435 | |
Rep 40,789
1) 9C FSC Code and 6NR BMW Apps Coding - Connection via USB 2) No FSC Code (enabled via Provisioning of Vehicle SIM Card) and 6AK ConnectedDrive Services Coding - Connection via BT
hufman4.50 |
04-27-2022, 11:51 PM | #436 |
Rep 883
FYI — I never de-installed the old BMW Connected app when I added My BMW to my iPhone. It worked for a decent while in parallel, but now Connected no longer launches at all. Not on current OS or on older iPhone/OS. (Backend is dead Jim)
06-06-2022, 08:58 PM | #437 |
Rep 3
009c - A4A not activated
shawnsheridan
im newly replaced my headunit from NBT to NBT_EVO, afterwards i try to connect via bimmercode and found that unable to code it since 009C-A4A activation code rejected. do you know what I could do to resume it? many thanks! |
06-06-2022, 09:00 PM | #438 |
Rep 40,789
You retrofitted NBT2. What did you use for FSC Code solution? Feature Installer?
06-06-2022, 09:07 PM | #439 |
Rep 3
Sorry man I have no idea about it since my friend done the installation for me and the hardware seller code it thru my friend's laptop with remote session... i ve heard something like esys
06-06-2022, 09:19 PM | #440 |
Rep 40,789
All your FSC Codes are from App called Feature Installer. If you need BMW Apps, your installer needs to fix 9C FSC code. The BimmerCode issue though has nothing to do with 9C FSC code, rather the issue is it does not work on any Head Unit once Feature Installer is used. The Developer is aware of it and will not fix it. You can Code NBT2 with E-Sys instead.
