02-13-2019, 02:07 PM | #1 |
Rep 328
Drives: 2013 335i, ‘08 328i, ‘03 316ti
Snake oil or useful?
Quick question. My car is at the dealer for some CPO work and they tried to sell me their Engine Decarbonization" and „Fuel Injector Flush" for $200 a piece. This is a N55 engine with 35k miles. I know these procedures are pretty unnecessary for a well maintained N52 engine. Are they more useful for the direct injected N55?
02-13-2019, 05:09 PM | #2 |
Rep 5,457
Drives: F30
Fuel injector flush is likely hogwash so long as you've been using a top tier fuel of 91 or better octane. I also use a can of Techron every 10k just to be sure and that may even be throwing money down the drain.
Now the Engine Decarb... I would be interested to hear more about. Wonder what exactly is included in this service? |
02-13-2019, 05:33 PM | #3 |
Rep 16,120
They're probably using this or something similar for 'de-carbonization':
https://www.amazon.com/CRC-05319-Int...e%2C223&sr=1-1 The other option is walnut blasting, which would cost a lot more than $200. Cleaning the intake valves yearly is a good idea, especially as you can do it yourself for less than $20. Fuel doesn't go through intake valves with direct injection, so detergent in the fuel won't clean them. While you're at it clean the MAF sensor: https://www.amazon.com/CRC-05110-Mas...GCNCBESQ5JPAEP The injector cleaning is probably using this: https://www.amazon.com/dp/B07576419V...d-dda674112141 I put that in my tank yearly. It can't hurt, beats replacing injectors. |
BMWinAZ104.00 waxwing_f311.50 |
02-14-2019, 12:29 PM | #5 |
Rep 16,120
02-14-2019, 12:57 PM | #7 | |
Rep 5,091
So should walnut blasting still be considered@50k-60k miles? |
02-14-2019, 01:39 PM | #8 |
Rep 16,120
How long do you plan on keeping the car? It might be a worthwhile investment if that's another 30k miles or more, especially if you do it yourself. The blasting part is easy, removing the intake manifold and all the stuff it takes to get at the manifold is the hard part.
02-14-2019, 02:17 PM | #9 | |
Rep 5,091
My thinking is to keep for another 40k to 50k, so dont-touch for now. |
02-14-2019, 03:48 PM | #10 |
Rep 16,120
I don't know if it's possible to get a look at the valves with a borescope without too much hassle, but if it is I'd consider doing that before spending $600 on something you don't need, or not spending $600 on something you do need.
Pittcrew34.00 |
02-14-2019, 04:24 PM | #11 | |
Rep 5,091
BTW an indy tried in vain to use borescope through the oil cap opening to inspect the plastic TC rail guards, as there were too many twists and turns along the way. |
02-14-2019, 05:18 PM | #13 |
Rep 5,091
Got it, but getting through intake manifold(and removing all those components) probably will be 2/3 the work of walnut blasting, right?
02-14-2019, 06:40 PM | #15 |
Rep 328
Didn't get it done at the dealer. But I started to think about researching additives/cleaners by Techron and LiquiMoly. May use them on all my cars in the future.
02-14-2019, 06:54 PM | #16 |
Rep 16,120
I don't know, haven't looked at it all that closely. You might get in by just pulling the pipe at the throttle body entrance.
02-15-2019, 11:42 AM | #17 |
Rep 57
How do you clean the valves without walnut blasting?
02-15-2019, 12:24 PM | #20 |
Rep 5,091
02-15-2019, 12:39 PM | #21 |
Rep 16,120
02-15-2019, 12:41 PM | #22 |
Rep 57
