01-13-2020, 09:10 AM | #45 |
Rep 60
This thread is full of great information, thank you kern417 for all of your efforts.
With the understanding that this mod is still new, does anyone have any long term concerns about the higher pressure pump wearing out the regulator or injectors sooner than the stock pump would? |
01-13-2020, 10:57 AM | #46 | |
Cheapskate
4447
Rep 4,993
Same for the FPR. It's related to flow, not pressure. If anything, pumps that flow more than the TU pump are more likely to hit the limits of the FPR. But that's based on how much fuel you're using. That's why I said before that it didn't make sense for the pump to create an issue with fuel pressure. BUT the real risk I do see is the safety valve that protects the system in case the FPR fails. It would bleed off pressure to protect the fuel system just above the 200bar standard pressure. I'm just not concerned since I haven't heard of a failed FPR in ever on a modern DI engine. I don't think we'll hit the limits any time soon, especially since people are pushing 600whp + through the stock fuel system with just a pump upgrade. |
fsugatorbait257.00 janea120728.50 |
01-13-2020, 05:44 PM | #47 | |
Rep 413
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
kern4174446.50 |
01-13-2020, 10:00 PM | #48 |
Rep 299
when would upgrading the pump be needed?
im just thinking stage 1..downpipe, intake and a flash. do i need one?
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
01-14-2020, 06:04 AM | #50 |
Rep 31
01-14-2020, 06:29 AM | #51 |
Cheapskate
4447
Rep 4,993
You don't need it for any OTS map. I'd even go so far to say those that have experienced fuel pump crashes on OTS maps should investigate other failure modes before upgrading pumps.
Our biggest hurdle is boost spikes and throttle closures, and those tend to create more fueling issues than the tune itself. Our crappy wastegates can't seem to control boost well on a lot of cars, and fixing that would allow you to make the same power without hitting fuel limits. If your tune is calling for 16-18psi and you're hitting 20, then that is your problem. The pump just compensates for crappy boost control. It's only needed if you want a custom tune to run more boost or higher ethanol content. |
fake_bimmer6.00 |
01-14-2020, 02:23 PM | #52 | |
Rep 643
OR, are you instead saying that 20psi overshoot is the limit? |
01-14-2020, 03:45 PM | #53 | |
Cheapskate
4447
Rep 4,993
it's simple in theory. Just target a boost pressure that's 1-2 psi below that threshold and send it. But for whatever reason, our car says fuck you i'm going to hit your target +2psi anyway. So then your boost goes over target and the throttle angle closes in an attempt to bring boost back in check. If you're already operating near the fuel limits, that also translates to hpfp pressure dropping because now the airflow is above the hpfp capability. it's doing exactly what it's supposed to do to protect the engine, but there's no good reason why it should need to "protect the engine." but our wastegate sucks, so the DME has to work overtime and pull throttle to keep things in check. Over time I'm just seeing how lacking the system is. It works ok, but there's a lot of room for improvement. We've been experiencing throttle closures since the JB4 days and to be frank OTS tunes haven't fixed it. Everything runs smoother but throttle closures are still very common. I even see throttle closures when logging my stock tune, though it's minimal. |
01-27-2020, 09:21 AM | #54 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Just completed my B58TU pump install yesterday using this DIY and it went down exactly as advertised. Everything was very smooth except the fuel rail connection. You will need to carefully make some bending adjustments to get it to mate up with the new pump outlet. It's only off about 3%, but you want to make sure it mates up perfectly to avoid crossthreading the nut.
Thanks again kern417
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
kern4174446.50 |
01-27-2020, 02:26 PM | #55 | |
Rep 135
B58
01-27-2020, 02:56 PM | #56 |
Rep 684
No, I purchased the extender from BMS and cut about 1" of material out from the heat insulation foam to accommodate where the electrical connector sticks up. I don't know why anyone would bother trying to turn or modify the pump, they're solving a problem that IMO doesn't exist.
2020 X3M
01-27-2020, 06:49 PM | #57 |
Rep 210
So with the upgrade pump do i choose XDI Pump when flashing MHD?
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
01-27-2020, 06:58 PM | #58 |
Rep 684
I contacted MHD and asked if they have any support for the HDP6 and here's the response I got:
Hello Martial. I am a current MHD user, B58 stage 2 E30 map. I have just installed the upgraded B58TU fuel pump (Supra pump). Do you plan to provide an option for customers with support for this fueling upgrade? Hi, the pump works plug and play if you want more power then you need to order a full custom tune. Best regards Momir
2020 X3M
kern4174446.50 |
01-27-2020, 07:02 PM | #59 |
Rep 210
Gotcha so not exactly PNP
01-27-2020, 08:32 PM | #60 |
Gettin It Figured Out
1820
Rep 2,669
What part of "...not exactly PNP" are you referring to? .
01-27-2020, 09:53 PM | #61 |
Rep 210
pnp as in get the benefits of the supra pump. Has to be custom tuned
01-27-2020, 10:17 PM | #62 | |
1820
Rep 2,669
I'd say that's pretty PnP .
kern4174446.50 |
01-28-2020, 06:09 AM | #63 | |
Cheapskate
4447
Rep 4,993
*POTENTIALLY* tuners like BM3 and MHD will make a high output map for people that have fuel pumps. But don't expect it any time soon. |
03-23-2020, 04:02 AM | #64 |
Rep 9
I just got my upgrade pump and had a look at the connector issue. It seems it's just fixed my pressure. There is a weld point holding it together. Likely it can be easily turned when you open it but I don't think the UK eBay guy did that. Likely it can be turned by some force if you have a tool to firmly hold it. Unfortunately I don't have the necessary equipment.
Did anyone else made progress? |
05-01-2020, 05:08 PM | #65 | |
Rep 1,597
05-01-2020, 08:46 PM | #66 |
Rep 949
The TU is a great option IMHO because it's a factory part so you know it's going to last. The aftermarkets are still unproven at this time. So far on our Z4 no issues supporting straight E85 on the factory turbo up to 500whp and I'm sure it will support a lot more than that. BMS has them in stock and ready to ship with the adapter if anyone needs.
