01-20-2020, 05:28 PM | #45 |
Rep 288
01-20-2020, 07:57 PM | #46 |
Rep 1,934
Welcome to the club
mcintoshf30184.00 |
01-20-2020, 08:15 PM | #47 | |
Rep 288
01-20-2020, 08:41 PM | #48 | ||
Rep 1,934
I had very little time with it on summer tires, and out of the break in period, before having to put dedicated winters on.
01-22-2020, 07:22 PM | #49 | |||
Rep 288
01-22-2020, 07:27 PM | #50 |
Rep 1,934
It's mechanical so there's no interfacing with any of that. No coding possible or necessary.
Lock up in every mode.
01-22-2020, 08:22 PM | #51 |
Rep 288
I understand that but if I'm in sport DTC will cut power when there's loss of traction, so then both wheels would immediately lock up but then unlock as throttle dies down ?
01-22-2020, 08:24 PM | #52 | |
Rep 1,934
02-05-2020, 07:54 PM | #53 | ||
Rep 288
02-05-2020, 08:00 PM | #54 |
Rep 1,934
Nice to hear. I have yet to turn off xdrive and it's still pretty apparent something is happening back there.
02-05-2020, 11:34 PM | #55 | |
Gettin It Figured Out
1820
Rep 2,669
That's what she said... .
02-22-2021, 01:07 PM | #56 |
Rep 468
Sorry to revive old thread but need some help on how to remove the prop shaft.
I also have a leak in my diff on one shaft and I managed to pop the half shaft out using pry bar but im struggling with the 50mm nut on the propshaft. I guess the easiest option would be to undo the three bolts holding the propshaft and just lower the diff then but BMW says no to do it as it will upset the propshaft balancing. The 50mm sunk nut is unbelievable tight and I dont know how to lock the shaft to get a good grip at it. Thanks |
02-23-2021, 07:44 AM | #57 |
Rep 1,109
Drives: 2015 BMW 435i Xdrive MSport
Are there any M Performance LSD's even floating around anymore these days?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
02-23-2021, 01:09 PM | #58 | |
Rep 5,391
An experienced dealer or specialty shop charges about $560 to swap an F3x differential. The E-Series were a lot easier because driveshafts had a bolted flange that was easy to do. F-Series has circlips that fit into a groove to hold it onto the differential. That's why the special tools are needed. F-Series is not very old so not many mechanics are experienced swapping the differential. So they say that they can do it, assuming that it's easy like the E-Series. Then they get the car up on their lift and say "Oh, sh*t!" They don't have the correct tools so they try to rig it and risk buggering it up. Don't let anyone do your F-Series differential without questioning them about their F-Series experience and having them show you the tools |
Poochie9103.00 |
02-23-2021, 01:13 PM | #59 | |
Rep 5,391
https://www.getbmwparts.com/c-differentials-92 |
02-23-2021, 03:42 PM | #60 | ||
Rep 1,109
02-23-2021, 03:49 PM | #61 |
Rep 7,591
There are a few companies where you can get one built to order with various types of internals depending on what type of LSD you want and how aggressive you want it to be. Forgot the main company, it was linked in one of the threads.
02-23-2021, 04:32 PM | #62 |
Rep 1,109
I'm guessing Diffsonline.com?
02-23-2021, 05:56 PM | #65 | |||
Rep 5,391
02-23-2021, 06:21 PM | #66 |
Rep 1,109
I'll probably end up with a Wavetrac unit.
