01-14-2020, 06:51 PM | #1 |
follow my instagram @bimmer_6uy
Rep 96
f30 suspension parts for sale
https://drive.google.com/open?id=1RY...z8DRLV2DMjp2Qu BC coilovers 6k Front & 12k Rear Spring Rate V-Barrel front & Linear rear springs30 Levels of Simultaneous Compression and Rebound Dampening Extreme Drop version allows additional 1-1.5" lowering over the standard 2-4" lowering from traditional BR suspension kits Shocks are 1" shorter in length and springs are specifically selected for greater lowering capabilities can fit the following models F30 320 328i 330 335 340 I have a few hundred miles in these coil overs still in superb condition. front lower control arms The same control arms found on the M3! Adds -0.5 degrees of camber for improved response and handling. Kit replaces both front rear arms and headlight level sensor. can fit most f22 f23 f30 f32 f33 f36 models The right amount of camber in the front gives it that very settle stance look. Tuner spherical mounts for rear Eliminates bushing deflection for improved shock efficiency and direct connection with the road. Stronger than OE design for a long life, even with stiffer shocks. compatible with all platforms including M3, M4, M2's These work phenomenal for that improved shock absorption and makes it a lot more smoother.
01-14-2020, 07:07 PM | #2 | |
Rep 919
Drives: F30 328d Sport Line
01-29-2020, 10:38 AM | #7 |
Rep 96
Hey, the suspension does not fit the x drive chassis. I am now selling the system for 700$ but shipping must be covered by the buyer.
