12-10-2016, 07:33 PM | #1 |
Rep 1,398
2012 F30 AC Compressor is not functioning
Hello Guys,
My best friend having some problem with the AC. I told him to come to me for ISTA scan. I did it and I got 2 error according to the AC Compressor : There was test plan but I could not find any solution or I did not get what exactly saying. I would like to share the symptom maybe you guys can help me out. TITLE : Functional check, noise, smell ABL : Heating and Air conditioning functions : Refrigerant circuit check, noise, smell Detail : 80436E compressor clutch : Break in wiring or short circuit to B+ System Check : B7F8B8 Connection between headunit and Bluetooth aerial foot : open circuit Car is 76k miles on odometer. I will appreciate any help. Thank you!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
08-13-2021, 02:16 PM | #3 | |
Rep 3
I installed a new head unit and i am thinking that is either causing the issue or i pinched/damaged a wire at some point. voltage at compressor electrical connection is reading 10-12V but clutch wont engage. |
11-21-2021, 07:32 PM | #4 |
Rep 2
AC compressor clutch not working
I have a 2015 320i and I was driving the other day and noticed the AC wasn't blowing cold. I checked 134a levels was good and I checked all fuses, does anyone know how I can test the clutch or anything else I can do to fix this issue. please help. thank you
11-21-2021, 08:31 PM | #5 |
Rep 1,398
If your ac doesnt blow cold air, compressor doesnt kick in probably or you are low in freon. How did you read the freon level? With pro tool?
