06-04-2021, 09:46 PM | #3719 | |
Rep 176
you can't. as soon as you change the settings for the downpipe its not the stock tune anymore. The tune has to be 100% unchanged to lock the DME.
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
n55david1301.50 |
06-04-2021, 10:16 PM | #3720 | ||
1302
Rep 3,550
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
Kolianovskyi87.00 |
06-04-2021, 11:30 PM | #3721 |
Rep 381
06-04-2021, 11:45 PM | #3722 |
Rep 176
No, Your car needs to have the DME relocked in order to transfer the license.
Kolianovskyi87.00 |
06-05-2021, 06:17 AM | #3723 |
Rep 381
Thank you. So how and what can I do in order to fight potential CEL because of catless downpipe and being able to sell license?
06-05-2021, 12:01 PM | #3724 |
Rep 780
Eschmacher334.50 harkes1090.00 |
06-05-2021, 07:41 PM | #3725 | |
1302
Rep 3,550
imperfectluck434.00 |
06-14-2021, 05:32 PM | #3726 |
Rep 44
Another question about knocks...
I have an EWG with Wagner catted downpipe, Evo 2 comp cooler and upgraded chargepipe. I'm in Scandinavia and I'm fueling up with Shell Vpower 98 RON (also did when the car was stock). E85 is not available here anymore. Initially I flashed the BM3 stage 2 93 OTS map. Some logs looked great, some looked not that great with timing pulled and knocks detected. Some examples: https://www.bootmod3.net/log?id=6085...0b43386e5ab211 (good) https://www.bootmod3.net/log?id=60ad...0b4341fb952b8a (less good) I switched to the stage 2 91 map, datalogged a few runs and PTF adviced me to stick to the 91 map. That's fine, but even on the 91 map with 93 (98 RON) fuel I'm getting knocks: https://www.bootmod3.net/log?id=60c7...729b675f868e98 This one has two knock events on full boost which worries me. The plugs are recently changed OEM's with stock gap. Could the Shell fuel be my issue even on the 91 map? Or something else? I've read through thejeremyman9's "how to" thread several times (thanks dude!), and I can't find other issues in my logs. IAT looks fine. Only thing I've noticed is the WGDC in higher RPM's, but I've read that's common for the 7.1 maps. (Sidenote - from what I've seen the knocks are mostly ocurring when starting from low RPM in 4. gear (logging situations). I'm pretty sure I can feel slight hesitations when timing is being pulled. In more normal WOT situations it pulls pretty strong and feels consistent, and I have not seen knocks on full boost.) |
06-14-2021, 05:44 PM | #3727 | |
1302
Rep 3,550
06-14-2021, 06:00 PM | #3728 |
Rep 44
06-14-2021, 06:45 PM | #3730 |
Rep 44
That’s an option if the issue is octane related. It’s also possible to buy barrels of E85 for race fuel, I just need to find somewhere to store it as I live in an apartment block with shared parking space.
06-14-2021, 07:01 PM | #3731 | |
Rep 7,624
1. Try ACN map. Drive 50+ miles for adaptations (and/or reset octane one in particular), then get three 4th gear logs on the same tank of gas. 2. Try getting three 4th gear datalogs on a new tank of gas still on the 91 map 3. Try a "real" octane booster and see if the knocks go away and/or timing improves. 4. On either 91 or ACN map if you are still getting knocks (without octane booster) in 4th gear pulls, try a few 1-4 gear pulls (from standard start to top of 4th) and see if you knock. You dont need to use launch control or anything. just floor it from a stop. |
06-14-2021, 08:17 PM | #3732 |
1302
Rep 3,550
it might be. that's why that map exists for the US. some places have really terrible fuel
Possessed13.50 |
06-15-2021, 03:30 AM | #3733 | |
Rep 44
06-15-2021, 06:54 AM | #3734 | |
Rep 19
Drives: BMW X3 M40i 2018
How to reset only the Octane Adaptations? I've been using the bm3 and the option I have is "Reset Adaptations". If I reset Octane Adaptations, for how long I need to drive before logging? |
06-15-2021, 11:02 AM | #3735 | |
Rep 44
06-15-2021, 11:29 AM | #3736 | |
Rep 7,624
JP.BSB9.00 |
06-17-2021, 09:23 AM | #3737 |
Rep 381
Folks! Is it possible to change a VIN under same account/email address? I mean, if I sell a license via transfer, there would be a new email address for another guy, maps would not be transferred.
But, if I can change vin in my account I could give that account with reseted password to another guy and he might use maps as well. If I sell a license via transfer, what will happen with my account? If I want to buy another license for another engine, will I lose my map pack? |
06-17-2021, 11:24 AM | #3738 | |
Rep 90
06-17-2021, 05:24 PM | #3739 | |
1302
Rep 3,550
06-17-2021, 06:34 PM | #3740 |
Rep 381
