06-04-2020, 02:03 PM | #1 |
Software Engineer
229
Rep 60
Drives: 2020 C8
Clockspring has been replaced twice now, light came back on...
When I purchased the car a year ago, the driver restraint malfunction light came on, took it to the dealer, they replaced the clock spring and everything was good... Few thousand miles later, it came back on, and I replaced it myself.
Now 2,000 miles later, it just came back up while making a turn and I assume I'll have to replace it again... WHY would this be the third time this has happened now? Could it be an underlying issue? Any help is appreciated...
E-SYS Bundle with working .EST token and loader: bmwtune.org/coding Last edited by brandonf30; 06-04-2020 at 02:44 PM.. |
07-22-2021, 05:25 AM | #2 | |
Rep 14
07-22-2021, 07:40 AM | #3 |
Rep 16,081
07-22-2021, 11:43 AM | #4 | |
Rep 14
07-22-2021, 02:12 PM | #5 |
Car Hypochondriac
335
Rep 901
I believe it's referring to the explosive in the airbag. Perhaps check to see if the connector on the airbag is dirty or making poor connection? Otherwise, perhaps you need a new airbag, not an SZL?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-22-2021, 02:46 PM | #6 |
Rep 14
Just checked the connections! Took out the airbag but i was not able to take the actual harness connected right at the airbag out. Still pushed in that connection and reconnected battery. The fault code went from permanent to intermittent! Cleared it and hopefully it stays gone! Thanks for the suggestion!
