07-12-2021, 09:54 AM | #1 |
Rep 1,487
Ceramic Coating
Hi all
I’m going to get the M5 detailed which will consist of a 2 stage polish and I’m wondering whether ceramic coating is worth while? The detailer uses Gyeon products which appear pretty decent but never having had a ceramic coating not sure whether it’s worth it….??? Opinions welcomed! |
07-12-2021, 10:04 AM | #2 |
Rep 5,681
My only comment is you need to be clear what you want/expect a ceramic coating to do; if your main goal is to make the car easier to wash then yes they work but if you're hoping they're going to prevent swirls and scratches you might be disappointed. Furthermore, if you're the sort of person who's likely to be bothered by aforesaid swirls and scratches you also need to be aware that getting the paint back to standard is less straightforward - and hence more expensive - than with a conventional wax. Obviously how much the ceramic coating is going to cost and how long you intend to keep the car also comes into it as well!
Have a read of the thread below which includes the opinion of an experienced detailer.... https://f87.bimmerpost.com/forums/sh....php?t=1590057 |
07-12-2021, 10:07 AM | #3 |
Rep 421
Drives: 2017 F31 328dx
I've had 3 year ceramic coating on my car for 3 years. If you hand wash your car regularly I highly recommend it. It'll cut your wash time in half, it'll make normally hard things to get off like bug guts and bird turds easy to take off. After a wash the car looks like you spent 3 hours alone in waxing. I've had a thick layer of pollen just fly right off on a drive. Having said all that, you do have to wash the car regularly. A quick dip into a touchless car wash is good but a really good handwash and dry will look amazing.
It's not going to protect your car from rock chips or major scratches but it will help with swirls but it's by no means a be all end all and you have to have a good washing technique. There are self-healing coatings that on a hot day and in the sun will heal itself. If I was to go back to the beginning with my car I would have put a paint protection film on it and ceramic coating. |
07-12-2021, 12:03 PM | #4 | |
Rep 5,681
This is probably the best solution if you want protection from scratches and swirls as well as a car that's relatively easy to keep clean - comes at a price though! |
07-12-2021, 12:45 PM | #5 |
Rep 12,248
I have had my last three cars done. I havent kept any for particularly long and only had the Crystal Serum light not the professional stuff but for a few hundred quid on a car that costs a lot more than that they are worth their money for helping it stay clean longer, helping the man who applied it come and do the maintenance washes and providing some protection from swirls and damage.
I'm not in the OCD class though when it comes to paint, its a car and it sits outside all the time..... But to me well worth it.... |
07-12-2021, 01:01 PM | #6 |
Rep 3,966
I've had it done professionally on two cars, a 5 and a 4 series. The last time, the detailer used Kamikaze products and the results on Carbon Black were impressive.
I have had two cars since and haven't bothered with either. Admittedly, neither are what you'd called premium. Instead, I've prepared the paintwork to a reasonable standard when new and applied Gtechniq C2V3 sealant. A budget approach but its worked just fine. The cars have been easier to wash as a result, and the paintwork has always looked good. The sealant can be reapplied from time to time. Nothing truly protects the top coat from swirls, chips etc unless you apply film, which I've never even considered, tbh.
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
MashinBenzin8454.50 |
07-12-2021, 02:06 PM | #7 | |
Rep 5,392
07-12-2021, 05:18 PM | #9 |
Rep 1,158
If you fancy maintaining your own car like I do - I enjoy the process of a polish and wax every 6-8 months then don't.
If you prefer to let it sit for a month without a wash and then spend 30 minutes washing it, then a coating is worth it as it'll keep it in top condition. Armaan |
07-13-2021, 12:51 AM | #10 | |
Rep 8,780
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
07-13-2021, 02:35 AM | #11 | |
Rep 12,248
Armaan714.50 |
07-13-2021, 03:05 AM | #12 | ||
Rep 1,158
Armaan |
07-13-2021, 02:09 PM | #13 |
Rep 5,681
07-13-2021, 02:40 PM | #14 | |
Rep 3,966
The best I think it can do is to give your paintwork a deeper shine as the topcoat gets polished and if done well, ends up near perfect, making it easier to wash and making water bead more readily. It's a myth that it "protects" your paintwork against chips, scuffs and blemishes though. Film over the topcoat is the only thing which can do that.
JNW13122.00 |
07-13-2021, 03:00 PM | #15 | |
Rep 1,487
07-13-2021, 03:15 PM | #16 | |
Rep 12,248
In the scheme of how much the car cost, and assuming you dont love washing and polishing your own cars, for me its a no brainer these days.... |
07-13-2021, 03:43 PM | #17 |
Rep 2,192
Interesting, I spent >£500 on getting the mrs black GLC coated. I was very impressed with the correction detailer did in removing swirls but slightly disappointed with the ceramic coating itself. Was prone to water marks etc.
I use Gyeon wet coat on the other cars and subjectively they stay clean just as long and are just as easy to clean etc. I’m unlikely to do another unless I do a light version myself , maybe TAC moonlight I’ve been wanting to try . Coatings still require a bit of maintenance with a topper detailing spray to retain the water repellency etc…
M3 CP in THE fastest colour (says so in the title )
JNW13122.00 |
07-13-2021, 04:35 PM | #18 | ||
Rep 5,681
But as I said earlier, my view is probably influenced by the dark colour of my car - Mrs JNW1's Mini was done with Gyeon from new and any marks on her (Melting Silver) car are much less noticeable. However, I'd also say that after two years it's definitely in need of a top-up as the hydrophobic properties have now reduced significantly compared to when the coating was first applied. |
07-13-2021, 04:46 PM | #19 | |
Rep 12,248
07-14-2021, 03:21 AM | #20 |
Rep 8,636
For easy washing get one of these:
https://www.vyair.com/en/0817-high-p...city-blue.html One of the best things I've bought for car cleaning, hose off the car in full sun, no microfibre needed, just drys without any water spots! (Don't get Raceglaze, they are just rebranded Vyair ones for a lot more money!) |
JNW13122.00 |
07-14-2021, 12:25 PM | #21 |
Rep 3,432
I think the ceramic coatings (with hydrophobic top coatings) make most sense if you are not a regular cleaner/detailer of your cars... as they protect the underlying finish from the fall out and dirt...
For me, the Golf was the first I had done and I got it done specifically because I knew it would spend longer periods dirty and so I wanted something to protect the underlying paintwork from degrading because of that and the coatings fitted that bill exactly... It's a £500 job up here to have the car machine polished with the coatings.. including protection for wheels and interior... that is for GTecnique (sp?) products with a 5 year life... I either cleaned it by hand (now and again) or took it back to the detailers for a wash... Avoiding roller washes etc helps prevent surface damage/degradation of the coatings..,.
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
07-14-2021, 12:49 PM | #22 | |
Rep 5,681
