BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 Changing Gearing - Coding required?
proTUNING Freaks
      03-16-2019, 11:00 AM   #1
VAF30
VAF30's Avatar
Drives: 14' F30 335i
Greetings...
Time to look at LSD Diffs .. and since my car.. 2014 335i 8AT is factory at 3.15 in the diff.. if I change to 3.45 or so is there any coding required in the engine or tranny or? to support the diff gearing change?
Thank for the assist!
      03-17-2019, 12:20 PM   #2
VAF30
VAF30's Avatar
Any thoughts out there?
      03-18-2019, 08:44 AM   #3
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
I haven't seen an option/solution to change the rear gear ratio. Probably best to ask the people selling it to you what they recommend. Might not have to do anything ?
VAF3025.50
      03-18-2019, 05:21 PM   #4
doodlebro
Drives: '17 X3 35i
Definitely going to need it for the speedo to read right.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
VAF3025.50
      03-18-2019, 05:27 PM   #5
bradsm87
Australia
595
Drives: F25 LCI xDrive30d
There are settings in both the DME and TCU ROM for final drive ratio. I don't know how important/necessary they are though.
VAF3025.50
      03-20-2019, 12:18 PM   #6
VAF30
VAF30's Avatar
First -- Thanks for the input!!!
From what I have been able to learn.. for Manual cars -- no change in any SW .. bolt it in ang go.. no issues
For - Auto -- not recommended .. custom tuning can probably get around the change but both have suggested not too... I've got a reply from...
So looks like Ill be staying at 3.15 factory for auto unless I can find someone whos actually done it..
      03-20-2019, 04:11 PM   #7
XutvJet
Drives: 2011 Cayman Base, 2016 M235
Yeah, you'll need to keep the stock ratio. We recently had a guy on the 2 series forum accidentally install a M240 automatic LSD into his M235 automatic. The M240 autos use a taller 2.80 gear vs the M235's automatic 3.08 gearset and the DME and transmission computer were throwing speed errors on the highway and I believe shift timing was a bit off. He looked into coding, but he couldn't find a tuner capable of addressing the issue.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
VAF3025.50
