09-15-2015, 06:44 AM | #68 |
Don't care
117
Rep 224
Try selecting one of the other options until you find the one that will allow you to erase the fault memory error and still function. Difficult to tell without knowing all your options on the car.
Assuming you selected "erase fault memory" button below in between coding correct? Last edited by TMD29; 09-15-2015 at 07:31 AM.. |
11-20-2015, 08:22 AM | #69 |
Rep 16
Thanks for the helpful post
Followed all the steps and coded the rem but Can not find FEM_BODY / 3060 LCEMaster 1C / NSL_Verbaut = Verbaut Cannot see any NSL_verbaut under fem body 3060 Please advice how i can do this coding of fem body Last edited by sh2laba; 11-20-2015 at 09:44 AM.. |
11-20-2015, 08:45 PM | #70 |
Don't care
117
Rep 224
Try typing NSL_VERBAUT in the search function. It may be in another folder.
11-27-2015, 10:14 AM | #71 |
Rep 16
Tried searching NSL_VERBAUT in all folders and even in all CAFD and still can't find it .
My firmware might be old (never updated since 2012 ) so any other code at FEM BODY for older Firmware ? |
02-06-2016, 02:37 AM | #72 | |
Rep 246
I would use the latest files. I kept getting errors while using older files. Also, I also have found some functions are in different section folders. I just performed this tonight. It's super easy to remove the control unit itself. Literally took me 2 min. The hardest part would be removing the plastic tabs that prevent the button from moving inwards to activate the switch. The best method I came up with was using a very sharp box cutter. I was able to cut the pieces off clean from the button. Big thanks for the DIY |
06-09-2016, 02:32 PM | #73 |
Rep 39
I took a look at Ebay UK and saw that their headlight switches have both front and rear fog light switches and and extra rotating wheel on right side of switch, What is that for? What would it effect on USA and Canadian cars?
LittleSamurai4.50 |
06-10-2016, 05:22 PM | #74 |
Rep 1,113
I think the rotating wheel is for halogen headlights in Europe. It lets you adjust the height of the beam according to your overall load as to not blind oncoming traffic.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
06-18-2016, 11:50 AM | #76 | |
Rep 1,076
Rear fog lights REM / 3061 / NSL_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_IS_LED /aktiv REM / 3061 / NSL_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_IS_LED /aktiv |
06-18-2016, 02:56 PM | #77 | |
Rep 131
I haven't tried yet, i was only able to code FEM_BODY / 3060 LCEMaster 1C / NSL_Verbaut = Verbaut and since: REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_output = nsl_l REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_Function = nebelschlusslicht REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_output = nsl_l REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_Function = nebelschlusslicht is not available so i don't know how to code it for the lci rear fog light. thanks gabreigns...i will give it a try and see if it work and post here later |
06-20-2016, 12:28 AM | #78 | |
Rep 131
06-24-2016, 01:22 PM | #79 |
Rep 25
using this guide for "unlocking" the F/R fog light buttons, I was able to add BOTH to the wife's 2014 F30 Msport.
Some extra coding was needed to activate the L/R front fog channels on the FEM_BODY computer, but once done, the factory switch is now completely functional! Awesome thread, it inspired me to retrofit the fogs on the '14 msport f30. |
06-29-2016, 05:38 PM | #80 |
Rep 1,480
Drives: 2020 M340Xi (G20)
Hi,
I changed out the the lightswitch in my 2014 F30 for the European variation (BMW part: 61 31 9 265 303) that I got from ECS Tuning. I did all of the coding needed to activate rear fog and lights and switch worked fine; however, I also got an error in Rheingold, basically saying I had the incorrect light switch. To correct this, I was advised earlier elswhere in this forum to code the following: FEM_BODY> 3064 LCECONFIGURATION> LCE_BEL_LIN_VAR from BEL_FLC_NSW (4) to BEL_FLC_NSL (6) Having done that, however, I still got the same error in Rheingold. I noticed that there are a number of options that you can code for this function -- only wished my German was better. Perhaps someone can help Thank you very much
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
07-05-2016, 06:49 AM | #81 | |
Rep 524
EDIT: Looks like the coding should be: FEM_BODY> 3064 LCECONFIGURATION>BEL_FLC_NSW_NSL Last edited by hsk1610; 07-05-2016 at 11:13 AM.. |
07-06-2016, 04:15 AM | #82 |
Rep 1,407
everyone knows how to do coding, and im just here sitting on my ass scratching my head.. haha how did you guys all get started? i should probably look for a sticky on coding for the f30s.
Diligentia Vis Celeritas
07-06-2016, 07:12 AM | #83 | |
Rep 1,076
PM Shawnsheridan on this thread. Also the thread has information on coding and such. |
07-07-2016, 05:03 PM | #84 | |
Rep 1,076
07-29-2016, 09:58 AM | #85 | |
Rep 1,480
Oops, great catch -- pardon my typo error!
Al
07-29-2016, 10:04 AM | #86 | |
Rep 1,480
Well worth while! There are several threads elsewhere in this listing that are extremely helpful! As was stated contact ShawnSheridan for needed data (called PSdZData) & program (called E-Sys); then on another thread contact either TokenMaster or Almaretto to get a version of E-Sys Launcher which enables you to "understand" the data files -- since BMW has now elected to truncate them (they do not list names of functions and codes). Hope that helps!
Al
tmdals0213214.50 |
07-29-2016, 04:55 PM | #87 | ||
Rep 1,407
