BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > E85 vs Pump/Meth
proTUNING Freaks
      09-10-2019, 10:17 AM   #23
Solid67
Drives: 2019 M240i xDrive MP Edition
I ended up pulling the trigger on the Fuel-It CPI kit and Split Second AIC1 controller. I'll make a new thread once its installed and I get my custom E85 tune from F80Paul.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
B58togo808.50
      09-10-2019, 12:25 PM   #24
Relique
Drives: 2018 440i GC xDrive
Nice. Please post impressions and dragy
2018 440i GC xDrive | M Sport | AA Catted DP | AP Intake | B58TU HPFP | Pure800 Turbo | BM3 Flex Fuel Kit | E50 Tune by Performance Eurowerks
      09-10-2019, 12:50 PM   #25
Fuel-It!
Drives: M4, M5, M2C, X4M, 440i, etc...
Solid67187.00
      09-10-2019, 02:22 PM   #26
bacon_45
Drives: 2018 340i BM3 FBO
If you can post the process, that'd be super helpful. I want to go the same route, I have a custom tune from Jordan.
      09-10-2019, 02:29 PM   #27
Solid67
I'll try my best to detail the install process.
      09-10-2019, 04:04 PM   #28
Relique
Do you mind sharing the price for the custom tune? Would also love to see the progress. Thanks a lot Solid67. Hope you get some kick ass power and everything goes smoothly. Best of luck
Solid67187.00
      09-10-2019, 04:17 PM   #29
Solid67
Check your DM!
      09-10-2019, 04:25 PM   #30
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
I hope this goes well and I'm really looking forward to hearing about the process and results. There seems to be no other cars with this set up at the moment, or if there are no one is sharing the info.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
Solid67187.00
      09-10-2019, 04:33 PM   #31
Relique
Yes. Sounds like they had some customers but none of them are forum posters. I feel like once we get a couple of impressions this will really take off. I know a lot of us are waiting with an itchy trigger finger. Really want to get this setup. Straight E85 is just so much easier to deal with than the other options.
      09-10-2019, 04:34 PM   #32
Solid67
I hear you on that and thats the reason I bit the bullet and got the CPI kit.
Seen plenty of pump/E85 blends with meth, but none has run full E85 with a system that could handle it. That's why I am very excited to see what full E85 will do.
      09-10-2019, 07:18 PM   #33
B58togo
Drives: M240i
I wish I had some e85 stations closer to me. As it stands, I bought 12 VP Racing jugs and I make the trek to put four gallons in each one every 5-6 weeks, so I can at least run e30.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      09-10-2019, 07:58 PM   #34
Solid67
How far is your station? I am basically doing the same thing. Closest E85 station from me is 30 minutes, but I figure going there once every 3-4 weeks should be good enough.
      09-10-2019, 08:00 PM   #35
B58togo
Drives: M240i
An hour away. I get some curious looks with all the pretty colored jugs lined up on the ground. And then a couple weeks ago, at a local gas station, I was fillng my tank with one of the jugs and some girl in a Jetta was amusingly recording me. Maybe she just thought I was hot, I’m not really sure.
      11-06-2019, 11:05 AM   #36
Goga
Drives: 2018 BMW 340i X-Drive
How is your experience so far running the cpi kit with an aftermarket charge pipe?
I am looking to do the same, but when I reached out to fuel-it they told me "The CPI injector needs to be as far from the throttle body as possible hence the billet coupler we offer for those kits. Mounting the injector too close to the TB will cause poor distribution."
Also, if that is the case, than how does the WMI Kit that is mounted even closer work great?
Does anybody know anything about when the XDI pump is coming out and if its worth the wait?
Thank you
      11-06-2019, 12:04 PM   #37
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
Thank you
no matter what you don't want to spray right on the throttle body. But it depends on how much you're flowing and what type of fuel. water meth will atomize faster than pump gas, so there's less risk. however if you're running higher meth percentages, then the risk of damaging something goes up and it becomes more corrosive.
For meth, the throttle body spacer is your best option. it sprays right after the throttle body.
Youtube/Instagram/TikTok: @kern417
      11-07-2019, 10:28 AM   #38
Goga
I want to run E40-E60 on a daily tune and get a custom map from f80paul for ms109. CPI is probably my best option just want to see how it runs with an aftermarket charge pipe. However, with the xdi pump coming out soon I might wait to see what kind of results it has.
      11-07-2019, 11:59 AM   #39
kern417
Cheapskate
4447
A couple things
E40-E60 will have better performance than MS109
You don't need fuel upgrades to run MS109
It will run the same with or without the stock charge pipe. You can even tap the manifold and install it there if you want.
      11-19-2019, 08:52 PM   #40
lonewolfB58
lonewolfB58's Avatar
Drives: 2016 340i xDrive msport
Snow performance meth kit!?
Has anyone heard anything from the Snow Performance Meth kit for the B58 It has a separate reservoir that runs off this “Boost Juice” but I’ve seen one installation where a guy just tapped into he windshield washer reservoir and would just use the icon on the dash when running low! Honestly cool setup & good results on his behalf! I was curious into taking that route!?
      11-19-2019, 09:38 PM   #41
mitchellm
Drives: bmw 340i x drive
I have WMI with an FTP charge pipe using an ofset coupler for the BMS adapter. I've been playing with e40-e50 in the fuel tank and X98 in the meth tank. I have a PS2 and got my 1st throttle closure at 75add (around 24psi). I'm going to change to the CPI kit but need to fabricate a new bung for the FTP charge pipe. I'm done with filling up the meth tank. Would be great to hear if anyone has used straight e85.
2016 340i M sport
      11-20-2019, 06:05 AM   #42
kern417
Cheapskate
4447
I will be next year, but no one has reported results of a full E85 tune yet. Some people are working on it though.
