06-16-2018, 09:32 PM | #1 |
Noob
35
Rep 58
Anyone else have their TMAP sensor die as a result of a CP failure?
Just had a VRSF CP and FMIC installed after having my stock CP explode on me. Had a local BMW shop do the install and I now have the following 3 codes being set:
108A01-Charge air temp sensor, electrical:Short circuit to B+. 120408-Charging pressure control:Switch-off as consequence. 121001-Charging pressure sensor, electrical:Short circuit to B+. Shop says that the TMAP sensor most likely was damaged during the process of the CP blowing. Car is holding boost but is in a reduced power mode and showing the much loved "Drivetrain Malfunction" warning upon startup. Searching here and Googling elsewhere all point to a TMAP sensor or harness issue related to those codes above. The harness looks physically fine and I'm unsure how to test it other than with visual inspection. I have ordered a new TMAP sensor which will arrive Monday - damn sure hope that replacement will cure my ills. My main question is if anyone else had to replace their TMAP sensor as a result of their CP failing? |
06-17-2018, 04:17 AM | #2 |
Rep 216
Drives: F30 335i PWG
Do you have a jb4, as it might be the short circuit issue ?
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
Just Ask35.00 |
06-17-2018, 04:33 AM | #3 |
Noob
35
Rep 58
06-17-2018, 05:10 AM | #4 |
Rep 216
Well in that case have you tried reading and clearing the codes through the MHD app, also do you have access to ISTA/d and an enet cable by any chance?
06-17-2018, 09:30 AM | #5 |
Noob
35
Rep 58
i have read and cleared the codes utilizing the MHD app, only to have them instantly reappear upon restarting the engine. I do not have access to ISTA, unfortunately.
06-30-2018, 01:38 AM | #7 |
Noob
35
Rep 58
Update - Replaced the TMAP sensor in the CP and it had zero effect - same three codes still pop up. If I assume the new TMAP sensor is good, then I am left with trying to diagnose connectivity between the TMAP harness and the DME. Any ideas on how to do this?
I also switched the TMAp sensor in the CP with the MAP sensor in the intake manifold as they are the same part number; no change in codes so then I can assume that both sensors are good and the issue lies elsewhere. Any advice on what to do at this point? Last edited by Just Ask; 06-30-2018 at 05:50 PM.. |
06-30-2018, 10:07 AM | #8 |
Rep 142
I find it funny that everyone and their mothers jump on "Oh it's jb4 issue" for whatever issue nowadays.
Awaiting for "your car is low on air? Check JB4..."
02AccordV6(sold) 03350zMT(sold) 04E46///M3MT(sold) 06RSXauto(sold) 07G35auto(sold) 2014F32bmw435MT 2017MacanGTS
06-30-2018, 10:27 PM | #9 |
Rep 625
06-30-2018, 11:27 PM | #10 | ||
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
Just Ask35.00 |
07-01-2018, 12:58 AM | #11 |
Noob
35
Rep 58
07-01-2018, 01:51 AM | #12 | |
Rep 10,473
Have you set back to stock? |
07-01-2018, 02:08 AM | #13 |
Noob
35
Rep 58
Ah, OK, thank you. Clarity for me comes in waves at times...lol. What is the first step in obtaining/using ISTA?
No, I have not tried that. Will do so later today and see if that helps at all. I have tried loading a different octane map from the Stage 1 choices with no change in codes but maybe jumping back to the stock map will be different. Worth a try for the small time investment! |
07-01-2018, 02:18 AM | #14 | ||
Rep 10,473
Just Ask35.00 |
07-01-2018, 02:26 AM | #15 | |
Noob
35
Rep 58
07-01-2018, 03:05 PM | #16 |
Noob
35
Rep 58
Although I don't have ISTA yet, I just realized that I received an ISTA printout at the time of install generated by the indy BMW shop. Codes are as follows:
108A01-Charge air temperature sensor, electrical:Short circuit to B+. 121001-Charging pressure sensor, electrical:Short circuit to B+. These are exactly the same as what MHD indicates (the 120408 code comes and goes). i also remapped to Stock map and no change...same codes. Last edited by Just Ask; 07-01-2018 at 04:23 PM.. |
07-02-2018, 09:47 PM | #18 |
Noob
35
Rep 58
I tested for continuity by grounding the black/yellow TMAP wire to 4 different points on the frame....no continuity at all. Then I also tested for voltage by running multimeter between the black/yellow TMAP wire and the positive terminal in the engine bay...zero voltage. I then left the TMAP harness disconnected and used MHD to clear and read the newly generated codes. Same codes appear regardless of whether I have the TMAP harness plugged in or not plugged in, so it appears that wiring is the culprit. Should I try the JB4 ground "fix" by directly grounding that black/yellow TMAP wire?
07-02-2018, 10:27 PM | #19 |
Rep 558
haha - that was risky trying to test for +voltage that way. I would posi-tap the blk/yellow wire to ground then plug in the tmap and see. Doesn't hurt.
For your information, my tmap sensors are enroute. Couldn't wait so i decided to ground the black/yellow wire today. Drivetrain malfunction went away as soon as I turned on the car. I was able to finally clear the 2 codes with ISTA and they didn't come back after a drive. BM3 software came alive! Oh yes - exJB4 user here. Not going to say anything about that. |
07-03-2018, 06:26 AM | #20 | ||
Noob
35
Rep 58
