06-11-2018, 10:47 PM | #23 | |
Rep 134
06-15-2018, 11:19 AM | #24 |
Rep 134
Anyone else have any insight? Is this just a shit map from BM3 for my ROM version? I have seen others having problems with BM3 shuddering above 5k rmps. I need to find a resolution to this
06-15-2018, 11:43 AM | #25 |
Rep 1,499
Did you open a support ticket with PTF?
06-15-2018, 11:49 AM | #26 |
Rep 134
06-15-2018, 11:53 AM | #27 | |
Rep 1,105
Good luck my friend
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
06-15-2018, 12:51 PM | #28 | |
Rep 1,541
This is just to see if your HPFP #'s increase. They should, if not then something with your pumps is probably causing your issue. The tricky part would be figuring out if it's your HP or LP pump. Maybe both, but unlikely.
07-05-2018, 07:00 PM | #30 |
Rep 134
Just updating the thread for anyone whos curious, Stage 2 LPFP seems to have sloved the problem.
I had the updated fuel pump from the recall and it seems it was the culprit |
Anthony235715.00 Lancelot572.50 |
07-05-2018, 08:01 PM | #31 |
Rep 10,473
07-05-2018, 08:13 PM | #32 |
Rep 606
Oh man, I'm getting ready for stage 2 BM3, hope I don't get the same issue with my updated stock LPFP
07-06-2018, 12:37 AM | #33 |
Rep 560
Can you give link to place and part# where you got the stage 2 lpfp? Can we see new logs compared to your old logs?
07-10-2018, 10:17 AM | #34 |
Rep 1,541
log?
07-10-2018, 10:49 AM | #35 | ||
Rep 134
http://www.bootmod3.net/log?id=5b2efc8ed10b430873d73ef3 The original logs should be in the OP. You could see the HPFP pressure seems to keep up now. Timing doesn't seem to be consistent among the the cylinders in this log though, any possible reasoning for this? |
07-10-2018, 12:11 PM | #36 |
Rep 937
07-11-2018, 09:11 PM | #37 |
Rep 72
This is really helpful. I just upgraded from the Active Autowerke Active 8 (piggy back) to their flash tune. Loaded their stage 2 map for 93 octane (I have fbo 2015 335) I noticed a shutter at wot above 5k rpms. I have 55k miles on the car and never had any issues until now. Sounds like it could be the same issue as OP but I can't do any data logging with the Active's cable. I would love some more details from OP on the fuel pump replacement.
Mike
2018 M3 ZCP 6 MT |
07-12-2018, 10:19 AM | #38 |
Rep 1,499
hey guys if you want to upgrade the LPFP there are a few options. You can get a drop in kit from Fuel-It anywhere from $300 - $650 depending on options.
http://www.fuel-it.com/bmw-f-series-...-lpfp-upgrade/ If you are a DIY kind of guy you can by the rebuild kit for $109 (same as Fuel-It) https://www.highflowfuel.com/i-10388...UaAu20EALw_wcB DIY instructions here... https://www.1addicts.com/forums/show....php?t=1428292 https://f30.bimmerpost.com/forums/sh...php?p=22390446
Anthony235715.00 |
08-09-2018, 05:38 PM | #39 | |||
Rep 10,473
Works for the F2x, F3x and M2 Series. Will not transfer to my M3 so I need to replace it. |
06-08-2019, 10:48 PM | #40 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
Been having the same issue as op ever since installing bm3. Stage 1 when the car was stock, now stage 2 fbo. Only way i have "resolved" the issue is decreasing the boost by gear by 10% in 3rd 4th 5th and 6th. Wondering if i should grab a lpfp upgrade aswell. Bm3 said hpfp was taking a dive momentarily. Unfortunately a hpfp is 2,500. As the above poster said i dont want to spend that money and still have the issue. Lpfp seems like a good place to start.
After installing the stage 2 lpfp is that it? No tuning to get it to work just plug and play? |
06-11-2019, 01:21 PM | #41 |
Rep 101
Why not install the B58 HPFP? Way cheaper option.
https://f30.bimmerpost.com/forums/sh....php?t=1589774
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
06-13-2019, 06:45 AM | #42 |
Rep 323
i have dealt with breaking up since the day i installed the tune. I emailed bm3 and followed their instructions. cp,ngk plugs, spark plug gap, boost leak, coils. now they said hpfp. i turned the boost down in 3rd through 6th to avoid this problem. i got a second opinion and logged then studied my logs closely. my hpfp is below the target and above the target when wot.
i purchased the xdi hpfp and am getting it installed in july. I also i am getting the precision raceworks ignition kit after. the sad thing about this is i am stock turbo with basic bolt ons and the hpfp is failing. i chalk it up to my mileage 75k and bad luck. good luck to all |
06-14-2019, 02:26 AM | #43 | |
Rep 194
06-14-2019, 08:14 AM | #44 | ||
Respect My Authoritah
368
Rep 873
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
