11-24-2021, 07:08 PM | #1 |
Rep 3
Why the DRL lights don't turn on during day?
Recenlty I got my 2014 BMW 320i, Luxury
In auto headlight mode, the DRL lights dosent turn on during day. I did not find any settings under Idrive Lighting either. Everytime I had to turn on DRL mannualy. can someone help pls? Last edited by karthickj25; 11-24-2021 at 07:33 PM.. Reason: img |
11-24-2021, 09:31 PM | #2 |
Rep 16,054
Mine has the option to turn the DRL lights off in iDrive.
On the Control Display: 1. "Settings" 2. "Lighting" 3. "Daytime running lamps" Settings are stored for the profile currently in use. |
11-24-2021, 09:59 PM | #3 |
Rep 3
11-25-2021, 02:49 AM | #4 |
Rep 3,860
No light sensor? Not sure how it is on the early BMW F3x, but on Audi from the same period, a light sensor is optional and comes in conjunction with rain-sensor (automatic wipers).
11-25-2021, 04:22 AM | #5 |
Rep 497
I don't think the problem the OP is dealing with has anything to do with the presence or absence of light sensor. The DRL lights, if set, are supposed to be there regardless of the ambiance condition.
11-25-2021, 04:26 AM | #6 |
Rep 3,860
You may be right.
My experience is from the Audi world (from that period) where "DRL" as an option does not translate into "Automatic DRL", which is a different (more common) option.
11-25-2021, 07:41 AM | #7 |
Rep 16,054
True. The DRL should be on anytime the headlights are not, unless they're turned off. In some countries where DRL use is mandatory they can't be turned off.
11-25-2021, 07:23 PM | #9 |
Rep 4,870
11-26-2021, 12:17 AM | #10 |
Rep 3
11-26-2021, 06:32 PM | #11 |
Rep 1,055
You can grab a Bluetooth module to do this with the BimmerCode app. It's iOS and android one time purchase.
Otherwise Navardi tuned and Kies makes a obd2 adapter to utilize BimmerCode and other apps wirelessly. https://navardituned.com/products/wifienet https://www.kiesmotorsports.com/prod...1-toyota-supra
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
