09-07-2023, 11:33 PM | #24 |
(formerly exe36M3)
53
Rep 63
Resurrecting this thread as I have to smog by 435i up here in NorCal.
I've got the BootMod3 DME. So the verdict is still the following? 1. Charge the car overnight 2. Unlock and reflash the DME back to stock 3. Lock the DME 4. Drive for last least 100 miles. 5. Get it smogged? Thanks gents!
BMW CCA Member | 2015 BMW 435i RWD, Stage 1 Bootmod3
09-13-2023, 10:53 AM | #25 |
Rep 104
This is a useful thread, thanks. I will have to do this next year on my 2018 and I had emailed PTF about locking and unlocking the DME and they never really answered my question. Glad some of you here were able to lock for smog and unlock again after just using the bm3 app.
09-30-2023, 05:51 PM | #26 |
Rep 34
FYI - I was able to pass without flashing back to stock (stage 1. no dp). I forgot about my tune when I went in. This was back in July.
The spot I went to didn't do a visual check either so I'm guessing if I put on the DP I have sitting around, it might've passed. However, I'm not sure if the test that's done has some range for emissions values and whether a high flow catted DP would still cause that to fail (tuned or not). |
11-04-2023, 01:48 PM | #27 |
(formerly exe36M3)
53
Rep 63
OK gonna resurrect this thread as it's coming up for more and more of us as the 8 years has expired!
My car info: - 2015 BMW 435i, stage 1 BM3 - 80k miles - Minor engine mods like VRSF charge pipe and intercooler - MPPK airbox Been running the BM3 for 1 year. Reflashed back to stock AND re-locked the DME about month ago, then put about 500 miles on the car since then. Went in today for SMOG in Norcal with a local shop. I was mentally prepared for the tailpipe stick, ODB plug in, underhood inspection. NOPE. Talked to the SMOG tech, learned a few things... 1. No dyno/roller test on newer cars (like last 10 years) 2. No tail pipe sniffer test, but will gas it for a visual smoke test - excess black or white smoke is a fail. 3. Yes, ODB plug-in scan... which looks for these things (see Torque App screen, which you can do yourself to "pre-test") 4. Yes, he does pop the hood and look for stuff. So if it ain't black and stock looking, it won't fly. The VRSF charge pipe is black, metal. 5. Yes, he will walk the car with a under-body mirror - looking for non-stock headers or missing cats. 6. Battery - he said if you got a new battery, drive the car for at least a hundred miles. He's seen cars with new batteries fail because the emission checks haven't cleared or readied themselves. I was in/out in 5 minutes for the test. Heck 15 if you count the small talk. So in short, with the F3X cars, it's more about the equipment working and telling the OBD2 system, yep were are good. Not so much about actual emissions. I used the torque app to pre-check mine a couple weeks ago. This is the actual list the SMOG guy looks at on screen and my results... VISUAL: Air Inspection Sysem - NA Computers, Sensors, Switching, Wiring - Pass Exhaust Gas Recirculation (EGR) - NA Fuel Metering System - Pass Turbo/Supercharger - NA Catalyst - Pass Crankcase Emission Controls - Pass Fuel Evaporative System (EVAP) - Pass Other Emission Related - Pass Vaccuum Lines to Sensors - Pass My take on this, just make sure nothing looks disconnected or touched. This REALLY needs to look like it was bought off a lot and dirty from a few years of driving. [B]EMISSION CONTROL:[\B] Liquid Fuel Leak Check - Pass Smoke Check - Pass OBD2 - Pass Hope this helps some of you guys. I've been through SMOG fails before with my 95 M3 (dead cats). This was a cake walk.
11-17-2023, 08:14 PM | #28 |
Rep 129
Has anyone ever tried getting a smog with Fabspeed Catted Downpipe and stock tune and locked DME? Is it possible to pass? or do you have to find someone to pass you for visual?
11-19-2023, 07:28 PM | #29 |
(formerly exe36M3)
53
Rep 63
Well theoretically...
1. If there are no markings or shiny chrome or any visual way to give away that you aren't stock. 2. If the DME is locked 3. If there's no smoke out the tailpipe 4. If they don't do a tail-pipe sensor Then you *could* pass because all the checks are software, smoke, and visual...
12-31-2023, 07:49 AM | #30 | |
Rep 39
So this makes me wonder... I totally understand how they can easily verify a known checksum and determine from there if the software was tampered with. But... where do 'they' get the checksum from? Is BMW supplying them with a very long list of checksums for every possible engine & car variation? Does anybody have more insight on that? |
01-05-2024, 08:18 PM | #31 | |
Rep 185
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
01-13-2024, 01:46 AM | #32 |
Rep 137
I'm looking into this exact downpipe for this exact reason lol. Based on what I've heard from others, this will pass visual and smog. But curious to see what others who have first hand experience have to say. The price is rather steep and I'd hate to have issues when I have to re-smog in a couple years.
02-06-2024, 08:57 PM | #33 | |
Rep 129
03-28-2024, 01:03 PM | #34 |
Rep 5
Hello, I just did my smog last month and I passed . I just put the stock down pipe back and flashed stock tune . Also I didn’t have to lock the dme. I did do the drive cycle and drove 300 miles. Also just checked if all the emissions status was completed
2BitRoach12.00 |
11-02-2024, 02:06 PM | #35 |
Rep 79
Drives: 2016 F31 M Sport
My wagon just passed first-ever smog check. I kept putting it off and ran into needing to register my car asap, so I never flashed back. Passed no problem with Stage 1 flash and stock cat.
11-07-2024, 11:30 PM | #36 |
Rep 59
Hello. Sorry to resurrect a dead thread but you had no problem smogging without locking the DME? For some reason I cannot get Bootmod to lock the DME anymore on my laptop (it's a new laptop but I flashed it back to stock from the Stage 1 tune).
11-13-2024, 09:01 AM | #37 |
Rep 228
Wanted to weigh in here.
2017 430i stage 2 tuned with MG Flasher Reinstalled factory downpipe. Flashed back to stock tune and locked ECU. Passed emissions. Was able to unlock and reflash stage 1 in the parking lot. |
