04-10-2023, 06:24 PM | #661 | ||
Rep 7,607
Having said that the whole point of the stage 2+ map is to take advantage of HPFP, so you will definitely benefit from that. Bottom line is that you dont get any benefit unless you actually need the extra fuel delivery. A HPFP doesnt add any power in itself, it only matters when you exceed the fuel capacity of the stock HPFP. |
johnung4528.00 |
04-10-2023, 08:05 PM | #662 | |
Nicks_F30
Rep 13
04-10-2023, 08:08 PM | #663 | |
Nicks_F30
Rep 13
04-10-2023, 10:44 PM | #664 | ||
Rep 7,607
But yes you can run the stage 2+ map with an upgraded HPFP. for the B58tu pump you keep the flash option as stock |
johnung4528.00 |
04-10-2023, 11:56 PM | #665 | |
Nicks_F30
Rep 13
04-11-2023, 05:00 PM | #666 |
Rep 7,607
04-11-2023, 07:51 PM | #667 |
Nicks_F30
Rep 13
04-11-2023, 11:31 PM | #668 |
Rep 7,607
04-12-2023, 01:44 PM | #669 |
Rep 93
I’ve been running pure500 with oem b58 hpfp gen 1 pump on e30 custom tune. Stock n55 hpfp can’t handle e30 mix with pure500 turbo. I haven’t had any hpfp crashing issues yet like I did with n55 hpfp.
04-12-2023, 02:37 PM | #670 | |
Rep 7,607
According to Dorch, the HDP5 evo only flows about 7% more than the OEM N55 HPFP. https://dorchengineering.com/product...1-hpfp-upgrade |
04-12-2023, 02:47 PM | #671 | |
Nicks_F30
Rep 13
04-12-2023, 07:20 PM | #673 |
Nicks_F30
Rep 13
04-12-2023, 08:31 PM | #674 | ||
Rep 4,146
Can you post a log?
Mods: Yes.
04-13-2023, 12:17 AM | #675 | |
Rep 93
N55 ewg, 8 auto, pure500 turbo FBO. Car is running higher boost now, it’s a beast. N55 hpfp dip to 1400psi vs 2000psi on b58 hpfp. B58 hpfp with same map https://datazap.me/u/arekux/pure500-...og=0&data=3-12 N55 hpfp with same map https://datazap.me/u/arekux/pure500-...og=0&data=3-13 Last edited by arekuf3x; 04-13-2023 at 09:28 AM.. |
04-13-2023, 12:54 AM | #676 | |
Rep 4,146
Mods: Yes.
04-13-2023, 08:40 AM | #677 | |
Rep 93
https://datazap.me/u/arekux/n55-pure...og=0&data=3-12 Here is one log with higher boost on pure500 turbo and b58 oem hpfp. Last edited by arekuf3x; 04-13-2023 at 10:45 AM.. |
04-13-2023, 11:06 AM | #678 | |
Rep 7,607
Also your pressure still starts to drop at peak boost. Makes sense with how little more that pump flows. |
04-13-2023, 12:10 PM | #679 | |
Rep 643
M235i rwd 6mt
04-13-2023, 12:25 PM | #681 | |
Rep 643
i have read of 1 instance where someone claimed the tu pump damaged their n55, but it was never backed with any evidence and the poster went quiet. n55 hpfp is driven by cam on the vacuum pump, and using a tu pump to get more flow is no different than using any of the available aftermarket hpfp. the principle is the same, increase fuel volume by increasing the size of the piston that rides the cam or have a more efficient design. sure, this would theoretically cause more wear on your cam, but so does any other upgraded hpfp and there has been no reports of damage that i have ever come across. if you're willing to do the work and modify the flange of the tu pump, i think it's a good option.
M235i rwd 6mt
04-13-2023, 02:23 PM | #682 | |
Nicks_F30
Rep 13
