BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Reverse camera OEM style retrofit for $199 shipped - DIY Details
      10-02-2019, 03:49 PM   #111
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Originally Posted by efrancis1409 View Post
Just finished installing the camera! It was actually really easy, and I'm a noob when it comes to wiring and stuff like that. Took me about 2 hours, the hardest part by far was hiding the extra wires and the additional module in the climate control area after everything was up and running.
Nice man. Yeah this thing is pretty awesome. Congrats on the install!
      10-02-2019, 05:29 PM   #112
efrancis1409
Drives: BMW 328I F30
Thanks man! I noticed in the camera settings the very first option looks like an "R" with a camera icon behind it but it's grayed out and can't be highlighted. Know what that is or its function? I'm assuming it's some type of recording feature?
      10-02-2019, 06:17 PM   #113
Urbz
Enlisted
Urbz's Avatar
Drives: 2016 F30 340i
2016 BMW 340i  [0.00]
Just purchased and installed mine. Thanks for the Free Shipping code!
Anyone know of there's any way to disable the the car icon on the right of the screen? Maybe some sort of dip switch combination? I don't have PDC so don't need it.
'16 F30 340i / Mineral Gray / MSport / Track Handling / Harman Kardon / Blackline Tail lights
SOLD '07 E90 328i / Sparkling Graphite / Black and Aluminum Interior / 6MT / ZSP / Xenon / Logic7 / BMW Performance Exhaust / BMW Performance Short Shift Kit / Modified CDV / Euro Light Switch / Dæos DRL Harness / V1 Fuse Box Hardwire / Blacklines / Darmstadt Military Sales
      10-02-2019, 07:16 PM   #114
330istocknot
Drives: 330chino
I atually think the car looks cool haha, but nope, i feel like that part is straight from BMW, might need some coding for that.
Urbz8.00
      10-02-2019, 10:00 PM   #115
efrancis1409
In case anyone was wondering here's the reverse camera with led reverse lights and led brake lights. Car originally had halogens installed.
https://photos.app.goo.gl/McLT9ZVJazmkgLZc7
      10-03-2019, 09:06 AM   #116
penet05
Drives: 2014 X5 Sdrive35i, 2013 328i
How does it work with the original PDC? Any issues?
      10-03-2019, 09:44 AM   #117
muniz_ri
Drives: BMW 320I
I emailed the seller and he stated that there is no way to remove the car icon to make the camera full screen.
I also searched and found this schematic for the dip switches:
[IMG]undefined[/IMG]
Urbz8.00
      10-03-2019, 09:50 AM   #118
jbb2388
Drives: 2016 F30 340iX
Where did you....or anybody else... pick up the LED brake and rev lights?
      10-03-2019, 09:51 AM   #119
jbb2388
Free shipping code? Did I miss that?
      10-03-2019, 10:08 AM   #120
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
OP shared that if you us code "free-shipping" you'll save $20. I used it, it works.
jbb238847.50
      10-03-2019, 10:21 AM   #121
efrancis1409
These are what I have in my car. Had them for a few months now no issues and are very bright but of course you'll need to code out the voltage check so the lights don't blink every few minutes.
CIIHON 1156 LED Turn Signal Light... https://www.amazon.com/dp/B07G9B52NX?ref=ppx_pop_mob_ap_share
AUTOGINE 4 X Super Bright 9-30V... https://www.amazon.com/dp/B07DTBHHZR?ref=ppx_pop_mob_ap_share
jbb238847.50
      10-03-2019, 02:30 PM   #122
jbb2388
Thanks guys
      10-04-2019, 11:58 PM   #123
muniz_ri
Drives: BMW 320I
My guess is that you can record video if you insert an sd card in the mmi's sd card slot. Not sure if I have an sd card laying around but if I do I may try it this weekend.
      10-05-2019, 12:07 AM   #124
muniz_ri
Drives: BMW 320I
Originally Posted by 330istocknot View Post
My 8.8 screen will be arriving this week, i will update if it works with a 6.5 unit.
See the attached schematic...dip switches 1, 2, and 3 seem to adjust the screen size.
      10-05-2019, 12:20 AM   #125
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
You're correct. 1,2,3 switches are used to set screen size. The sticker on my box indicates 1-ON/2-ON for for 8.8" but that setting leaves a slight white line on the right of my iDrive screen on the right side I'd the card image. 1-OFF/2-ON did the trick. No lines, looks good.
For those who choose to update these settings make sure you unplug the white cable before changing the dips. The changes will take affect after the unit is plugged back in.
Good luck.
      10-07-2019, 12:11 PM   #126
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
Originally Posted by sthor10 View Post
This is the response they sent me when I sent them my vehicle info:
Hi, please choose iDrive CIC system with 6 pin LVDS plug.
If the existing screen on your car is 6.5 inch, please choose 6.5 inch screen
If the existing screen on your car is 8.8 inch, please choose 8.8 inch screen
Best regards,
CarNaviPlayer Support Team
www.carnaviplayer.com
did they end up getting it right on which plug you needed?
I didn't have time to pull the screen to check so i emailed them my VIN in the meantime and they sent me the same response - pick the 6 pin.
      10-07-2019, 01:23 PM   #127
sthor10
sthor10's Avatar
Drives: BMW F30 328
Best regards,
Yes, they gave me the correct info on which unit to order.
aps335.50
      10-09-2019, 09:58 PM   #128
efrancis1409
When you ordered it, did you select that you had an 8.8 inch screen or 6.5 that seems e made for 6.5
I got a 6.5 inch screen and it works great. I haven an 8.8 inch screen on the way here that i will be installing soon, ill let you know if this problem happens, if so, that means you might have ordered the 6.5 inch version not version.
Any update on the 8.8 screen? I actually just picked one up myself and was wondering if the split screen feature could be used somehow, along with this camera.
      10-09-2019, 11:42 PM   #129
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Good luck.
So of the 8 switches only the first one needs to be switched off and the other switches stay on? I just ordered an 8.8 screen and what to make sure I get the settings right.
1-On, 2-On, 3-Off is what they recommended. 1-OFF, 2-On , 3-Off worked for me.
      10-11-2019, 07:34 AM   #130
Chriske92
Drives: BMW 328i
For the led brake light i purchased these led bulbs from iJDMTOY. I didn't need to code thema at all and no flickering
For LED reverse bulbs i bought natgic, but very weird always the tight one doesnt want to work Tried other bulbs but also that didnt work
      10-11-2019, 08:18 PM   #131
Chrisf36
Drives: BMW f36
I just installed the same kit but I have navi and 8.i screen and the whole screen says no signal whether I'm in drive or not
      10-11-2019, 09:07 PM   #132
Palantir
Palantir's Avatar
219
I have these for a year now and they worked great. I got them just when they started selling them and there were no reviews. Took a chance but they turned out great. I have lasfit brand for the reverse lights-coded all checks off and designated all as LEDs. Lasfit turned out to be white but not as concentrated as I had hoped.
In your case, the one bulb that is not working might need the module to be reset. If you had faults too many times the module just turns off power to that circuit.
