11-20-2020, 11:58 AM | #45 | |
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-20-2020, 05:53 PM | #46 | |
Rep 880
The 4 "main bits" that form the 4 sides of this Air Breather duct are, in order of importance: • the Ramp piece at the bottom, a multi-curved seal that at entry follows the lower M-sport Bumper AirBreather Inlet geometry, and then arches back and upward in a smooth curve up to the bottom of the small exit Port in the forward fender liner. • the outward Bulging Aero-shape on the inward face that's actually formed on the outer shell of the Cooling Duct for the remote oil cooler (in my case, on side shown) or remote radiator. • the inner surface of the curved lower M-sport bumper side fascia. • a narrow flat face along the top front created by the bottom of inner bumper mount, that has just a small curved seal at the back that downturns as it meets the forward fender liner. The rising ramp aero-surface at the bottom directly into the port would look to speed up airflow and compression to 'pull' the available air in the duct through the port, jetting it at the outer/lower edge of the spinning wheel. The LCI looks to have retained the ramp - maybe only difference is lack of the exit Port? See pic - pardon the dirt, hasn't has a wash in more than a week... Last edited by visionaut; 11-20-2020 at 08:24 PM.. |
BWbimmer276.50 |
11-21-2020, 04:05 AM | #47 | |
Rep 833
I finally found the "missing part", it's not the fender liner which does the funneling. As you showed to us, it's indeed a seperate part with I guess is the Air duct, lateral, 51747465289 (LCI) vs 51747294821? I was mislead, the whole time, sorry for that. I'm wondering if I should get the parts for left and right. I probably will not see any difference since my car is limmited to 250km/h.
Such Fun
11-21-2020, 01:22 PM | #48 |
Rep 1,115
Drives: 2015 BMW 435i Xdrive MSport
It's on 4 series cars and the level of trim determines its color. They're called louvers.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
11-21-2020, 02:40 PM | #49 |
Rep 880
01-02-2021, 04:19 PM | #50 | |
Rep 128
440i GC - Previous cars, I30n Performance, MKV GTi, E46 325i Touring, E46 320d Touring, E91 M Sport Plus Edition,
01-02-2021, 07:22 PM | #51 |
Rep 880
Should help aero efficiency. The Air Curtains in the front likely more so than the Air Breathers in the fenders. They aren't designed for downforce like your M Perf splitter.
Per BMW: "The Air Curtain controls the airstream. This is because it reduces the air resistance of the body in an astonishingly simple but very effective way. Its narrowing channels speed up the airstream and guide it past the wheels. This reduces the air turbulence in the wheel housings and decreases the drag due to the body as well as the fuel consumption and CO2 emissions". and "The Air Breather, an aerodynamically effective aperture behind the front wheels, works in tandem with the Air Curtain in the front apron to provide an effective reduction in drag around the wheels. The Air Breathers divert some of the air flowing through the wheel arches, thereby reducing air resistance." As you know, the LCI 4 dropped BOTH. Instead the LCI has fully open Air Curtain slots in the bumper (so no exit port speed-up), and closed-off Air Breathers in the rear of the front fender. So it's likely a small but appreciable benefit. But likely not worth the retrofit cost if you're trying to rationalize payback in fuel savings... |
01-03-2021, 08:31 AM | #52 |
Rep 833
I just don't get why BMW dropped the breathers since everyone talks about fuel consumption and CO2, these day. Seems to be a pretty stupid move, to me.
Such Fun
01-03-2021, 09:11 AM | #53 |
Rep 3,862
That's exactly my theory - that they dropped them BECAUSE co2 and fuel efficiency is becoming a bigger topic than ever.... and maybe those features turned out to do exactly the opposite, specifically on this model, as originally designed.
I have no other explanation why else to redesign and introduce new components.
01-28-2021, 11:10 AM | #54 |
Rep 128
Just to resurrect this one a bit, from the spy shots of the upcoming G26 GC, it looks like they are reintroducing function slats behind the front wheel wells again.
So it's on-off-on again?
01-28-2021, 02:04 PM | #55 | |
Rep 833
https://www.auto-motor-und-sport.de/...an-coupe-2021/
Such Fun
01-28-2021, 06:33 PM | #56 |
Rep 128
Here you go:
01-31-2021, 11:13 AM | #57 |
Rep 833
Such Fun
