11-23-2020, 07:43 AM | #1 |
Rep 360
N20 knocking - rods or torque converter VIDEO
Hi,
Noticed my N20 makes a slight knock but only when fully warmed up. The knock is not present at start up or when warming up. Only appears at 80-90C It's comes on at 1k rpm and can only be heard from underneath the car or inside the cabin. I've heard that it could be the torque converter being out of place and needs turning? BMW did the chain a year ago and said the oil was fine when removing as sometimes if the oil pump fails it causes the oil to go funny. Wasn't sure what they meant, but during the strip down it was all okay. Any thoughts? |
12-05-2020, 10:30 AM | #4 | |
Rep 360
It's currently got 0w30 in, at the next change I'll put 0w40 in to see if it helps. I don't get any knocks at start up or switch off which comes with rod knock. |
12-07-2020, 02:23 AM | #5 |
Rep 360
So after thinking about this and listening to it more it only happen when at full temp and
Between 1500-2200rpm. I've used a hearing device on the sump and gearbox and can't work out what it is. Could this be an imbalance on the harmonic balancer? I am also considering changing the rod bearings, but wondering if there is an easy way to do this as mine is xdrive. Also, is there an easy way of getting the oil pump out without having to remove the chain assembly? |
12-15-2020, 06:59 PM | #10 |
David
783
Rep 2,010
Sounds fairly normal, possible some waste gate rattle or motor mounts are getting worn, but I doubt it's a knock.
12-15-2020, 07:05 PM | #11 |
Rep 99
Drives: F30 328i BMW
This is mine on a cold start, but warm it's not quite as loud.
https://f30.bimmerpost.com/forums/sh....php?t=1773400 |
12-16-2020, 05:51 AM | #12 |
Rep 360
Thanks for the replies.
The noise I'm talking about is kinda like a knock or imbalance wobble. It's most apparent on this video at 14-30 seconds. There's a noise just after deceleration. It's quite hard to hear |
12-16-2020, 06:22 AM | #13 |
Rep 1,230
I feel my n26 was noisy and had a ticking sound (injectors), but it did not sound like this when I stepped on the gas.
2023 M2. ZB. Manual.
2024 m235i |
12-16-2020, 06:30 AM | #14 |
Rep 360
Thanks for confirming.
This noise is only apparent from underneath rear of the engine towards the gearbox and only when at operating temp. Thought it might be torque converter so I re-torqued the bolts, but no difference. BMW only changed the oil and filter in September and didn't mention anything. Also they did the TC in December 19 and no mention of problems which they said they would check due to the broken chain guides. Might pull the oil to check it, but seems wasteful as it's only covered 1k miles. I've checked the filter and couldn't see anything. Also used a magnet, I'll check it again though. Another thing I was thinking is could it be the oil pump counter balance? |
12-16-2020, 09:48 AM | #15 |
Rep 360
I pulled my oil filter and put some oil on white paper and could see some shiny specks.
With so many moving parts I would expect there to be some and on a 100k engine. However, I do wonder if the two could be related. Any thoughts on this? I'll test it again when I can and post a picture/video. I'll drop the oil when there's a break in the weather. I would drop the sump, but it's quite a big job on the X drive during winter. So might have to wait until spring/summer to inspect the rod bearings. |
12-16-2020, 01:51 PM | #16 | |
Rep 143
Metallic specs are not good regardless of mileage. If you open the oil cap, can you wiggle the timing chain with a screwdriver? Does it look loose? |
12-16-2020, 06:03 PM | #17 | |
Rep 13
https://youtu.be/I0nsGIlT3z8 Out of curiosity, are the rod bearings easy to replace once the oil pan is removed? |
12-18-2020, 04:54 PM | #18 |
Rep 360
Hi,
So I checked the oil again today on paper and could see some tiny flecks, but not a lot. I filmed the following video of the oil filter housing. There's some flecks, but it doesn't look bad. Regarding my knock it's very hard to hear and can only be heard from underneath. Can't hear it at the top of the engine. It's quite faint, I'm starting to think it might be gearbox or torque converter as I can some funny noises when it's hot and in reverse. |
12-18-2020, 05:00 PM | #19 | ||
Rep 360
TC guides were broken up, bmw inspected the oil and pan and said there were no concerns when replacing it. |
Phoenix70486.50 |
12-18-2020, 05:07 PM | #20 | ||
Rep 360
Regarding doing the bearings there's videos on YouTube for N55 Yours should be relatively easy. Drop the subframe - support engine from top. Drop it by 10cm and lock flex plate, remove pan, remove oil pump (think just strainer and oil chain bolt, will need to take tension if chains using Allen key) Then use plastigauge and get tolerances from bmw along with correct bearings. Ista will give you a guide. Lots of assembly lube, new oil and filter, prime the engine (disconnect coil packs and injectors) crank 4/5 times to build oil pressure and lubricant system. Make sure oil pressure light goes out. There's more on priming online. Hope for the best that it's worked, if the platigauge readings come in ok you should be good. |
F32Huncho13.50 |
12-11-2022, 03:40 PM | #21 | |
Rep 1
Thanks! |
