02-24-2019, 03:46 PM | #1 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
What Gap to use? Installing NGK Spark Plugs Weds.
I have 2013 f30 n55 335ix 6mt. I have bootmod3 stage 1 93 octane. with drop in afe filter. Getting charge pipe installed same day as NGK 97506 sparkplugs. Bootmod3 recommends .020 or .018 gap. I have been recommended .024 gap because of reports of rough idle from the other gaps.
Right now I am experiencing between 3k and 4k rpm a stutter or lose of power in wot. I have posted my diagnostic results in another post and have been told I am running high boost for a stage 1 tune. Looking to see what gap I should use this weds that has given other the most success in holding higher boost levels and maintaining good idle and drivability! here are some links to my diagnostics under WOT http://www.bootmod3.net/log?id=5c6b4219ae729b792d308250 http://www.bootmod3.net/log?id=5c6b4219ae729b792d308250 http://www.bootmod3.net/log?id=5c6b3f56ae729b792d308248 http://www.bootmod3.net/log?id=5c6b3f19ae729b792d308247 http://www.bootmod3.net/log?id=5c6b4157ae729b792d30824d http://www.bootmod3.net/log?id=5c6b4022ae729b792d30824b http://www.bootmod3.net/log?id=5c6b3ed0ae729b792d308245 thank you Last edited by 13blk335ix; 02-24-2019 at 04:16 PM.. |
02-24-2019, 03:53 PM | #2 |
Rep 799
Check out these 2 threads:
Spark Plug Options for N55 Engine https://f30.bimmerpost.com/forums/sh....php?t=1531734 Which Sparkplugs? N55 (mods) https://f30.bimmerpost.com/forums/sh....php?t=1369661
13blk335ix74.50 |
02-24-2019, 03:59 PM | #3 |
Rep 808
I'm running 0.020 on the same setup as you with good results
13blk335ix74.50 |
02-24-2019, 04:15 PM | #4 |
Rep 323
thank you for responses when gapped at 0.020 how much closer is that than the NGK out of the box? I have the 97506.
02-24-2019, 04:36 PM | #5 |
Rep 323
thanks for posting those two thread links but I have used the search option before posting this thread and read those. I was hoping for more input on the subject and recent results since those posts and what people have experienced since then!
02-24-2019, 06:16 PM | #6 |
Rep 808
13blk335ix74.50 |
02-25-2019, 08:03 AM | #8 |
Rep 5,457
+1
Running the same plugs and didnt touch the gap. The way they are packaged, it is IMPOSSIBLE for the gap to differ from production line. Not necessary to even check the gap. Havent missed a beat in about 20k miles. Playing with the gap leaves you open to all sorts of potential issues (noted above). Sooo... why would you? I am highly doubting a performance increase from a tighter spec spark plug gap. Actually sounds funny |
02-25-2019, 08:58 AM | #9 |
Modder of everything I own
147
Rep 491
I used 0.022 NGK 95770 since Summer 2018, I'm on MHD with JB4 BEF.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
03-01-2019, 03:20 PM | #10 |
Rep 716
Drives: F90 M5
I am running a 0.018 gap on mine and everything has been perfect thus far, have you tried sending your logs in to PTF and seeing what they say?
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
03-01-2019, 07:41 PM | #11 | |
Rep 323
I sent my logs to PTF and they recommend to gap plugs at .018 or .020. and if that dosnt solve stutter they would turn the boost down on a custom tune. a huge difference is because i have a 6 speed manual transmission. CATLESS DOWNPIPE NEXT BOYS! |
Shayan55338.50 |
