02-25-2019, 09:29 AM | #1 |
Rep 568
Drives: BMW M4 DCT (F82)
Deleted
Deleted
Current: F82 Mineral White M4 7DCT
Gone but never forgotten: E92 Sparking Graphite 335i (N54) 6MT build thread. Last edited by Pete.J; 08-24-2020 at 09:49 AM.. |
02-26-2019, 02:10 AM | #2 |
Rep 373
looks like part of the wrist pin?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
02-26-2019, 01:46 PM | #3 |
Rep 1,934
Lol damn! That doesn't look fun.
02-26-2019, 02:03 PM | #4 |
Car Hypochondriac
335
Rep 901
This is literally just a shot in the dark, but that plastic piece looks like it could have been off of the timing chain tensioner or something.
02-26-2019, 02:24 PM | #5 |
Rep 5,369
A Google search of N55 "timing chain tensioner" and "N55 piston" appear to indicate that the parts are:
1) The black plastic is part of the tensioner frame. 2) The metal rings are wrist piston retainers. Both of these parts being able to fall into the sump makes total sense too as this is directly where they'd fall and not get chewed up. Given there's metal shavings in the oil and wrist pin retainers have been knocked out makes me think this N55 is done for.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
afranke207.00 |
02-26-2019, 02:35 PM | #6 |
Car Hypochondriac
335
Rep 901
After looking at google images, I agree with XutvJet, the metal looks like wrist pin locks. This engine is probably gonna need a hefty makeover.
02-27-2019, 01:58 AM | #7 |
Rep 373
What is the mileage on the car. You say the car is used for competitive racing is it totally stock?
what would cause this? oil temps too high no lubrication?
02-27-2019, 03:48 PM | #8 |
Rep 470
N55 and oil pan is really not designed for high sustained G loads of track driving, probably just accelerated wear from beating on it.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
02-27-2019, 04:13 PM | #9 |
Rep 440
Drives: 2013 335i xDrive
If the spirolocks are out and the piston pin has gotten into the cylinder wall, it should have oil smoke, not just out the tailpipe but inside the crankcase too. Can you run a compression test?
I'm not completely useless, I can be used as a bad example.
