05-22-2019, 11:39 AM | #1 |
Rep 107
Installed B14's now clunk. Shop says sway bar end links?
Hey guys,
I just installed B14's on my F33 M sport I've got the front slammed and the rear two turns up. I'm now getting a clunk from the front right corner. We checked the pitch of the struts and it looks correct (my guy said the struts are keyed, so there's no way to install them with the wrong pitch). My alignment shop said my sway bar end links look like they might be causing the problem. Would adjustable end links remedy this issue? If so what size should I get? Looking at Turner as an option. https://www.ecstuning.com/b-turner-m...104~dk/?pdk=Ag
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
05-22-2019, 01:52 PM | #2 |
Rep 1,934
Look under the car and check the end links out. I have seen them snap very inconspicuously when the cars get lowered.
05-22-2019, 02:13 PM | #4 |
Rep 2,962
99% of the time you lower more than ~1" and get a clunk noise it's the endlinks
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
05-22-2019, 02:36 PM | #5 |
Rep 107
What size adjustable end links should I be ordering?
05-22-2019, 02:51 PM | #6 |
Rep 2,962
They should be shorter by the amount you lowered. I had adjustable endlinks on my E90, not sure if they make them for Fxx though
Check out https://www.bimmerworld.com/Suspensi...ing/End-Links/
05-22-2019, 03:19 PM | #7 |
Rep 5,457
MEYLE HD end links work great for my Bilstein suspension. Worlds better than OEM.
05-22-2019, 05:01 PM | #9 |
Rep 681
I swapped out for adjustable endlinks (and shortened them to remove preload) and my clunking went away. I would highly recommend swapping your end links as lowering even 1" put considerable preload onto my sways. Car handles way better after removing that preload.
sspade2467.00 |
05-24-2019, 09:26 AM | #11 |
Rep 107
Do you remember what length they were?
05-24-2019, 10:29 AM | #12 |
Rep 681
I bought the CATuned 160mm adjustable end links. They were on sale and I wasn't 100% sure at the time if it would solve my issues so I didn't want to spend 200 on the hotchkis ones. They're pretty nice though esp for the price. They sometimes make a tiny bit of noise when doing full lock to lock turns though. Just something to keep in mind when you put them on.
2016 328ix F31 - SOLD!
2006 997.1 C4S Last edited by andino; 05-24-2019 at 10:39 AM.. |
05-25-2019, 09:32 PM | #13 |
Cheapskate
4455
Rep 4,995
you shouldn't need adjustable end links for any amount of reasonable lowering. It doesn't add a preload to the sway bar. The sway bar rotates in the bushing. Anytime you go over a bump, it rotates up and down with the shock. The only purpose of an adjustable endlink is to add preload during corner balancing.
sspade2467.00 |
05-25-2019, 10:42 PM | #14 | |
Rep 5,457
kern4174454.50 |
05-29-2019, 08:15 AM | #15 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
It's true that often the OE end links work fine because the sway bar can rotate to a new non- preloaded position after lowering the car. However it's a problem if that new position interferes or contacts some part of the suspension. Or if you are independently adjusting ride height at each corner. The primary reasons for adjustable end links are to remove preload (NOT add) and to resolve any clearance issue that arises when changing ride height and/or other suspension geometry, arms, etc.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 05-30-2019 at 01:01 PM.. |
05-29-2019, 08:20 AM | #16 |
Rep 5,457
^ no clearance issues with a modestly lowered F30, therefore adjustable end links are unnecessary.
05-30-2019, 12:59 PM | #17 | |
Rep 6,734
I have lowered my car on HR springs and was able to continue to use my OE end links without any issues.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
sspade2467.00 |
05-31-2019, 11:37 AM | #18 |
Rep 681
FWIW, I'm lowered on b14s with a 14" center of wheel to fender distance and I needed to change my end link lengths due to contact on large bumps as well as a noticeable amount of preload on my sways. Keep in mind, I'm an xdrive car as well so 14" measured from center of wheel to fender is a larger drop than a rwd car.
I also noticed the same while I was lowered on KW V1s so the symptoms are independent of the type of suspension I'm running. I was 1/2" lower on V1s than I am currently on b14s
2006 997.1 C4S |
Logicoeur992.50 |
06-01-2019, 06:40 PM | #19 | |
Rep 1,523
06-01-2019, 08:27 PM | #20 |
Rep 107
FWIW my shop installed a new end link on the passenger side. The bushing on the old one was shot. No more clunks now.
They said I’ll need adjustables as they expect these to wear out fast. They said the drop is adding extra pressure thus wearing out the bushings.
06-01-2019, 09:41 PM | #21 | |
Rep 681
You're more than welcome to run stock links after being lowered. If you don't notice a difference that's fine too. I did and knew what I needed to change to fix it. I'm very happy with how my suspension responds now so I stand by that decision. |
06-01-2019, 10:02 PM | #22 | |
Rep 1,523
I am lowered on KW and I believe the end link mounting point is higher up on the front strut already. |
