09-05-2018, 12:18 PM | #1 |
Rep 609
Difference in comfort between 18s and 19s?
Hi everyone,
Please can I get some real world feedback on difference in comfort between say m sport and m sport plus? Is it noticeable with the same tyres etc? |
09-05-2018, 04:20 PM | #3 |
Rep 3,860
No big difference on decent roads. You may find the 19s harder on bad roads.
This said, the 19s perform better at high speeds. And look better
09-05-2018, 05:42 PM | #7 | |
Rep 3,860
And don't forget that in the F3x's case the 19" setup has wider rear tire (255 vs 225). While 19" are inevitably less comfortable than 18", that is only (or mainly) noticeable on bad roads. And I would not hesitate for a minute to go for 19" summer tires assuming decent roads. I still drive 18" winter tires which are the best compromise for that season. For comparison, on my Audi I have 18" summer, 17" winter. Used to have 17" summer as well but moved on to 18" and don't regret it at all - noticeable improvement in performance.
09-06-2018, 05:48 AM | #8 | |
Rep 594
The F3x's M Sport models with 18" come with 255 rear tyres. If I were to consider 19" alloys, I would go for standard tyres over runflats and that should compensate the difference. |
09-06-2018, 06:04 AM | #9 |
Rep 15,858
Wheel size and choice of tyres will always be a set of compromises. There has to be give and take, it is the nature of what each choice offers.
For me it is setting priorities; safety, wet weather performance, road conditions, handling/comfort balance, looks. In that order. BMW typically optimise a chassis for the standard wheel size on offer for the model. Upgrades are offered with extra compromises, BMW state that in their own wheel/tyre development data. |
09-06-2018, 07:24 AM | #10 | |
Rep 194
As for 19s looking better, that’s all down to personal taste. 18s will defo be my next mod. |
09-06-2018, 07:28 AM | #11 |
Rep 3,860
It's all subjective, including taste, but I doubt you will find many to like smaller rims better than bigger (up to a certain size and assuming same design).
But yes - it is all a personal choice. I am very happy about mine for both cars. Would go up to 19" Summer tires on the Audi as well but I feel the aesthetics may be affected as it is a smaller car. Good luck to the thread owner!
09-06-2018, 08:49 AM | #13 |
Rep 1,032
Personally I think the standard M Sport 18" 400M wheels look OK and being painted are far easier to refurb if the inevitable happens. Same stagard setup as the 19" with 225 front and 255 rears
09-06-2018, 08:58 AM | #14 |
Rep 624
I've just been through this debate myself. This issue for me is that the aspect ratio on F30 19" rims is very low. My current car has 45 profile tyres on 19 inch rims but I believe it's 40/35 on the F30 19" rims.
That doesn't leave much rubber to absorb bumps, and vibrations and it makes the rims more exposed to damage from potholes etc. Although I love the asthetics of the 19" rim I've gone for 18" on my new motor (an F36) as the 19" option seemed to be a case of form over function and the roads around my area are pretty bad. |
09-06-2018, 11:48 AM | #15 |
Rep 1,437
19"s have more feel and feedback but less comfortable than 18"s for me.
comfort to sport plus with adaptive transmits through a little more harshness from the UK potholes roads but not enough to immediately switch back to comfort. my main issue with 19"s is noise. I suspect the runflat 19"s make up some of the problem, however changing to nrft would comprise the suspension and very likely to invalidate the warranty on the xdrive drivetrain. I'm likely to go for Goodyear f1 as2 which are approved and 65db v 72db . it also worth noting that I've personally got another 4k miles out of rft (32k v 28k miles) on my previous car. |
09-07-2018, 07:32 AM | #17 |
Rep 36
I switched from 19s to 18s and there was a big improvement in primary ride and harshness. Just normal manhole covers felt like a car crash on the 19s. My winter tyres ride better still. They are also on 18s but 225 runflats all 'round. Not sure if it is lighter wheels or softer rubber making the difference. Standard M Sport rear tyre size on 18s is 245 not 255??
2018 530dX Touring
09-07-2018, 08:26 AM | #18 |
Rep 1,926
Just to put some numbers behind the wheel/tyre combos, I measured my Summers and Winters as follows:
Front 225/40 R19 with Bridgestone RFT = 24.2kg Rear 255/35 R19 with Bridgestone RFT = 25.4kg Winter 225/45 R18 with Goodyear non-RFT winter tyre = 19.2kg
F31 340i | GS with CR & Ash Grain Trim | M Sport+ Pack | Prof Media Plus Pack | Interior Comfort Pack | Leather Dash | Folding Mirrors | Pano Roof | Elec Mem Seats with Lumbar | Adaptive Suspension | Comfort Access | Reverse Cam | Surround View | SLD | Rear Sunblinds | Folding Headrests | Model Designation Delete | Trim Designation Delete | MPPSK
09-07-2018, 10:44 AM | #19 |
Rep 2,511
Both ride quite comparably on my cars. Comparing 19" Bridgestone summers and 18" Pirelli winters. Both run-flats and on Adaptive Dampers and M Sport Springs on a F30 330d and a F31 340i lci.
So, spec adaptive dampers and the ride compromise seems much reduced. My F30 330d on 19" wheels rode better than my previous E90 320d on passive dampers and SE springs.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
09-07-2018, 11:21 AM | #20 |
Rep 797
With 19" wheels and run-flats you will get a pretty big shock each time you drive over a pothole, even when the force of the impact isn't enough to cause any damage. Having said that, the worst shock I got was when I hit a pothole on the A7 going into Edinburgh, and that was on a set of 17" winter wheels in my old car. So run-flats are indeed the culprits.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
09-07-2018, 05:59 PM | #22 |
Rep 3,860
Is that an advantage or a disadvantage....?
Firm is what you want from a sporty car.
