10-07-2018, 07:15 PM | #1 |
Rep 176
Comfort Access Issues
When I try to lock the doors using comfort access, it takes several tries for it to work, even after getting the key closer to the car.
When turning on the car, sometimes it'll say the key was not in the car and won't start, but it'll work the second time I try. Just replaced the key's battery. Last but not least, the trunk also takes several "kicks" for it to open. Any ideas? Can this be improved with coding by any chance? |
10-08-2018, 03:13 AM | #2 |
Rep 3,869
Coding will not help. You have a technical problem. It sounds like it is with the fob (each door has a separate sensor, so if all have the problem, as you describe - it is most likely the fob).
Do you have the same issue when using the second fob?
10-08-2018, 03:35 AM | #3 | |
Rep 765
10-08-2018, 04:33 PM | #4 | |
Rep 130
Drives: 2016 bmw 328i xdrive
wdeerfield2745.00 |
10-09-2018, 02:28 PM | #5 |
Rep 878
Jhnblckwood130.00 |
10-10-2018, 05:59 PM | #6 |
Rep 765
10-14-2018, 02:41 PM | #7 | |
Rep 176
Just wanted to make sure it wasn't normal operation for that year, but if it isn't, might just take it in before the cpo expires, just gonna have to be lucky enough for it to reproduce it for them as they never do any work unless they can see it, and this doesn't happen every time unfortunately. |
10-15-2018, 05:14 PM | #8 | |
Rep 130
10-15-2018, 07:52 PM | #9 |
Rep 1,827
Is your fob in any kind of case? On a key ring with a bunch of other keys? Sometimes I find it less responsive if I have something bulky in my pocket and the key fob is behind it (ie. my vape mod).
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
10-17-2018, 05:13 PM | #10 |
Rep 176
