10-13-2018, 11:35 AM | #1 |
Rep 27
Esys coding problem
Hi,
Just swapped from an F22 to a F30 335i (so happy I did!) Anyway, I dug out the old laptop that I used to successfully code my 2 series so I could code similar things on the F30. I've updated the Launcher and have successfully coded a few features in the HU CBT CAFD. However the majority of the coding I want to do is in the FEM_BODY and KOMBI ECUs and when I try to read coding data for these I get the attached error. Is there something else I need to update for these? Cheers |
10-13-2018, 12:02 PM | #2 |
Rep 16,054
10-13-2018, 04:35 PM | #3 |
Rep 878
You need to update the data files your are using, when I had something similar I tried a few versions newer and older before I found a version that had the files I required.
10-14-2018, 01:06 AM | #4 |
2JZ-GTE
3005
Rep 3,986
Esys coding problem
This. Good luck and happy coding
10-17-2018, 03:42 PM | #5 |
Rep 626
Drives: X5 F15 M package
Guys,
while attempting to read edit FDL and see all codes I get the following error: The chosen token EST "c:\program~3 \TOKENM~1\E-SYSL~2\FREETO~1.EST" is no existing file. [C156] While I understand the issue I have no clue how to fix it. Any help please ? |
10-21-2018, 07:36 AM | #6 | |
Rep 2,302
The free Launcher Premium 2.8.2 together with E-Sys 3.27 is still a good solution. Download here: https://www.bimmerfest.com/forums/sh...d.php?t=983244 |
10-21-2018, 08:22 AM | #7 |
Rep 626
Launcher pro does not install on win 8 vm.
Any solution ? |
