BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Original Tire Size is 225/45-18, could I use 235/45-18?
      08-31-2016, 09:50 PM   #1
humbertob
humbertob's Avatar
Drives: '16 BMW M235i
Question Original Tire Size is 225/45-18, could I use 235/45-18?
Anybody here know if am able to use a 235/45-18 tire on my stock wheels with 225/45-18 tires currently ?
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i
'19 G01 X3 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
      08-31-2016, 09:57 PM   #2
mbanks21
Drives: 2015 335i MSport
Absolutely
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
      08-31-2016, 10:23 PM   #3
humbertob
humbertob's Avatar
Smile Thanks !
Thanks mbanks21 !
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      09-01-2016, 05:51 AM   #4
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
If you have a 255 stagger the rears can go to 275 with no issues.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      09-01-2016, 10:43 AM   #5
paul e
Drives: 340i xDrive 6MT
Or you could go 245/40. That's what I plan to do come change time. I think 245/40 comes a bit closer to the original spec for sidewall:
225/45=101.25
235/45=105.75
245/40= 98.00
Your call.
      09-02-2016, 09:30 AM   #6
BEAR-AvHistory
225/45=101.25
235/45=105.75
245/40= 98.00
Your call.
Agree ran 245/275 on the 19" 335is.
Kevin
      09-02-2016, 09:44 AM   #7
mbanks21
I wouldnt run 275 on the stock wheel if it's 8.5
      09-02-2016, 12:16 PM   #8
BEAR-AvHistory
Its OK on a stock 18/19" wheel for the rear if the car has a stagger as OEM.
Kevin
      09-02-2016, 03:35 PM   #9
T4NZ4NIT3 335i
Drives: 2013 BMW 335i xdrive Sportline
235 45 18 and 265 40 18 is the best stagerred setup, beefier sidewall, but not as bad as 245 45, increases overall diameter too much.If I had a rwd I wud run that setup. I have an xdrive so i run 255 40 18 square.
      09-02-2016, 04:43 PM   #10
oonowindoo
Drives: 2021 M340i RWD
Hey Bear,
Do you have a picture of the 275 rear on OEM rear?
I know they will fit, just curious how the sidewall looks on a 8.5 wide wheel.
      09-02-2016, 05:13 PM   #11
Hangman4358
Drives: '14 F31 328d Sportline
2017 M2  [0.00]
2014 328d F31  [0.00]
How wide is the rim? 8.5? You can't fit a 255/40 on the OEM 18x8, can you?
      09-03-2016, 06:09 AM   #12
BEAR-AvHistory
Originally Posted by oonowindoo View Post
Hey Bear,
You need at least a 9" rim, that's why I said if you have a stagger. The stagger OEM wheel set has different width rims front & back. The BMW 313 style wheel with 275X30X19" Conti DW Extreme Performance Summer Tire was very common on 335is cars running JB4's & going to the drag strip.
One of the guys was running in the high 11's on these tires. with just the tune + back end flash with an E85/93 fuel mix. My best was 12.1 tune only + back end flashon a 93/100 octane mix.
Have a close up on my desktop computer will see if its still alive.
Kevin
      09-03-2016, 08:31 AM   #13
T4NZ4NIT3 335i
18x8.5.you can fit it in 18x8 but it wud bulge like crazy and not food for grip.
      09-03-2016, 11:31 AM   #14
paul e
According to Tirerack, minimum width for 245 is 8.0", for 255 the minimum is 8.5".
      09-06-2016, 07:13 PM   #15
oonowindoo
We/I do have staggered wheels.. unfortunately i do not believe they are 9" wide. M sport 19s are 19x8 and 19x8.5
      09-06-2016, 08:36 PM   #16
saaltonen
saaltonen's Avatar
Drives: 2014 F31 328i xDrive
I went with a 245/40R18 when I ditched my stock run flat Pirelli P7 run-flats. Less of a stretched look, I like the change personally.
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
tires
