BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BLINKZYKLEN_ANZAHL_TIPP No longer easy to change
      03-12-2017, 03:05 AM   #1
Magnetic845
New Zealand
Drives: M135i
Hey All,
My F30 recently got programmed with F020-17-03-502 and like the i3 boys the tripple turn signal adjustment coding now says "einmal" with no other options in the dropbox.
Has anyone successfully adjusted it by changing the Werte=00 value in the box below? If so, what would the value for 5 flashes in total be?
In the past this was an easy change, now sadly not so. Took a little longer to flow in F020 software than the i3 stuff but it's now changed.
Thanks
      03-13-2017, 01:46 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
BLINKZYKLEN_ANZAHL_TIPP: 04 no longer has any effect?
Unfortunately, the solution for the F015 and I012 will not work as PIA_DEFAULT_TIPPBLINKEN will only accept 00 or 01.
      03-13-2017, 01:57 AM   #3
jbeer
jbeer's Avatar
Drives: 320i M Sport Shadow Edition
I was trying to get this to work the other week on my 2013 320i to no avail.....someone in the UK was helping me and they did get it to work on theirs but they had a .ncd file that was a higher version than mine, I have 005 and they had 011
Current: F30 2018 320i M Sport Shadow Edition
Accessories: BMW OEM Roof Bars & Bike Carriers, Dashcam - Blackvue 590W-2CH
      03-13-2017, 05:48 AM   #4
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
There is a value i remember that can increase the blinking interval if that what you mean.
FEM == (search for sth called vorne_hinten)
i am having some problems with my esys in these moments and i cant tell the exact name
that FDL will increase the interval
Check 00:17 in this video
https://www.facebook.com/TheGarageEg...5074336232290/
      03-13-2017, 01:42 PM   #5
Almaretto
Almaretto's Avatar
2374
You can always try using TM's NCD / CAFD Tool if E-sys is having issues.
@0:17, I just see windows rolling up with door opened.
Vorn = Front. Hinten = Rear.
  • In HU_NBT(2), those are used for PDC sensor location.
  • For Fem_Body, window delays as well as blinker status checks.
      03-13-2017, 03:24 PM   #6
seanantenbring
Drives: G21 M340i
I'm having the same issue. I was able to code BLINKZYKLEN_ANZAHL_TIPP with no issues at first but following a dealer software update I now can't code it. Werte value is 00 and changing to 03 or 04 does nothing.
      03-13-2017, 04:13 PM   #7
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
My bad Alamerto it's on 00:30 i read what time is left in the video.
Well, NCD tool now requires an activation code too and i am using a pretty new laptop.
Regrading the increased interval, As soon as i connect my car using BMWAI will tell you the desired name and function.
Almaretto2374.00
      03-13-2017, 06:15 PM   #8
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
thats it
      03-13-2017, 06:29 PM   #9
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
I read the post totally wrong, you were talking about the easy blinker while i was thinking of the singals interval
      03-14-2017, 11:11 PM   #10
Almaretto
Almaretto's Avatar
2374
thats it
Yeah. That looks like checks for front and rear blinker. We are looking for new way to adjust soft blinker count.
View post on imgur.com
      03-15-2017, 04:57 AM   #11
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
I will give it a shot and if i reached anything i will post it here.
btw, i have been coding for couple of months, no body asked to me code the soft blinker yet.
      03-15-2017, 01:08 PM   #12
Almaretto
Almaretto's Avatar
2374
Sounds good. I have been coding for 4+ years and 90+% ask for soft blinker.
      03-15-2017, 01:12 PM   #13
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
its totally different in Egypt my man😀
      03-21-2017, 05:01 PM   #14
seanantenbring
Drives: G21 M340i
Has anyone found the fix for this? Miss having more than 3 blinks using soft touch
      03-29-2017, 04:04 AM   #15
bmwdd
Drives: F30
i think someone mentioned he knows how as he did it for G series but he didn't share how.
      04-05-2024, 09:24 AM   #16
nightwalkerbg
Bulgaria
Drives: F31 / Yaris II
Same here ...very sad .
I'm with F30 LCI 2016, really miss 6 blinking from the old F30 pre LCI
I have "BLINKZYKLEN_ANZAHL_TIPP" . I'm changing "Werte" to 4,5 or 6 and "save it/code it" but it didn't take effect.
It's 2024 now, is there still no way to be coded Is'n there any solution?
THank you in advance
