04-04-2017, 07:23 AM | #1 |
Rep 132
PDC
Hi Guys, does anyone know if its possible to code the front PDC to remain permanently on. On my car it only gets activated either via the 'P' button or if reverse is engaged.
Cheers |
04-04-2017, 08:59 AM | #2 |
Rep 1,687
Drives: 2014 428i and 2018 X5
I wouldn't mind the same thing. Just checked the coding cheat sheet available here: http://www.bimmerfest.com/forums/sho...16&postcount=2 and didn't see any PDC items that would control that unfortunately.
04-04-2017, 10:23 AM | #3 |
Rep 740
you can try this and see if this work. You most likely still need to trigger it on first.
REM> 3201 PDCVehicleConfig1A> CUT_OFF_SPEED value = 0F (6mph). Increase the value to something really high, like hex value of 96 (100mph)
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
04-04-2017, 10:37 AM | #4 |
Rep 132
OK thanks I'll give it a go, it may help once initially triggered by reversing.
