BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Incandescent brake bulbs installed with LED brake light coding?
      04-10-2017, 11:56 PM   #1
ikehigh05
Drives: 2011 328i xdrive
So I had coded and installed LEDs for my rear turn signals and brake lights. One of the LEDs for the brake lights went bad(cheap). So I reinstalled the stock, clear incandescent bulbs in the brake light sockets. Everything seems to work as it should, but I do realize that I still have LED coding, and coding to disable the warm/cold checks enabled for the brake light function.
Besides not being alerted via idrive/dash that a bulb may be out, is there any concerns I should have regarding regular bulbs installed with LED coding??
      04-11-2017, 06:34 AM   #2
atzebmw
Drives: Tesla Model 3
No, that's no problem if you only changed the cold/warm check and no voltage settings.
