04-11-2017, 04:25 PM | #1 |
Rep 118
Esys Token Issue
Hi guys,
I have an issue with Esys Launcher Premium. I changed the date several times - now it doesn't work anymore as I'm on 2019 I payed Eli. for the Pro version, but he doesn't answer to emails and the date problem is the same... I used Esysplus, but it seems contain virus, and FDL resolution doesn't work for me. I used psdzdata 59 / 60 / 61... same issue Someone knows how to clean correctly PC, that after reinstalling Esys Launcher it doesn't detect the old installations ? Or another idea please ? |
04-11-2017, 05:23 PM | #2 |
Rep 8,364
The trick is to not create Token or Launch E-sys with date modification. Otherwise, you will run into your issue.
It has nothing to do with PSdZ; You just need version >= vehicle I-Step. |
04-11-2017, 05:29 PM | #3 | |
Rep 118
About Launcher (Pro and/or Premium versions), according to TokenMaster, the PC must be cleaned to delete files that stay after the Esys Launcher uninstallation (that inform about the date of last time the program was used) - someone knows something about that ? Except EsysPlus and Esys Launcher, is there another token solution ? |
04-12-2017, 12:09 PM | #4 | |
Rep 8,364
Search your C drive for "Tokenmaster" & "Launcher." |
