BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Heated Sportline Steering Wheel - Don't need heat
      04-17-2017, 11:21 AM   #1
murphius1118
murphius1118's Avatar
100
Drives: 2013 328i xDrive
I have a base steering wheel in my 2013 328i xDrive and may be purchasing a Sportline wheel with airbag - no paddles but has heat function. Will my car throw any error codes if I install wheel and the heat is not connected or retrofitted? I don't care about the heated functionality nor do I want to spend the cash on the retrofit parts.
'13 328i xDrive│Jet Black│BMS JB Stage 1│MPE│18" 400M & Conti DWS 06│DelVal BMW CCA #533245
      04-17-2017, 11:29 PM   #2
KingpinRCR
Belgium
61
Drives: F30 320d ed
The heat function has a separate connector so the car won't even know the steering wheel has that function. I did it on mine about a year ago and didn't get any errors.
(Well, I did recently get an airbag error but that's because the airbag connector got loose.)
Kind regards,
KingpinRCR
obert1781.00
      04-18-2017, 06:43 AM   #3
murphius1118
100
Thanks for clarifying. I wasn't sure if there was a separate connector or not.
      04-18-2017, 12:26 PM   #4
TomaGo
TomaGo's Avatar
France
91
Drives: BMW X4
I confirm, i have the same configuration on my car and there is no issue as the heat cable are not connected.
