09-15-2020, 12:00 PM | #1278 |
Rep 40,786
09-15-2020, 12:06 PM | #1279 |
Rep 3
09-15-2020, 12:17 PM | #1280 |
Rep 40,786
Yes. PSdZData has to be >= to ECU version.
09-15-2020, 12:23 PM | #1281 |
Rep 3
09-15-2020, 01:20 PM | #1282 |
Rep 40,786
For Coding, you need only Lite versions.
09-16-2020, 10:34 AM | #1284 |
Rep 40,786
PM sent.
09-17-2020, 12:15 AM | #1285 |
Rep 7
Thanks a million Shawn!
Just updated psdzdata. The procedure as follows: downloaded archive, unpack, delete psdzdata from folder c:\data (esys data location), copy the unpacked psdzdata under c:\data. E-sys started fine, new options for chassis connections, but unfortunately now the button detect caf from swe is greyed out. With the older psdzdata, the button was accesible. Is there something I am missing? Last edited by mih222001; 09-17-2020 at 06:40 AM.. |
09-17-2020, 07:39 AM | #1286 | |
Rep 40,786
09-17-2020, 08:44 AM | #1287 |
Rep 7
Indeed, I was aware of this, and I have tried also with 3.30.0. I have installed a second instance of E-sys under ec-apps by creating a new installation folder and deploying there. Basically under ec-apps I have two folders, for the two E-sys versions.
Still the button is greyed out also in 3.30.0. Another question is, assuming the scenario when I need to inject cafd for a certain module and afterwards code it, how can I work with these 2 instances? With one I inject the cafd and with the other, coding? As a side note, I was able to code with my old version 3.27.1 the Kombi module to display the digital speedo, so FDL coding works, and the connection with the car is okay. Any suggestions to tackle this? |
09-17-2020, 10:34 AM | #1288 | |
Rep 40,786
Code with 3.27.1, flash and inject CAFD with 3.30.0.
09-17-2020, 10:45 AM | #1289 |
Rep 7
Hey Shawn. The ecu is TRSVC, but the thing is that with 3.27.1 and old psdzdata the detect caf from swe was accessible. With 3.30.0 and psdzdata 4.25.1 it is greyed out, idem if I try with 3.27.1 and psdzdata 4.25.1. FA is activated in all the above cases.
What I am trying to achieve is to VO code option 3AG, and to code TRSVC, HUH_NBT and REM after a rear view camera retrofit. With 3.27.1 and old psdzdata it failed to code TRSVC throwing a cafd not found error. Basically this is the long story short. I am trying to get a working coding tool for my car's I-step configuration which was updated by the dealer last year. |
09-17-2020, 10:47 AM | #1290 | |
Rep 40,786
09-17-2020, 11:15 AM | #1291 |
Rep 7
My second neuron came into play and I've realised that I have installed version 3.33.0 instead of 3.30.0. I will try again with 3.30.0, as I have grabbed it already.
Update: installed 3.30.0, I was able to VO code 3AG. Everything worked, I have now a rear view camera installed! Thanks Shawn, much appreciated. Last edited by mih222001; 09-17-2020 at 04:00 PM.. |
09-18-2020, 11:33 AM | #1293 |
Rep 40,786
09-18-2020, 12:52 PM | #1295 |
Rep 40,786
PM sent.
09-20-2020, 11:03 AM | #1298 |
Rep 40,786
PM sent.
