06-19-2018, 12:33 PM | #265 |
Rep 3,680
That actually makes sense, good analogy. Still kind of odd to me that an upgraded FMIC would slow a stage 1 car down though, just a weird thought to digest. I would've thought that the drop in IATs would've at least compensated for the little bit of loss you're getting from the extra volume added in the intercooler, but I guess not. I trust you though, what you're saying definitely makes sense.
06-19-2018, 12:44 PM | #266 | |
Rep 146
06-19-2018, 09:59 PM | #267 |
Rep 3,680
True, you don't see the IAT benefits until the latter part of a pull anyway.
06-19-2018, 10:50 PM | #268 | |
Rep 2,639
All drag runs normally keep you above 5k rpm and thats where stuff starts heating up. You also want IAT to drop quickly if you were idle waiting to go on the line, on a normal 80-85F day, you could be at 110-120F idle IAT. |
06-20-2018, 09:00 AM | #269 | |
Rep 2,382
R, remember that Stage 1 keeps the boost around stock and is typically taking more advantage to pull power from the timing. So if the boost chain is remaining the ~same~ as stock, it's just not accounting to push enough early to fill it quick enough. Hell, there is even such a thing as too big of an FMIC for Stage 2!
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
Rokoz294.50 |
06-20-2018, 10:44 PM | #270 | |
Rep 3,680
06-23-2018, 12:14 PM | #272 |
Rep 3,680
What is your burble configuration set to? Are you catless/high-flow? Assuming no since you're stage one, but wanted to ask anyway.
06-23-2018, 12:19 PM | #273 |
Rep 109
I'm running the updated version 4 of the OTS ST1 93 OCT. i was running the OTS ST2 93 OCT with the VRSF DP, but decided to go back to stock DP and downgrade it back to ST1.
06-23-2018, 12:28 PM | #274 | |
Rep 3,680
Also, why did you make the decision to go back to stage 1 after stage 2? I'm almost certainly about to go up to stage 2 and curious why you made the switch back.
06-23-2018, 12:52 PM | #275 |
Rep 109
it was a personal choice. the VRSF dp was awesome and loud AF. but i drive my 2yr daughter to and from school everyday. every morning when i start up the car, i didnt want her inhaling those exhaust fumes inside the garage, and vice-versa.
06-23-2018, 08:01 PM | #276 |
Rep 48
In regards to the burbles on stage 1, what were your configurations for aggressiveness and duration? Also will this melt the kitty in the stock downpipe? The burble sounds are to die for!
Alpine White 320i /// BM3 Stage 2 93 OCT AGG /// Evolution Racewerks FMIC-CP-TP /// VRSF Catless Downpipe /// AWE Tuning Touring Exhaust /// Injen SP Series Intake /// M3 Style Headlights /// Carbon Fiber Spoiler-Lip-Grille
06-23-2018, 08:20 PM | #277 |
Rep 3,680
I don't know about melt, but that's why I was asking. Agressive burbles are not good for the cat and they will damage it over time. Little ones are fine, like the ones you (I) get setting them to OEM in the configurables menu. The burbles in the video above sound too aggressive for the stock cat.
06-23-2018, 08:42 PM | #278 |
Rep 48
My AWE exhaust and Wagner catless come in later in July. Personally I am running with stock exhaust and BM3 stage 1 with burbles set to 5 AGG and 2 seconds duration. Pretty sure I’m hurting the kitty everyday =/
06-23-2018, 09:29 PM | #279 |
Rep 3,680
You are... I'm running OEM so when I sell the car I still have a good downpipe when I go back to stock. Should be catless soon enough though.
06-25-2018, 08:49 AM | #280 |
Rep 2,382
Definitely be careful. I'd personally baby the cat even if you are taking it off. You will likely put it back on if/when you sell the car. Too many burbles will melt that poor thing and knock it around.
brofessorpham26.50 |
07-03-2018, 11:57 AM | #281 | |
Rep 39
Has either of you gone ahead with the bm3 flash? Also MEVD1724 here. Build date 04/12. Experienced users care to chime in? Will I have to request a custom map to make sure things work out well? Main concern is daily drivability since I daily drive mine to work
2012 Glacier Silver F30 328i
18 x 8.5 Square Apex SM-10 | 245/40/18 Michelin PS4 | F8x LCA | Red M Performance Brakes | F80 Steering Wheel | VRSF 5" HD FMIC | Full FTP Piping |
07-03-2018, 09:34 PM | #282 | |
Rep 65
update the dme and will be fine to load in OTS maps. thanks |
07-05-2018, 04:01 AM | #284 |
Rep 24
07-05-2018, 04:03 AM | #285 |
Rep 24
dont worry, ptf has OTS maps for it , and which updated to 4.1 now
07-06-2018, 09:31 PM | #286 |
Rep 109
bm3, bootmod3 |
