BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
Vorsteiner
      10-22-2018, 10:16 AM   #1915
Seba77W
Seba77W's Avatar
258
Drives: BMW 435i Xdrive Coupe
Originally Posted by aturk View Post
Originally Posted by Seba77W View Post
Really? You regret the $3 and change you spent per plug? I don't think it's a big deal, just run em for 20k and swap for something else. I'm running the NGK 97506 with my MHD Stage 2+ 95 octane tune and they've been great. When I took them out of the box I checked the gap, it was at about .030 so I left it there and they work great. All though MHD recommends stock plugs and gap as well. However running the more aggressive timing 95 octane tune I figured why not splurge on the 1 step colder NGKs.
Where do you find them for $3/plug???
They are around $13/plug from RockAuto.
Was meant to say $3 and change extra per plug over the Bosch. I apologize for any confusion. I will do my best not to have this same problem come up in the future, and thank you.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
      10-22-2018, 10:40 AM   #1916
TSA8151
Drives: 2013 F30 335i msport
Does bootmod3 have a race gas ots tune for pwg n55s?
      10-22-2018, 11:19 AM   #1917
stlb5
stlb5's Avatar
44
Drives: '14 M235i MT, '15 X5 Msport
Originally Posted by stlb5 View Post
A couple runs today. Boost is higher and WGDC is lower. The logs yesterday were right after I flashed Stage 2, could it be learning? Do these show any signs of boost leak?
Run 1
Run 2
Above were logs on Shell 93. Here are the logs on BP 93 with 4 ounces of Boostane Premium. I was struggling for traction in 2nd so only got one log feathering throttle. Do these look better? Did the boostane help?
2nd Gear
3rd Gear 1
3rd Gear 2
2014 M235i MT, BSM, MPE, Dinan Springs (His)
2015 X5 Msport, CB (Hers)
      10-22-2018, 11:30 AM   #1918
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Those look good, the timing is clean on 3rd Gear 1, on 3rd Gear 2 the #3 cylinder is behind but catches up at higher RPM. I'd say the boostane fixed the timing up. If you're going to run boostane going forward I recommend getting the professional to save some money per can.
stlb544.00
      10-23-2018, 12:16 PM   #1919
F30_SixSpeed
F30_SixSpeed's Avatar
937
Drives: 335i M Sport
F30 N55 335i PWG - PS2 Turbo + FBO. STOCK Fuel system 93 octane.
Stock tune and OTS S2H 93 oct v7.1
Gainzzz
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
      10-23-2018, 01:24 PM   #1920
JaredG_F30
JaredG_F30's Avatar
695
Drives: 2014 335i, M-Sport, Manual
Hell yeah!! NOt bad for an OTS map.
Gainzzz
2014 F30 335i, M-Sport, 6MT, V801s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, 381 whp, 429 wtq (waiting for install: GFB DV+) Next: Ohlins R&T, M Performance LSD, M Performance Brake Kit
SPI Films Blog/DIY Vids
      10-23-2018, 03:22 PM   #1921
XxThe_RemedyXx
Greece
424
Drives: 2014 335i XDrive
Anyone know why EWG maps are at 6.1 and PWG maps are at 7.1? Is it just because of the hardware differences?
'14 335 xDrive EWG FBO - VRSF Chargepipe - VRSF Downpipe - AA Intercooler - MPE - BM3 Custom Tune by Cary Jordan (in progress) - R1 Concepts Front/Rear Geomet Cross Drilled and Slotted Rotors
      10-23-2018, 03:54 PM   #1922
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
They're considered completely different platforms so it's unlikely their versions will match up. I think it's a coincidence that they both happen to be on an .1 version. Maybe the PWG maps released first or required more patching. Who knows. It's just a version number.
For example, the N55 in the M2 is "only" on version 5.5. It doesn't mean anything.
      10-23-2018, 04:24 PM   #1923
stlb5
stlb5's Avatar
44
Are the E30 maps based on octane? Based on an online calculator, e30 is about 96 octane. Could I run an e30 map if I added boostane to get 98 octane?
      10-23-2018, 04:28 PM   #1924
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
Originally Posted by wdeerfield View Post
I notice a lot of users have a catless downpipe but that is problematic for me in NY. I saw that they have recommended hardware for the tunes. Is it possible to run the stage 2 tune with an upgraded CP, FMIC, and intake only? im trying to figure out what is my best course since im still stock downpipe and exhaust at the moment with no plans to upgrade the DP due to emissions here. Unless someone knows a way to set the readiness monitors.
please excuse my ignorance but i cant find a definitive answer on this and they dont seem to list out the OTS maps unless you buy from them. In the event the stage 2 will not work for me, is stage 1 worth it from those that have used it?
Anyone able to help out with this or is it best to just email PTF?
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      10-23-2018, 05:07 PM   #1925
upsidedownfunnel
Drives: 2014 335i
I was in the exact same boat. Some people say you can proceed cautiously while others recommend against it.
I currently run an FMIC and CP but no DP and have stayed on Stage 1 91 (I'm in CA). Others have tried Stage 2 with no mods at all but I doubt anyone would do so long term.
You can email PTF, and if they even get back to you, they'd just point you to their recommendations anyway.
I think the best option for us is to eventually get a custom tune. We probably fit in somewhere between Stage 1 and Stage 2 but probably closer to Stage 1. It'd be nice if PTF released a Stage 1+ for people with FMIC. I feel like a lot of people prefer not to install a catless DP.
wdeerfield1377.50
      10-23-2018, 06:10 PM   #1926
designatedposter
Drives: m235i
Octane and fuel trim. Ethanol rich fuels have less power density so requires more fuel.
      10-23-2018, 06:59 PM   #1927
HKD126
Drives: 2014 335i XDrive MSport
Custom Meth tune - 415awhp/492awtq
Custom 93 tune - 370awhp/467awtq
OTS 93 tune - 370awhp/399awtq
Stock flash - 295awhp/290awtq
JordanTuned
2014 335i XDrive
AFE drop in filter
ER charge pipe
Wagner Comp Evo 2 IC
ER catless downpipe
TorqByte CM5LT/5gph nozzle/100% meth
Slight misfire on the 93 tune with OEM plugs at OEM gap. Power was dialed back from the 390ish area on the 93 tune due to misfiring. Swapped to NGK gapped to .020, misfires cleaned up a bit, but still slightly present up top around 6k. Misfires were non existent on the meth tune. Cary thinks I need new coils as they have 45k on them. Keep in mind both tunes are not quite done yet due to the coil issue. I will have to swap them and we can resume this coming spring when the snow disappears and I am back from traveling for work. We should see quite an improvement in the top end. Nothing that canít be finished on the street and another quick dyno session.
First and second gear are currently useless until I get some better rubber. I highly recommend a custom tune over OTS. My car wouldíve probably made more power with the AWE catback I used to have on it, but the exhaust was so damn loud I couldnít take it anymore...
Iíll post a graph tomorrow when I get it.
      10-23-2018, 07:30 PM   #1928
F30_SixSpeed
937
You can try Wagner Catted DP. Never had a CEL or problems with emissions with that DP. Highly recommended.
You can technically run stage 2 with stock DP, but not really recommended.
I was certainly happy! Car ran really strong on that map!! Now adding more fueling and boost!!
JordanTuned
2014 335i XDrive
AFE drop in filter
ER charge pipe
ER catless downpipe
Slight misfire on the 93 tune with OEM plugs at OEM gap. Power was dialed back from the 390ish area on the 93 tune due to misfiring. Swapped to NGK gapped to .020, misfires cleaned up a bit, but still slightly present up top. Misfires were non existent on the meth tune. Cary thinks I need new coils as they have 45k on them.
Nice numbers! No Graphs though
      10-23-2018, 09:58 PM   #1929
HKD126
Iíll have the graph tomorrow.
      10-24-2018, 09:29 AM   #1930
HKD126
Dyno chart up.
      10-24-2018, 10:50 AM   #1931
designatedposter
Drives: m235i
Dyno chart up.
No graph of the ots 93?
      10-24-2018, 11:54 AM   #1932
HKD126
They have it there. This is what I was sent today. I have one from a previous visit to the same dyno as well...
      10-28-2018, 08:32 AM   #1933
ceedawg
ceedawg's Avatar
401
Drives: 2k15 335i xdrive MSport 6spd
I finally go around to loading BM3 on my Avin 10.25" Andriod screen and it works. Much better than my phone display. This is the 7.1 version, would not run on 4.4.
So Sweet I need this!!
Stock 2k15 335i Msport xdrive 6spd Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, ACS springs.
Wish list Big Turbo kit Yes! PS2 Nope!
      10-28-2018, 01:25 PM   #1934
$howtime456
$howtime456's Avatar
118
Drives: BMW 640i
Gainzzz
NICE!!!
AUTOCARE M LIFE
LABWORX
NYC FINEST F06 GC
      11-01-2018, 11:42 PM   #1935
Guerillah
Drives: 15' F30 335xi AW MSport Stg 2
When running e30, how do you guys manage to keep the ethanol content consistently at/around 30% after multiple fill ups? I feel like it's a big guessing game since you don't really know how much fuel is in your tank.. ?? I have a e85 station about 6 miles away which is why I ask.
      11-01-2018, 11:58 PM   #1936
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO S2 bm3 w/ options
This is what I use.... Fuel-It Flex-Fuel Sensor BT Analyzer
My Build Thread can be found HERE
FastF30218.50
