09-11-2018, 09:39 AM | #1 |
Rep 10,473
Quaife LSD Differential build and install
On the advice of Lancelot moving forward with a Quaife Differential on my F30 highly modified AH3.
Went about it differently than others. Found a used 2017 Differential on eBay with 9k miles for $180 (had a broken outer seal which scared most away). Was in Trenton, NJ so I had someone drive it to the Quaife Distributor/Machine Shop in Philadelphia avoiding shipping charges and also visually inspect Differential. A weld needs breaking in the BMW Differential and a machine shop to complete the rebuild. They are starting the rebuild process. Will have it installed at LABWORXS in Cherry Hill, NJ. This allows me to keep the stock OEM Differential for whatever reason in future should I want to go back to stock and sell Quaife unit (highly doubt it). Also allows me to keep car operational during the rebuild time. Will update as it proceeds. Last edited by IK6SPEED; 09-11-2018 at 11:11 PM.. |
09-11-2018, 09:59 AM | #2 |
Cheapskate
4447
Rep 4,993
Nice. I was looking at wavetrac because I believe they sell the whole assembly with a core charge. But this seems cheaper if deals like that can be found.
09-11-2018, 02:35 PM | #3 |
Rep 928
Wavetracs are nice I was running one with 625 whp for awhile in my CAMARO.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
09-11-2018, 02:37 PM | #4 |
Rep 928
Are our f30 diffs interchangeable with the f80's?
09-11-2018, 02:42 PM | #6 | |
Rep 928
09-11-2018, 02:43 PM | #7 |
Rep 928
Do f80's have bigger axles and r and p?
09-11-2018, 03:01 PM | #8 |
Rep 1,291
Well it's an electronic diff to begin with so you'd need an ecu that would accept to play with the rest of the car's ecus, then physically the attachment points to the subframe are different (as f80 subframe is different too).
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-11-2018, 03:05 PM | #9 | |
Rep 10,473
The N55 F30s run 2.81 (d and AH3), 3.15 Sports/Automatic and 3.23 Manual The B58 F30s run 2.81 Sports/Automatic or 3.13 Manual. If buying a used differential, you need to make sure it matches up to what up you have. Last edited by IK6SPEED; 09-11-2018 at 03:25 PM.. |
09-11-2018, 03:58 PM | #10 | ||
Rep 928
09-11-2018, 03:59 PM | #11 | |||
Rep 10,473
09-11-2018, 04:00 PM | #12 | ||||
Rep 928
09-11-2018, 04:01 PM | #13 | |||||
Rep 10,473
09-11-2018, 04:07 PM | #14 |
Rep 928
I see it now 3.23 thanks
I'm posting while working....
10-12-2018, 09:07 PM | #18 |
Rep 488
Let me know how it is, this is just about the only mod I don't yet have on mine.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
IK6SPEED4488.00 |
10-12-2018, 09:07 PM | #19 |
Car Hypochondriac
335
Rep 901
How much was the damage? I'd like to do this as well, I'd prefer a quaife or wavetrac over the m performance...
10-12-2018, 09:15 PM | #20 |
Rep 10,473
Rough figures, $1500 for the Quaife.
Another $1100 to mod the current dif as a machine shop is needed with special equipment to break weld and modify it with Quaife. Most shops do not have the equipment to machine this. And about another 4 hours of labor to install modified dif in car. |
Eschmacher334.50 |
10-12-2018, 09:22 PM | #21 | |
Car Hypochondriac
335
Rep 901
10-12-2018, 09:38 PM | #22 |
Rep 10,473
