BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Avin USA 10.25 android system install DIY
      10-21-2018, 03:31 PM   #2377
kalinkamaen
Drives: BMW X3 2.0 Diesel
Originally Posted by ddigian View Post
in my case, I think not!
I did some tests and I think the problem is software and not hardware
in fact, when I delete the cache from the MUSIC app the system starts again and again without problems and then after some kind of 4 or 5 switching on the problem occurs again
and as if you could not shut down in time when you close the car
because the 12v power supply is removed before the system turns off completely
Oki, If you hard reset your device. Does it go directly in to No signal? Do you have splitter?
      10-22-2018, 07:23 AM   #2378
ddigian
Danilo
Italy
Drives: bmw 318d
yes I have the splitter, I also did the Hard reset, but
anything .
I tell you that not using the app music and using all of them
other applications the "no signal" problem on 30 ignitions
only once happened.
When using music there are problems otherwise not
      10-22-2018, 11:25 AM   #2379
Wooju
Drives: 5 series F10
Hello, could somebody advise please how to prepare the usb stick to upgrade the unit for android 7.1?
      10-22-2018, 12:05 PM   #2380
kalinkamaen
anything .
only once happened.
When I had the splitter installed my unit went in No signal mode everytime I hard reset my unit. Now without splitter I have not had any no signal screen since. Please test to only unplug GPS antenna for a while. Its a 5 min job.
      10-22-2018, 12:07 PM   #2381
kalinkamaen
Format to Fat32 or NTFS. Copy PX3.img to root of USB stick. If it doesnt work on one usb port, try the other one. Min only worked to upgrade through 1 of 2 usb ports.
      10-22-2018, 01:22 PM   #2382
ddigian
Danilo
Italy
Drives: bmw 318d
ok ,I'll try
      10-22-2018, 03:19 PM   #2383
vieira_mar
Portugal
Drives: BMW F44 M235i
Is this the 8,8 inch version. If so there is a reset switch on the right side. There is a small hole. You need a smal steal thing to push it.
It is not possible to make a default app to my understanding. To be honest I am happy that music app starts on default. Because when I close music app and start spotify or internett radio, both works with next and back key on steeringwheel.
This freeze issue has also happened to me once. I think its running to hot. Its just a guess from me. But I know from other units that PX3 will overheat very easy. I am going to install a fan later to see if it helps. <-- But I have only experienced it once. But I am only using it for Sycig, not Gmaps. I think Gmaps is using more Cpu power.
Firmware updates.
MCU updates. <.-- Only instal CIC MCU updates on your unit if your is CIC. NOT CCC and NOT NBT.
THIS IS 7.1 ONLY. DO NOT USE FOR ANDROID 4.4.4
Does this update work for my version?
View post on imgur.com
My car is BMW F21
      10-22-2018, 03:32 PM   #2384
Wooju
Thanks. That's what i have done but wasn't working. I had to disable the file explorer which was taking over the autorun and it work fine.
What is the difference between tbe firmware version and mcu? Do i need to upgrade both? Is there any order to do it is mcu has to be on specific version before upgrading firmware?
Thanks again
      10-22-2018, 06:12 PM   #2385
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Have you guys seen this?
https://4x4shop.ca/product-category/...ation/oem-bmw/
Video Demo:
ronanz1819.50
      10-22-2018, 08:10 PM   #2386
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Originally Posted by XxThe_RemedyXx View Post
Great find!! Thanks!! . .
My Build Thread can be found HERE
      10-22-2018, 08:34 PM   #2387
jc2000
Drives: BMW F10
Hi,
Can someone Help, my unit is BMW F10 Android 4.4. Over last few days my Unit Stuck in the BMW logo when boot up. It doesn't boot up at all. The BMW original I Drive is working Fine but not the Android. Can someone please help.
      10-23-2018, 01:44 AM   #2388
kalinkamaen
Thanks again
Firmware is upgrading Android.
I would not recommend to upgrade MCU If you are happy with how your unit is working. Newer is nopt always better.
Its writen to upgrade FW first and then MCU afterwards in documents. I am not sure what is the correct order. You can go for what version you want.
      10-23-2018, 01:52 AM   #2389
kalinkamaen
Originally Posted by jc2000 View Post
Hi,
https://drive.google.com/open?id=1Tf...zE24LeHhyBOHK6
Taken from this post earlier:
https://f30.bimmerpost.com/forums/sh...postcount=2354
      10-23-2018, 04:55 AM   #2390
kalinkamaen
My car is BMW F21
Yes!
      10-23-2018, 10:07 AM   #2391
belmix
Drives: bmw x1
Hi! Who has the latest firmware on 4.4?
      10-23-2018, 10:23 AM   #2392
belmix
Drives: bmw x1
I have a unit 4.4.4 gen2 avin
and I still have the problem that often when yes
start the drive gives me the error "no signal"
I have to turn off the car or reset button
I have the latest update but still many times myself
from this problem
can someone help me
Thank you
Danilo
In factory setting check - Old BMW X1
      10-23-2018, 02:23 PM   #2393
jc2000
Drives: BMW F10
Thank you i will give it a try
      10-24-2018, 01:30 AM   #2394
Werra2006
Drives: X5 E70 2009
I have seen a cable on AliExpress that I think can provide a low cost solution to connecting to the Aux in the arm rest.
Has anyone tried this cable instead of ripping the centre console and running the aux cable into the armrest?
https://www.aliexpress.com/snapshot/...Id=32872691908
      10-24-2018, 07:12 AM   #2395
ddigian
Danilo
Italy
Drives: bmw 318d
Because, that works what it does.
I have the problem on the android side.
      10-24-2018, 07:23 AM   #2396
kalinkamaen
I am using a similar cable with no problems. Its not plug and play. You need to move cables over to stock plug.
      10-24-2018, 07:51 AM   #2397
vieira_mar
Portugal
I already did the update. However, I can not change the brightness settings in the Android setup menu. Do you know how to access this luminosity menu? Thank you
      10-24-2018, 08:32 AM   #2398
Werra2006
Drives: X5 E70 2009
Could you please explain how you wired this cable? I have ordered one and I am hoping to do the connection when the cable arrives.
