BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Running without TPMS?
      09-25-2018, 12:28 PM   #1
Bigyin1314
Drives: F36 435d
so, I bought a set of winter wheels and had the tyres fitted. It just dawned on me that at no point did the seller mention tpms sensors and I dont think I have them fitted.
Question is, can I run the car without the sensors and if so is it likely to cause any issues?
      09-25-2018, 12:49 PM   #2
teaston
Drives: X3 M40d
Does your car definitely have TPMS, or just the old flat tyre warning?
      09-25-2018, 01:03 PM   #3
Bigyin1314
Drives: F36 435d
Yeah pretty sure, It went off today, I had to reset the system by driving and it measured each tyre giving me the psi of each, that sound right?
      09-25-2018, 01:28 PM   #4
sensible
sensible's Avatar
810
Drives: BMW 420i M-Sport Gran Coupe
I run my winter tyres without TPMS valves (not runflats). It just means that you have to acknowledge the fault on the idrive every time you start up with one press of the knob. A warning light then stays on the dash for the journey but you can use them without.
If you have runflat tyres it is advisable that you have TPMS valves as you may not realise they are losing pressure.
      09-25-2018, 01:34 PM   #5
teaston
Drives: X3 M40d
Ok that is TPMS then. If you run wheels without the sensors you will get an annoying message every time you get in the car (it doesn’t appear until after a few miles the first time) and you have to click the idrive knob to clear it.
You can code the car to revert back to the old style flat tyre warning though. I did that for a couple of winters but last winter I had enough and bought some sensors for them.
      09-25-2018, 02:35 PM   #6
Bigyin1314
Drives: F36 435d
I can live with clearing the fault short term, I was reading that it can prevents you from going into other drive modes and also if the fault persists, it locks and the dealer had to clear it ...... I’m guessing that you didn’t have those issues?
      09-25-2018, 02:55 PM   #7
Hooded
England
1669
Drives: F30 330d M-Sport
It's ok as long as your MOT isn't due while your running them without the sensors
https://www.tyresafe.org/media-centr...s-to-fail-mot/
      09-25-2018, 03:35 PM   #8
teaston
Drives: X3 M40d
No there were no issues like that at all.
      09-26-2018, 05:37 AM   #9
Bigyin1314
Drives: F36 435d
Hmmm, Mot is at the start of feb.
      09-26-2018, 06:55 AM   #10
Hooded
England
1669
Take it on for an early MOT now if you really wanna run the winters without the valves
      05-01-2019, 08:31 AM   #11
ezzaf30
Drives: BMW 320D F30
Tpms not working
Hi guys,
Wondering if anyone can help! Just brought 320d f30. Had a warning come up on the idrive about low tyre pressure on rear passander side. Stopped the car and fill tyre to the correct pressure and tried to reset the system but for some reason none of the tyres are highlighted and the reset tyre pressure is not letting me select that function
      06-13-2019, 01:26 AM   #12
Superfizzy
Drives: f31 330d xd
ezzaf30, I have the same problem. Did you find a solution?
      06-13-2019, 04:08 AM   #13
RickLS7
RickLS7's Avatar
Drives: F32 435D, Boxster 981S
I had this problem when I bought the car, the aerial in the car that receives the TPMS data was dodgy and a common failure.
This was replaced under warranty and not had an issue since.
      06-13-2019, 04:58 AM   #14
dizzy619
Drives: F31 340i
£100 ish on ebay if needed
      06-13-2019, 01:40 PM   #15
Superfizzy
Drives: f31 330d xd
My car doesn't have TPMS though ....
Just the version that works on ABS sensor data. Main Stealer said it should have reset after a few miles when it went in for the EGR recall (no work required, yay), and didn't look at it because I have an android head unit.
