10-29-2018, 05:14 PM | #23 | ||
Rep 46
I can't understand any of this, Audi allows for up to 5% deviation on their AWD setups, and this is only 0.4% with BMW wheels and tires... so not happy. |
10-29-2018, 05:29 PM | #24 | |
Rep 2,499
I have no idea how hard you tried, but I would keep pushing for them to cover it under warranty. Send BMW NA a letter. Detail that your car is using tire sizes that come standard on other BMW xDrive vehicles. Ask them how that could possibly cause a warranty issue. It's technically possible there is different software in xDrive cars with staggered tires. However it is unlikely. |
10-29-2018, 05:50 PM | #25 | |
Rep 46
Thanks everyone for hearing my rant. |
10-30-2018, 09:15 AM | #26 |
Cheapskate
4447
Rep 4,993
The stupid part is dealers don't lose money on warranty work. BMW pays them the labor costs. So I have always found it strange that some dealers want to be overly critical of warranty work.
Also putting 225 tires all the way around is worse. Now you're stretching the tire on the rear wheels which exposes the edge of the rim and risks them getting beat up a lot more. You should use at least a 245 wide tire on a 8.5" wide wheel. |
alohasurftoad3078.00 |
10-30-2018, 10:36 AM | #27 | |
Rep 46
It's a temporary solution until I can get a square set of wheels (or get BMW to accept my staggered wheels, which sounds unlikely) |
10-30-2018, 12:03 PM | #28 |
Rep 46
FWIW I dropped off my car at the dealer today (check engine light is on again for the DEF system) and the service manager I got this time said he never heard of a warranty being voided for tire sizes and also stated there are xdrive cars with the same staggered setup. He said we would look into the issue for me, but I'm not hopeful
10-31-2018, 01:41 PM | #29 | |
Rep 2,499
10-31-2018, 06:40 PM | #30 | ||
Rep 128
Drives: 2014 435 x drive msport
10-31-2018, 08:36 PM | #31 |
Cheapskate
4447
Rep 4,993
how? they complete the work and send the bill to BMW instead of the owner. it's the same.
11-01-2018, 07:15 PM | #32 | |
Rep 46
So i'm out $200 bucks for the alignment to have the car be exactly the same, and they won't work on it further until it has new front tires as well now... good grief, the car only has 38K miles... at least they fixed the check engine light it had (failed SCR module) I imagine the dealer doesn't make any money on the parts in that case, just labor? |
11-01-2018, 08:19 PM | #34 |
Rep 128
I'm wondering if it's something else, or the transfer case got screwed up somehow otherwise then
11-02-2018, 02:19 AM | #35 |
Rep 369
You could look at classifieds or craigs list etc and just buy another set of 403s and use the 225s on all 4 corners. Then sell the 4 255s as a set, someone will like that setup assuming the front wheel wells can run 255s. Or you keep the 255 if you prefer, and sell the 225s.
You should be able to find a set for under $1,000, mostly depending on condition and the tires. When you sell 4 you get your money back. I found new 400m on CL and almost broke even selling original crappy 393s. |
11-02-2018, 08:05 AM | #36 | |
Cheapskate
4447
Rep 4,993
the only thing that they might be concerned about is work authorization. usually bigger things like engine/transmission replacements go through a system that automatically sends an inspector to review the issue before sending parts. But again, no ding on them for at least submitting the order and trying to complete the repair. If BMW turns it down, so be it. The transfer case might fall in that category. |
chiefneil771.50 |
11-02-2018, 12:13 PM | #37 | |
Rep 46
11-05-2018, 08:15 AM | #38 |
Rep 5,995
Is this a CPO car it is coming off lease with the wrong tires and you didn't put them on seems like fraud to me as the previous owner should pay for damages that occurred during the lease or resulting from it. If they didn't catch it when it was returned that is on them.
11-06-2018, 12:06 PM | #39 | |
Rep 46
Based on this thread -> https://f30.bimmerpost.com/forums/sh....php?t=1407191 It seems like BMW knows there is an issue, and they'll do anything to get out of warrantying it. The transfer cases must be made of glass if they can't put up with the factory staggered sets or even square setups that are slightly more worn front vs rear. I'll update next week when the the car goes back into the dealer. |
11-06-2018, 11:27 PM | #40 | ||
Rep 128
12-11-2018, 06:01 PM | #41 | |
Rep 46
My bet is the stuttering was from the front tires being worn than the rear tires (being brand new) on the 19" 403M's. (too large a difference in diameter for the xdrive) I'm not 100% happy with the outcome as I preferred the look of the 403M 19" wheels, but BMW wouldn't look at the car without the change and that was the compromise my dealer made. There were some other issues found that could have been affecting things too though; They replaced a rear knuckle, drive flange and wheel bearing that had "damage" (I had some strange pulling when braking heavily) I'm still worried about xdrive failure (per other threads with multiple low mileage cases) but for now I'll just enjoy the car. |
12-12-2018, 12:36 AM | #42 | ||
Rep 128
12-12-2018, 05:47 PM | #43 |
Rep 46
I've also heard that BMW "star" tires and the equivalent non-star tires are slightly different in width and height. In my case when the dealer replaced only the rear tires they were non-star and the front were still BMW star. I guess another thing to keep in mind for xdrive cars.
12-28-2018, 11:43 AM | #44 |
Rep 1
I have a similar question. I'm running 225/55 R17 summer tires(all 4 tires are the same size) on 2017 330i GT xDrive. The winter tires I bought are 225/50 R17(again all 4 are the same size) and dealer is telling that because the tires are a different size(non-OEM sized) this will confuse and possibly damage the xDrive system. Is there any truth to this?
