08-17-2023, 05:16 AM | #727 | |
Rep 20
Tonight i'll try stage2+ again and upload the log here |
08-17-2023, 05:58 AM | #728 |
Rep 505
add few liters of e85 and timing corrections will be gone. also if ambient temp is high (like +30C or smth) car will noticeably slower
08-17-2023, 11:53 AM | #729 |
Rep 20
E85 is not available in my area. I bought 50 liters of alcohol ethyl denatured 100°..I will try to add it to the tank and check the log
08-17-2023, 04:04 PM | #730 |
Rep 3,885
Measure the alcohol content yourself! Do not trust the label!! More often than not, it will be lower! 100% Ethanol requires additional destillation. So unless it had a corresponding price-tag, it is most likely around 96%.
08-17-2023, 04:56 PM | #731 |
Rep 577
If it says 100% 200 proof anhydrous ethanol for him, it should be good. If it’s been denatured to any degree, the specs must be observed. I’ve used pure 200 proof before and tested it myself.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
08-17-2023, 05:32 PM | #732 |
Rep 20
I bought directly from a company that produces alcohol. They have two versions of denatured ethyl alcohol, 94° and 100°. I bought the 100° version. this is the description:
"Completely denatured 100° ethyl alcohol following the legislation dictated by EU Reg. 1112/2017, it is colorless and odorless, ideal as a solvent in the restoration sector to dissolve shellac, or in the chemical-pharmaceutical sector for in vitro diagnostic use." |
10-15-2023, 04:27 PM | #733 |
Rep 118
10-15-2023, 09:22 PM | #734 |
Rep 62
B58 GEN 1 | RWD Built Engine (Pistons and Rods) Stock Transmission PI with 750cc Stock Manifold PURE800 Stage 2 (Old version) Fuel E85 Stage 3 LPFP M Performance Exhaust + VRSF Downpipe Last edited by jav140i; 10-15-2023 at 10:10 PM.. |
10-15-2023, 09:57 PM | #735 | |
Rep 577
current
10-15-2023, 10:08 PM | #736 |
Rep 62
M Performance Exhaust + VRSF Downpipe. This numbers where done with unfinished map. Could not test final map, had no traction i limit 3rd gear torque. Lower temps would help even more
10-15-2023, 10:17 PM | #737 |
Rep 577
Nice, I used to have the exact same exhaust setup until I switch to a turndown. If you were to swap to a 3.5” diameter exhaust/downpipe you could probably cut a couple tenths off just by freeing up some back pressure and flow the turbo is seeing through the stock style exhaust/downpipe.
current
10-15-2023, 11:55 PM | #738 | |
Rep 62
10-16-2023, 03:24 AM | #739 |
Rep 577
For sure a water meth nozzle will help, on a stock intake manifold even more. The bigger exhaust is the most simple mod, but since your rwd on a narrow body tires are super necessary. My one issue with the F2X body is how narrow it is, it’s my one reason as to why these cars need to be x-drive.
current
M2C40.00 |
10-16-2023, 08:25 AM | #741 | |
Rep 118
10-16-2023, 07:24 PM | #743 |
Rep 1,372
That is crazy fast. 5.78 60-130 should equate to about a 140 mph trap!
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
jav140i33.50 |
10-17-2023, 02:09 AM | #744 |
Rep 118
11-10-2023, 07:18 AM | #747 |
Rep 62
