01-30-2020, 07:39 PM | #1 |
Rep 25
Hello all,
I'm inquiring if anyone has fitted 19' 437m(s) on their F36? I'm curious if this is doable without rubbing issues? I contacted BMW and they were not helpful. Looking for concave wheels and a more aggressive stance. Looking to fill wheel well without doing any suspension mods. Any help, and pics too, would be greatly appreciated. Thanks in advance. |
01-30-2020, 09:40 PM | #2 |
Rep 943
Drives: F30 328i Msport
Oem or reps? Not the same fitment. If oem then they will poke out ever so slightly on stock suspension, if reps they will be in the wheel well nicely.
01-30-2020, 10:07 PM | #3 |
Rep 25
Ideally OEM's although pricey. Any suggestion on reputable replicas? Any good websites that you can see how the look and fit?
01-31-2020, 11:33 AM | #4 |
Rep 118
This thread should help https://f30.bimmerpost.com/forums/sh....php?t=1133583
IG: @tanzanitem4
01-31-2020, 09:40 PM | #5 | |
Rep 25
Thanks again |
01-31-2020, 09:46 PM | #6 | |
Rep 25
01-31-2020, 11:18 PM | #7 |
Rep 4,365
https://f30.bimmerpost.com/forums/sh...5&postcount=20
https://f30.bimmerpost.com/forums/sh...&postcount=112 https://f30.bimmerpost.com/forums/sh...&postcount=136 https://f30.bimmerpost.com/forums/sh...&postcount=154 https://f30.bimmerpost.com/forums/sh...&postcount=260 due to somewhat aggressive widths and offsets meant for M-cars, you need at least, a mild lowering(to add slight negative camber) for OEM 437M to look good on F3/4 series. a typical requirement to have concave wheels are wide widths and low offsets, not always available as a front wheel spec on aftermarket wheels. the OEM 437M front wheel is 19x9 +29 is one of the most concave front wheel I know of that fits an F3/4 series, albeit with slight poke and aggression. you can run a 19x9.5 +35 aftermarket wheel with 255/35/19 tire, if you want the front wheels to have concavity. the video has an F36 with a 295/30/19 on the OEM 437 rear but you can see how much poke it has. generally a 285/30/19 on a 10-10.5" widths, with offsets between +40 to +45 is the widest that'll fit on the rear. you'll still need it lowered to get the tire flush or it'll poke especially at +40 if you are not going to lower your car, 235/40/19--265/35/19 is the tire size to use on OEM 437M, the fronts will be a little stretched, though. an optional size combo is 255/35/19-265/35/19 Last edited by alohasurftoad; 01-31-2020 at 11:27 PM.. |
02-01-2020, 09:26 AM | #8 | |
Rep 25
Cheers |
alohasurftoad3118.00 |
03-03-2020, 02:46 AM | #9 | |
Rep 110
Drives: 2014 335i 6MT
01-22-2023, 03:42 PM | #10 | |
Rep 81
Currently I have pirelli p zero 245/35/19 F 265/35/19 R But I’m getting 4 new tires (Michelin Pilot Super Sports) Was wondering if stock M4 size of 255/35/19 F 275/35/19 R Would that work? Should I keep that same 245/265 setup? I bought the car with this setup so I’m a bit confused with all this tire stuff because I’m new to it and I’m trying to learn and figure out the best setup. Would it be better to have bmw do the alignment or take it to a specialist shop. Also Poke doesn’t really bother me I’m more for how they will handle and everything. https://f30.bimmerpost.com/forums/sh....php?t=1986734 That thread has picture of my car with current setup |
