04-13-2021, 04:11 PM | #1 |
Rep 16
2012 F30 iDrive Controller Upgrade
Hello All,
I’ve tried to search however it cannot find the answer I’m looking for. I currently have 2012 F30 320d and it came with Factory HU_Entry 6.5 screen, base level with no Nav, just Bluetooth. I’ve upgraded to a Android 10.25inch which is all working fine. My current iDrive Controller Want to Upgrade To this Nav iDrive Controller It has the Nav and Media buttons and up and down movements. I’m not bothered about the newer iDrive Touch a controller. Note I do not use the BMW menus, I always use screen in Android all the time Can I simply get a NAV iDrive Controller from say 2012 model and its plug and play? If not what else is required to make this work. Many Thanks |
04-13-2021, 06:14 PM | #2 |
Rep 539
Pictures aren’t showing up here but the small iDrive dial controller should just plug in and work since 2012 controllers are KCAN1. A larger dial one wouldn’t without some extra wiring since it’s KCAN2 and I think from 2014 (but I may be wrong) the controllers switched over to that.
04-13-2021, 07:14 PM | #3 |
Rep 339
also up and down won't work because your head unit isn't designed for that particular movement. I have a 2016 F36 GC, that originally came with an NBT radio, non nav. and 6in screen and smaller controller, I personally upgraded both the screen to the 8 inch and the larger controller. up and down don't work, however on the screen it tries to, but really can't, hard to explain... you can still see the smaller controls. also upgraded to larger wheel with extra buttons...extra buttons work, except navigation...because car never had navigation before...see, smaller original screen
04-22-2021, 04:09 AM | #4 | |
Rep 16
As I just simply want the up and down function on the wheel and the extra Nav button. Thanks |
04-28-2021, 12:04 PM | #5 |
Rep 61
Hello I'm sorry for asking on your post. But I want to upgrade to the Android screen as you have but I am not sure if my car can handle it. However when you mentioned your dial doesn't have the up/down feature I recognized that!
Can you just quickly look at my post and see if we have the same system? If so I should probably be able to upgrade mine as well! I also want the up/down button on the wheel. Thank you so much! https://f30.bimmerpost.com/forums/sh....php?t=1821062 |
05-07-2021, 01:19 PM | #7 |
Rep 2
f30-12-316i
HELLO EVERYONE;
I have 2012 F30 too. 316i Sedan EUR, prod.month 07/2012, TYPE CODE: 3A11 This picture is my idrive menu. There is no navigation, no bluetooth, no usb. It has only AUX. I want to upgrade it. But i don't know what system that i should buy. Is my system CIC? And is it 4 pin or 6 pin? LAST 7 OF VIN: J175972, I need advice, thank you all. |
05-10-2021, 04:34 PM | #8 | |
Rep 2
Anyone knows?
05-20-2021, 10:23 PM | #9 | ||
Rep 660
Drives: 2014-320Xi / 2017-330Xi
