06-15-2021, 01:42 PM | #1 |
Rep 614
Drives: 2016 F36 M Sport
F36 Cabin Filter
I need to replace the cabin filter in my '16 F36, but wondering what is the best one to buy, or if they're all the same. I.e., are the cheap $15-20 ones legit? I see some with activated charcoal, some regular looking ones... Any recommendations?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
06-15-2021, 01:58 PM | #2 |
Rep 614
Also, if I change it, will the vehicle recognize the new filter? I'm just wondering if the dealer will keep telling me it needs to be changed because they don't have a record of it being changed by them, or if the computer will indicate that it's been replaced already.
06-15-2021, 02:46 PM | #3 |
Rep 496
It's not expensive, buy OEM if you can. For the same reason, it's all right if the dealer change it again at service time. The car can't tell whether the filter has been changed or not, unless you tell it.
(I think the same way about changing the oil myself when necessary. I don't record the change in the service history, as if I never changed it and let it record only the official service by the dealer.) |
QuikSilver_175.50 |
06-15-2021, 02:56 PM | #4 |
Rep 562
Drives: 2017 BMW 330i xDrive
The quality of the filter is up to you...if you just want to make sure it keeps large dust particles out, the cheapest of the bunch works fine. If you want to make sure it filters out allergens, you'll want to step up a grade or two. If you want to make sure absolutely everything, including smells, never reaches the cabin, you'll want to step up further to the charcoal filters. The automatic recirculate does a good job of keeping offensive odors out already, so I generally don't worry about much other than the particulates. I wouldn't worry about that, either, except some of my passengers have allergies.
Very simple and easy job to DIY, and your car has absolutely no idea what's going on with the cabin filter, so no coding or resets required. Would definitely recommend DIY if you can, the dealer charged me $190 to change the thing. Could have done it myself for $20.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
QuikSilver_175.50 SlickShift322.50 |
06-15-2021, 03:12 PM | #5 | |
Rep 614
06-15-2021, 06:41 PM | #6 |
Rep 5,092
My assumption is that F36 cabin filter DIY is the same as F30 job, which takes 15 mins if experienced. The first time took my 45 mins. as the panel had to be aligned exactly one way.
The BMW cabin filter for F30 is around $25-35, and it is tied to brake fluid service. |
QuikSilver_175.50 |
06-15-2021, 07:36 PM | #7 |
Rep 326
I used this on my F30:
https://www.fcpeuro.com/products/cab...r-cto-80004354 Identical to OEM, is charcoal, but doesn't have the BMW stamp. I got it for $8! When I bought the filter from the dealer I paid $89 (just the filter no install) Idk what the F36 needs, but if it's the same, than I would recommend it. Price isn't everything.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
QuikSilver_175.50 |
06-15-2021, 08:25 PM | #8 | |
Rep 614
06-15-2021, 08:30 PM | #9 | ||
Rep 326
06-15-2021, 08:48 PM | #10 | |
Rep 5,092
That is not bad given the price, except the plastic frame banged on the enclosure over bumps, and that drove me nuts! So I swapped that out with genuine BMW one for $25 for peace and quiet. |
06-15-2021, 08:56 PM | #11 |
Rep 5,092
Do note that the non-BMW ones tend to not bend/fit like the BMW ones, so the cabin filter may not sit tight in the enclosure(i.e. air leaks), and/or plastic frame may bang on enclosure(annoying), so buyers beware.
06-15-2021, 09:24 PM | #12 |
Rep 4,897
This is what I bought for my F30:
https://www.amazon.com/TYC-800195C-R...3810014&sr=8-3 No issues with bending to install (I do know some do). Just keep in mind whatever you pick, BMW DOES NOT make filters. They find a supplier, ask them to but a really expensive B M W stamp on them. I don't know what their cabin filter supplier is, but they do use Mann for other things like oil filters. BMW has one of the oddest installs for a cabin filter. On Honda's they just pop straight into place. On the F30, it's bend and then rotated up to get it in there. Not impossible, and watching a quick video will make it pretty clear. Mine took a bit longer the first time since the dealership removed the airbag bolt, and then used that to secure the plastic bottom cover (all wrong BTW). |
06-15-2021, 09:59 PM | #13 | ||
Rep 326
06-15-2021, 10:01 PM | #14 |
Rep 562
Contorting a cabin air filter for installation is sadly not unique to BMW, and is becoming commonplace. My last car basically required crushing the filter flat from end to end and I guess hoping it would expand back to full size once you shoved it in there.
I wouldn’t spend more than $30 on a cabin filter. Rock Auto has the extra-lux air filtration examples (even filters germs) for around that price. The above poster is correct, BMW manufacturers no filters of any kind themselves. Don’t be fooled into paying them more so they can slap a stamp on someone else’s product.
06-15-2021, 10:07 PM | #15 | ||
Rep 326
It's like buying the BMW engine oil filter. The MANN hu816x is exactly the same. BMW does not manufacture any of their filters. They rely on suppliers.
Wires1657.50 |
06-15-2021, 10:17 PM | #16 | |
Rep 326
If I had allergies, than an advanced filter might make sense to me in that case. But for keeping dust, pollen, and other things, lots of filters can do a good job.
06-15-2021, 10:49 PM | #17 | |
Rep 5,092
Similar issue was experienced with my F30 Fuyao side glass. The first Fuyao without BMW marking squeaked and had vertical lines, while the 2nd Fuyao from BMW dealer fit like a glove with no defect. My take is that OE (non genuine BMW) is not guaranteed to have identical spec. |
06-15-2021, 10:57 PM | #18 |
Rep 5,092
I think u meant OE versus genuine BMW, as fcpeuro defines OEM as:
"....produced by a manufacturer that supplies at least one OE part to a vehicle manufacturer. OEM parts may not have been original to the car, but are held to higher-quality standards and stringent quality control." BTW, this is an interesting clip comparing BMW star vs. non BMW PS4S from Michelin, genuine BMW PS4S is designed to a different spec to non BMW PS4S. |
06-15-2021, 10:59 PM | #19 | ||
Rep 326
To be honest, mine was identical to the part I bought from the dealer. One was $8, the other was $89. Otherwise, I wouldn't be able to tell a difference. Hope you have better part endeavours next time.
06-15-2021, 11:05 PM | #20 | |
Rep 562
A Fuyao window or Mann filter is produced by the same machinery in the same factory whether it has a BMW stamp or not. BMW, of course, only allows A grade units to put their stamp on. Rejects that are fully functional, but may have cosmetic or other ‘first world’ issues are sold at a heavy discount. Buy your parts from a reputable source (Rock Auto, FCP Euro, etc), and there shouldn’t be an issue. They also source A grade parts, but don’t surcharge for the brand label.
Slick_FThirty125.00 |
06-15-2021, 11:07 PM | #21 |
Rep 5,092
Thanks! Yeah hunting for quality parts can be part of the fun.
E.g. several years ago I got news the dealers sold BMW air filters for $5, and wiper sets for $10, and brake pad sets for $30. Naturally I loaded up big time. The cheapest BMW cabin filters were from eBay@$25, it was risky but the markings and pleat counts, thickness, heights, frame build, and hologram logo(on the box) all checked out. |
06-15-2021, 11:17 PM | #22 | |
Rep 5,092
