04-05-2017, 02:57 PM | #111 | |
Rep 8,364
I do not have all details of your CAFD, but I believe this is correct:
MrMarvin31.50 bringmywallet9.00 |
04-06-2017, 12:58 AM | #112 | |
Rep 15
04-06-2017, 03:24 AM | #113 | |
Rep 1,201
I think I may be misunderstanding what you say but you should not be setting the POLI_idx to 64. as Almaretto says, it should be the corresponding LmmIdx Intensity associated with the DRL
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
04-06-2017, 09:21 AM | #114 | |
electrified
32
Rep 127
04-06-2017, 12:47 PM | #115 |
Rep 8,364
04-08-2017, 06:58 AM | #116 | |
Rep 93
Dlr i have 100% parking I have 100% but want to dim to 50% and drl with low beam I have 8%. Also I dont have in esys "MAPPING_PARKL_V_L_PWM_LEVEL_1 " Please advice guys. Cheers |
04-08-2017, 12:25 PM | #117 | |
Rep 8,364
06-20-2017, 12:35 AM | #118 |
Rep 139
I wanted to code my angel eyes DRL (not with my low beams, just DRL and welcome light) to 100% the other day but they didn't get as bright as they should've been. One of my other friends that's a member on here as well did his halo's the same way that night and his got so bright that they looked washed out but they actually worked for him. We both followed the same f30 cheat sheet and changed the values through FEM_BODY. We also both have retrofitted lights, not the factory angel eyes. Where else should I look to change the values of mine? It currently say they're running at 100% but they're not the brightest they can go. They are nowhere "washed out". I just want to see how it looks like with my BSM during the day since mine during the day look dim
06-20-2017, 01:37 AM | #119 | |
Rep 1,201
Are they OEM or third party lights?
06-20-2017, 03:00 AM | #120 | |
Rep 139
It's not a big deal at all to me as I only wanted to see what they looked like in my car but I definitely want to try it out and see. We only coded 2 files under FEM_BODY... which are these MAPPING_TAGFAHRL_V_L_PWM_LEVEL_1 (set at 64 - 100%) MAPPING_TAGFAHRL_V_R_PWM_LEVEL_1 (set at 64 - 100%) I'm only looking to change the brightness on the daytime running lights, not while my low beams are on. |
06-20-2017, 03:12 PM | #121 |
Rep 1,201
Adding non OEM lights to the mix adds a whole new dimension to things.
Bit strange your friend got it to work and your's didn't
06-20-2017, 03:46 PM | #122 |
Rep 139
Exactly lol. I even coded them to 32- 50% and mine dimmed to 50% and I took it back up to 100% but it's still not the brightest. Oh well, I guess I'll just leave them how they are. Should I try changing anything on what I was reading earlier in this thread? or is that only for DRL with low beams?
06-21-2017, 01:47 AM | #123 | |
Rep 1,201
The changes in FEM are primarily for cars with xenon headlights. If you have a LCI F30 with LED, then a different method is needed within two modules call FLE's. And if you have a pre-lci F32 with adaptive LED, you adjust values in the TMS modules. Your non-OEM lights may or may not add custom modules and / or coding to the mix too.
06-21-2017, 04:57 AM | #124 | |
Rep 139
07-11-2018, 03:00 PM | #125 |
Rep 5
Hello all,
I try to modify to full brightness on Mini F57 2017 with FLE module. I've this type of were value : 03, 03, 03, 03, 0A, 0A, 03. Anyone know which value to have full brightness with headlight on ? Thanks |
07-11-2018, 10:10 PM | #126 | |
Rep 8,364
Without more information, it would be hard to advise. |
10-31-2019, 09:10 PM | #128 |
Rep 8,364
11-01-2019, 07:34 PM | #130 | |
Rep 8,364
Basically have to compare DRL_Idx to POLI1_Idx to discover which bit is halo. Then, modify WELL1_Idx, WELL2_Idx, WELL3_Idx, & WELL4_Idx accordingly or corresponding intensity level in other section. |
03-24-2020, 02:53 PM | #131 | |
Rep 30
Had to read your post a couple of times, but now i was able to code my standing lights to 62% (3E) and my parking lights to 30% (1E in the unused LmmIdx26) |
07-03-2022, 01:21 AM | #132 | |
Rep 33
What LmmIdx15_Priority value is for? Last edited by acmilangr; 07-03-2022 at 02:00 AM.. |
