01-14-2018, 07:35 AM | #1 |
Rep 170
CIC/NBT FSC Generator - Windows/Linux/OSX
This is (hopefully) a more user-friendly CIC/NBT FSC Key Generator for Windows, Linux and OSX based off of the work of the original FSC Key Generator and Intel123's certificate Patcher.
Input Files
Support Files
Unsupported Feature
As an example: Code:
FSC Date VIN Build Date Days Difference 200910211749 Thursday, October 22, 2009 -1 201001271515 Thursday, January 28, 2010 -1 201004011026 Monday, April 04, 2011 -3 201006071536 Tuesday, June 08, 2010 -1 201107121301 Wednesday, July 13, 2011 -1 201110310756 Wednesday, November 02, 2011 -3 201201111004 Thursday, January 12, 2012 -1 201203301822 Monday, April 02, 2012 -4 201204181719 Wednesday, April 18, 2012 0 201205242316 Friday, May 25, 2012 -1 201210010521 Tuesday, October 02, 2012 -1 201210010703 Tuesday, October 02, 2012 -1 201210241654 Thursday, October 25, 2012 -1 201211081709 Friday, November 09, 2012 -1 201305140635 Wednesday, May 15, 2013 -1 201308142104 Friday, August 16, 2013 -2 201403071931 Monday, March 10, 2014 -3 201404091427 Thursday, April 10, 2014 -1 201404300545 Friday, May 02, 2014 -3 201406241001 Tuesday, June 24, 2014 0 201406241307 Tuesday, June 24, 2014 0 201409161938 Wednesday, September 17, 2014 -1
Code:
Version History v1.91 Feature: Option to attempt to repair corrupt 1B file Bugfix: Download/Rename Lookup.xml Misc: Add "Select Option" to dropdowns, since I'm tired of answering "Click 'Premium'. Select 'Premium', then the next dropdown will become enabled" v1.9 - Add support for F0 Files. NBT EVO Headunits which use NEXT style maps. v1.02 - Allow Numerical First Digit for VIN. Bug Identification & Explanation provided by txomin in post 71 v1.01 - Unhide "Lifetime" Checkbox v1.0 - Initial Release Last edited by Jagaer; 05-02-2021 at 06:31 PM.. |
42
rflagg6.00 bubblecat0.00 larry_bml194.00 panache0.00 0burner00.00 x-m4n148.00 buggydrvr13.00 raptor_xxx0.00 bcoz80.50 Cromzinc0.00 einimuascht0.00 Roch M4424.00 Douggie142.00 tyrystor0.00 Coxy1191.50 ronnymadmax0.00 raphaelpais6.00 Tommi_Mav65.50 mahe0.00 rudders0.00 shozal0.00 TinCanSailor629.50 SteveWis1120.00 BuiltS850.00 DLucian6.00 MightyMike751.50 geron15.50 fe7565552.50 lutzman3.00 bill57p90.00 marcell8420.00 badbulll0.00 HighLight0.00 dleecs1.50 |
01-15-2018, 08:55 AM | #2 |
Rep 10
Drives: F30 2014 Estoril Blue M Sport
Here is the short vin from 3x NBT units, and the codes
F149333 - WIGHHJ63ZHXEAAFJAD7Q K566308 - F4LCSEQKXQ2BOAFJAD7Q KE95871 - YGF6C2VRX5KI6AFJAD7Q |
ez_2get12.00 |
06-23-2018, 01:52 PM | #13 | |
Rep 276
Genarated the code by date maybe that doesn't work Then searched net(found sollution), used esys to read and create fsc file, used file to genarate code and now its installing Last edited by deneyer; 06-23-2018 at 02:52 PM.. |
06-23-2018, 08:44 PM | #14 | |
Rep 5
production date 01,02,2011 North America Premium code 6WBJ4MHHYPORYABNAAWQ |
07-08-2018, 02:55 PM | #15 | |
Rep 3
For me the same question. FSC generation by file generates a fsc code, but bij Date I can't select any date, its grayed out. I'm using WIN10 64 bit Thanks for your reply Jan |
07-13-2018, 04:26 PM | #17 |
Rep 34
08-18-2018, 04:18 PM | #18 | |
Rep 236
08-18-2018, 04:20 PM | #19 |
Rep 236
Did you solve your problem?
08-18-2018, 08:36 PM | #20 | |
Rep 170
Enter your VIN. If the VIN isn't valid, it will not let you select a date. Select a Date, and the Map Type field will become active. You need to select a map type. Even if "Premium" is displayed, it will not let you select a region until you click on "Premium" You need to select a region. Even if you want "Arabian Gulf", it will not let you select a Map Year until you click on "Arabian Gulf". etc... I hope this is a bit more clear. |
08-22-2018, 03:45 PM | #22 |
Rep 7
Thanks Jaeger! If I may suggest a future improvement:
A lot of users seem to have problems adding a new release date to the lookup.xml file. For example: 2020-1 is not in the lookup file yet and nobody knows how long BMW will stick to the current byte pattern to identify releases. You might want to add edit boxes to enter the map type and release date as byte values, as an alternative to the dropdown boxes with fixed lookup values. |
panache0.00 |
