BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 - 51 knocks detected in 30 minutes
      10-23-2019, 11:03 PM   #1
Danny__Boi
Drives: 2014 BMW 335i
Starting this thread now that I can make threads. Original comment was in the Bootmod3 General Discussion:
Hi all, just joined to ask if this was bad (because it sounds bad to me). I flashed the [93 Stage 1 OTS] tune a month ago but didn’t know to do any logging until recently. I decided to log my drive to work and had 51 knocks detected in the 30 minutes to get there. Here is the link to the data if anybody can help: http://www.bootmod3.net/log?id=5dae3ecac090c61539d93ebd
For now I have returned to stock tune (still have the BM3 transmission tune on though). The only upgrade I’ve done is the charge pipe. Spark plugs were recently changed (I’m at 62k miles). Ambient temps today were in the 60s
Later came back with stock tune on the same drive, similar ambient temps and it had 34 knocks detected:http://www.bootmod3.net/log?id=5db0d8bec090c61539d945ad
Just wanted to see if this was normal or not. I did one first to third gear pull in stock tune after reading a reply to me but I'll have to do a better pull tomorrow to get better data. That one pull did have a knock detected however (halfway through first gear)
Car is a 2014 335i with VRSF Charge Pipe running 93 Octane fuel
Any input is appreciated
      10-23-2019, 11:15 PM   #2
thejeremyman9
Drives: 2015 BMW 335i
As i mentioned in the other thread, knock during commute-type driving isn't really cause for concern. The DME is working to optomize fuel economy; AFRs are leaner, load is lower, timing is more advanced, etc.
The knock during WOT pull could be a sign your fuel isnt high enough octane. You can always try a 91 map.
It would also help if you posted your exact car specs (beyond 2014 335i), mods, fuel, etc.
      10-23-2019, 11:53 PM   #3
Danny__Boi
Thanks! I updated the post to contain more info on the car. Unfortunately the pull knock was on stock tune (I'm guessing by default that's for 91 based on the fuel requirements) but I might give Bootmod3 91 map a try
      10-24-2019, 12:21 AM   #4
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
2014 BMW 335i  [0.00]
93 Octane from where? Premium ARCO or off-brand is not equal to premium Shell or Chevron. I learned this the hard way.
      10-24-2019, 02:59 AM   #5
hybris
hybris's Avatar
Norway
158
Drives: BMW 330e F30 M-sport
I (and many others) have to run 91 tune to avoid timing issues despite using 93 gas, apparently gas isn't gas.
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      10-26-2019, 07:10 PM   #6
Danny__Boi
I was running 93 from RaceTrac and QT but this last tank I filled from Chevron (1/4 of old gas left though)
Here is the logs with a 4th gear pull and a 1 to 5 gear pull. Unfortunately on both pulls it looks like knock was detected: http://www.bootmod3.net/log?id=5db4cd20c090c6759f4a1edf
Earlier I tried stock tune 4th gear pull and it had no knocks detected: http://www.bootmod3.net/log?id=5db4c6fec090c6759f4a1ebd
Unfortunately, looks like Iíll have to give the 91 tune a shot instead. I appreciate your help!
